Aprilia SRV 850
1 reply to this topic
#1 VeNoM
  • 165 posts
  • VozimXciting 400i
Posted 05 February 2012 - 17:19
slučajno (a kako drugačije) naleteo sam na snimak ovog skutera.
Posted ImagePosted Imagene izgleda lose možda je čak naslednik onog gilerinog gp-a.
specifikacije govore sledeće
Engine 90° V-twin engine, 4-stroke
Engine capacity 839.3 cc
Bore/stroke 88 mm / 69 mm
Power 76 HP @ 7,750 rpm
Torque 76.4 Nm @ 6.000 rpm
Timing system Single overhead camshaft (SOHC) - 4 valves per cylinder
Induction system Electronic injection with Ø 38 mm single body
Cooling system Liquid with three-way thermostat
Lubrication Dry sump with double trochoid lobe pump
Gearbox CVT with torque server
Clutch Automatic dry centrifugal clutch with vibration dampers
Chassis Double cradle in high strength tubular steel
Front Suspension 41 mm diameter hydraulic telescopic fork with straight stanchions and set-back pin (122 mm wheel vertical travel)
Rear suspension With laterally mounted, horizontal, hydraulic monoshock. Seven-position spring preload adjustment.
Front brake Double, 300 mm semi-floating stainless steel discs with two Brembo double piston 28 mm floating callipers.
Rear brake 280 mm Ø stainless steel disc and 25.4 mm Ø double piston calliper
Braking system management ABS system with two separate channels.
Front wheel rim Aluminium alloy 16" x 3.50
Rear wheel rim Aluminium alloy 15" x 4.50
Front tyre Tubeless 120/70-R16" - 57H
Rear tyre Tubeless 160/60-R15" - 67H
Length/Width 2.237 mm / 790 mm
Wheelbase 1,593 mm
Seat height 780 mm
Fuel tank capacity 18.5 litres
Dry weight 249 kg
Emissions compliance EURO 3
a cena...pa preko 8k evra.
#2 perlx*
Posted 05 February 2012 - 22:10
Razbusena gilera gp800 sa drugim plastikama.
