Specifications
Engine Type Liquid-cooled 4-stroke 8-valve, SOHC parallel 2-cylinder
Displacement 670cm3
Bore x Stroke 73 x 80mm
Compression Ratio 10.7: 1
Max. Power Output 38.1kW/6.25min-1 (35.0kW/6,250min-1 - 95/1/EC)
Max. Torque 62Nm/4.75min-1 (60Nm/4,750min-1 - 95/1/EC)
Fuel System
Carburation PGM-FI electronic fuel injection
Throttle Bore 36mm
Aircleaner 5.8
Fuel Tank Capacity 10.7: 1
Max. Power Output 14.1litres
Fuel Consumption 27.9km/l (3.579 L/100km (WMTC D-Mode) / 3.585 L/100km - (WMTC D-Mode)*)
Electrical System
Ignition System Computer-controlled digital transistorised with electronic advance
Ignition Timing 12° BTDC (idle) ~ 53.9° BTDC (6.600min-1)
Sparkplug Type IFR6G-11K
Starter Electric
Battery Capacity 12V/11AH
Headlight 212V, 60W x 1 (low)/55W x 1 (high)
Drivetrain
Clutch Wet, multiplate hydraulic 2-clutch
Clutch Operation D mode/S mode/Manual mode
Transmission Type 6-speed Dual Clutch Transmission
Primary Reduction 1.92
Gear Ratios 1 2.67
2 1.9
3 1.45
4 1.2
5 1.03
6 0.84
Final Reduction 2.44
Final Drive Chain
Frame
Type Diamond; steel pipe
Chassis
Dimensions (LxWxH) 2,195 x 790 x 1,440mm
Wheelbase 1,525mm
Caster Angle 27°
Trail 110mm
Seat Height 790mm
Ground Clearance 135mm
Kerb Weight 238kg (F: 49.8kg; R: 50.2kg)
Max. Carrying Capacity 195kg
Suspension
Type Front 41mm telescopic fork, 120mm travel
Rear Monoshock damper, Pro-Link swingarm, 120mm travel
Wheels
Type Front multi-spoke cast aluminium
Rear multi-spoke cast aluminium
Rim Size Front 17 x MT3.5
Rear 17 x MT3.5
Tyre Size Front 120/70-17
Rear 160/60-17
Tyre Pressure Front 250kPa
Rear 290kPa
Brakes
Type Front 320mm single wavy hydraulic disc with 3-piston calipers and sintered metal pads, ABS/CBS as standard
Rear 240mm single wavy hydraulic disc with single-piston caliper and sintered metal pads, ABS/CBS as standard
