Aprilia SR
minarelli lc
13 replies to this topic
#1 milosr6t
  • 6 posts
  • VozimAprilia SR
Posted 29 April 2013 - 13:52
Kupio sam Apriliju Sr 2000g, u losem stanju, skroz rasklopljenu, stajala mi je godinu dana tako, zato sto nisam imao vremena da je sredjujem. Pre mesec dana sam krenuo da je sredjujem i to sad hocu da podelim sa vama.
Evo i slika:
Uploaded with ImageShack.us
Na Apriliji ce biti sledeci setup:
- Strage6 Racing Modular
- Stage6 R 1200
- Stage6 TM 24mm
- Stage6 boost bottle
- Stage6 double layer
- Stage6 karbonske lamelice
- Hebo Hpc
- Stage6 iglicasti
- SKF C4
- Stage6 Sport pro (variator)
- Stage6 MK II (kvacilo)
- Stage6 R/T (korpa k)
- Motoforce kevlar
- Motoforce (plocice kocnica)
A od styling delova:
- Str8 korman
- Str8 drzac kormana
- Str8 F1 retrovizori
- PM Fire Style (kurbla)
- Motoforce brza rucica
- Str8 podzac amortizera
Attached File  4.jpg   103.96K   62 downloads Attached File  5.jpg   83.47K   60 downloads Attached File  6.jpg   74.26K   44 downloads
Attached File  7.jpg   111.46K   37 downloads Attached File  8.jpg   71.7K   37 downloads Attached File  9.jpg   102.06K   37 downloads
Attached File  DSC_0318.jpg   97.51K   32 downloads Attached File  DSC_0321.jpg   66.28K   44 downloads Attached File  DSC_0322.jpg   81.91K   68 downloads Attached File  DSC_0323.jpg   79.87K   63 downloads
Polako je krenulo sklapanje:
Attached File  DSC_0329.jpg   154.74K   51 downloads Attached File  DSC_0332.jpg   163.79K   46 downloads Attached File  DSC_0334.jpg   144.04K   41 downloads
Edited by Pita, 29 April 2013 - 18:38.
#2 milosr6t
  • 6 posts
  • VozimAprilia SR
Posted 29 April 2013 - 14:03
Svi komentari i saveti su dobrodosli !! :)
#3 Nesa BG
Posted 29 April 2013 - 14:17
Imam samo jedno pitanje: koju si banku opljackao hahaha. Salim se, bice ljuta masina.
#4 milosr6t
  • 6 posts
  • VozimAprilia SR
Posted 29 April 2013 - 15:15
Hahaha :) 2 godine sam skupljao delove za ovu ljutu masinu! :)
doslo je do prvih problema,izgubio sam : - bolcnu koja ide pre mehanizma alnasera(odma do semeringa)
-2 mala dihtunga glave od recinga (crvena)
Ne znam sta sada da radim? :)
#5 Boza
Posted 29 April 2013 - 15:19
Опасан попис делова. :)
#6 Pita
Posted 29 April 2013 - 18:43
bolcna se da napraviti samo ako imaš dimenzije, a dihtunge treba kupiti...Nikakvi veliki problemi...
Vidim da su neki ležajevi već u blokovima, jel su to novi C4 ili stari?? pitam zato što vidim da nisi otvorio blokove prema cilindru a ležajevi su već unutra??
jel imaš čime da ušteluješ taj TM24, dizne,igle,pilotke??
#7 Alexandar :D
  • 738 posts
  • MestoPancevo
  • VozimV-Max 1200ccm
Posted 29 April 2013 - 21:31
TM24, onaj C16 i bost b. je od mene uzeto :)
TM24 je dosao komplet sa diznama od 100 do 140,kao i sa 3 pilotke.A igla ima 5 stepeni stelovanja tako da ne treba druga,bar meni nije trebala :)
#8 Sloba15
  • 421 posts
Posted 29 April 2013 - 22:33
Oho taj R1200 je kod mene bio jos davno :D Sklapaj polako,nigde ne zuri,nego gledaj da sve bude kako valja!
#9 Mikac93
  • 1,554 posts
Posted 29 April 2013 - 22:50
Popis delova na nivou... Svaka cast
Posted 30 April 2013 - 00:23
aha moj TM24.. i Ste**n R1200...kako je počelo još će se po neko prepoznati...
čija je radilica i onaj modular S6
#11 milosr6t
  • 6 posts
  • VozimAprilia SR
Posted 30 April 2013 - 02:28
@pita : uzeo sam nove c4 lezajeve,nisam znao da treba da otvorim blokove za racing,radilicu sam ubacio ublokove pa sada ne znam da li da ih opet rasklapam?Hteo sam da sklepam apriliu samo da bi je upali do 1.maja ali sam se sada pokajao :(
@Mario: radilica mi je stigla nova iz nemacke a sto se tice modulara,imam 2 s6 racinga jedan je modular a obican,modular ima dvar risa a ovaj obican je u extra stanju jos naturpijan tako da sam od ta 2 sklopio jedan koji valja :D
-Da li pasu dizne od TM24 na R/T 24mm?
-Greskom mi je stigao malossi multivar za morini,na njega pase pase bolcna i poklopac od s6 sport pro-a,da li mogu tako da vozim ili ne?
#12 bojan681
Posted 30 April 2013 - 09:24
Ma menjaj multivar, trebao si mozda cak uzeti onaj overrange za taj setup. Nemoj da zuris, vozi onog ekzeklija ako ga jos imas a ovog polako sklapaj...
Posted 30 April 2013 - 09:57
dizne od Stage6 TM karburatora su Mikuni tipa, tako da moraš prepoznati šta stage6 podrazumeva pod R/T, oni rade i Keihin-e i Dellorto.. pa u te tipove neće odgovarati
#14 ALIEN SM
Posted 30 April 2013 - 10:11
Hehe, bice to porodicna masina, sve ostaje u porodici...
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
