Porting Calculator v3.5.7
No replies to this topic
#1 sinisa93
  • 1,551 posts
  • MestoPrnjavor
  • VozimPiaggio NRG Power DT
Posted 25 July 2015 - 21:03
Listajuci tako po stranim forumima naletim na stariju besplatnu verziju ovog programa, koji se inace moze kupiti u paketu sa Portmap Analyzer-om. Nisam bas pohvatao sve mogucnosti i funkcije programa, pa se nadam da ce neko od iskusnijih clanova da malo bolje to pojasni. Evo sa njihove stranice, copy paste:
Program features:
  • -Calculates port heights from durations, or port durations from port heights
  • -Assign fixed relationships between transfers and exhaust port. Enables all transfer
    port heights to be calculated automatically by just entering exhaust timing
  • -Exhaust and main transfer timing can be entered by mouse click on graph, or typed in
  • -Calculates required ranges of Jennings or Blair angle areas, mean areas and time areas
  • -Adjustable graph rpm scale: 7k scrollable range, adjustable from 1k to 18k
  • -Calculates possible ring flutter rpm
  • -Mean piston speed
  • -Suggests carburettor size
  • -Power meter (you input expected bmep value). Switch between PSI & HP, or BAR & kW
  • -Port design in separate cad window: enter shape values, or drag port cursors
  • -Limitations on CAD: Single exhaust port, single boost port
I evo link za download:
Attached File  Porting Calculator v3.5.7.zip   4.42MB   37 downloads
