Ubrzanje 0-60km/h ...Video edition...
41 replies to this topic
Posted 03 March 2011 - 14:47
Sprint Falcon 50cc stock
motor - cca 110kg
vozač 125kg
0-20-21 = dakle 20sec
Sprint Falcon 50cc tuned
motor - cca 110kg
driver - 70kg
0-60kmh = 10sec ravno po satu
12-2 na snimku
#2 LiMa
  • 237 posts
  • Mesto011
  • VozimGilera Runner 49
Posted 03 March 2011 - 16:19
Gilera RunneR 50
-Leo ZX, lakse rolne, tvrdje opruge
Motor 110kg otprilike
VOzac 60kg
Tacno 10sec do 60km/h
#3 Megasp
  • 247 posts
Posted 03 March 2011 - 18:12
Skuter pedah7 ili kako vec
Vozac 105
skuter 110 tu negde
0-60 nekih 11 s
Neki snimak od ranije sa trekom laksim rolnicama i oprugom tvrdjom.Snimak je 16s krecem na 4 sec i zavrsavam na 15s znaci nekih 11s.50cc
#4 Rade
  • 454 posts
  • MestoApatin
Posted 03 March 2011 - 23:38
Peugeot Vivacity - cista serijala.
Motor - oko 90kg
Vozac - 80kg
0-60kmh = 12-13sec
Peugeot Vivacity - serijala + giannelli extra.
Motor - oko 90kg
Vozac - 80kg
0-60kmh = 9sec
Peugeot Vivacity - malossi sport + giannelli extra.
Motor - oko 90kg
Vozac - 80kg
0-60kmh = 6-7sec
Peugeot Vivacity - Athena Sport 70cc AC, Yasuni R...
Motor - oko 90kg
Vozac - 80kg
0-60kmh = 5 - 5.5sec
Peugeot Vivacity - Malossi MHR Replica LC, Yasuni R...
Motor - oko 90kg
Vozac - 80kg
0-60kmh = 5sec
Posted 04 March 2011 - 00:30
Arpilia SR1, MHR Team 77cc, Roost Sprint..
Skuter - 86Kg
Vozač - 125Kg
0-60 8s , . sledeći put držim volan sa dve ruke obećavam...
Posted 04 March 2011 - 00:32
Keeway Matrix - Madness
Stage6 racing, Yasuni C20
Skuter - 95Kg
Vozač - 125Kg
0-60 - 5,5-12 = 6,5s brzina je GPS
#7 Pita
Posted 04 March 2011 - 12:29
Peugeot Jetforce, Malossi Sport sa Stage6 pro auspuhom...
Skuter - 115Kg
Vozač - 85Kg
0-60 8s
Posted 04 March 2011 - 16:34
Beneli 491 - mare666
Athena Sport, Tecnigas Trek, YSN PHBG 19mm
motor oko 90kg
vozač ubedljivo 125kg
6-12 dakle cca 6s po tom popularnom beneli satu
Posted 04 March 2011 - 16:38
Kymco Exciting 500 stock
motor oko 120kg
vozač 125kg
2-7 dakle oko 5s nisam krenuo iz mesta
#10 Boza
Posted 03 April 2011 - 20:57
Keeway Fact
Home-made rezona
3.0g rolnice, jace oprugice, sabnica ispred ventilvara
Uzmite u obzir da je pravih 60 na 75-80...
Nekih 16 sekundi ako se ne varam...
Posted 03 April 2011 - 21:42
Keeway F-Act 70
Motoforce alu racing, Arreche 19, Stage6 pro replica, +15% stage6 primar, Naraku racing vario...
vozač 125Kg, nisam merio od 0-60 već maksimalu.... sat bi trebao da pokazuje za 4 više od GPS-a, tako je do 81, ovamo gore moram još proveriti
#12 stefke_the_doctor
  • 23 posts
  • VozimMalaguti F15 Firefox
Posted 29 July 2011 - 02:50
Qingqi a-10
motor-90 kg
vozac-64 kg________________
-Potpuna serijala...cackao sam malo prenos-dodavao sajbnice,stavio nov kajs (serijski njegov),skinuo sam onaj metal koji drzi zadnju kalotu varijatora da ne moze da se skine,...
-Posto se pomalo taloze cestice cadji na izduvnom kanalu zbog full-synth ulja,biax-om sam sredio izduvni kanal...
-Sipano ulje Repsol Moto 2T,gorivo klasican BMB 95...
-Znaci 0-60 km/h izmedju 12 i 13 sekundi....
#13 Miroslav'91
  • 530 posts
  • MestoAleksandrovac-Bg
Posted 29 July 2011 - 15:32
Sprint exactly
Malossi sport 70cc
Tecnigas Next-R
Motoforce kvacilo
Malossi multivar, 4,7g rolnice
Nelimitirani CDI - by Icatenej
Od 0 do 60 negde oko 6-7 sekundi. Dobro je pocupao jer je bio hladan motor, a kad se ugreje obicno ne cupa ovako dobro. Moracu sto pre da izbusim deklu
#14 Boza
Posted 27 June 2013 - 17:53
Streetrace + TREK + Mikuni 16 + Naraku racing + Malossi primar..
0-60 (75 по сату је правих 60) - 8 секунди
#15 goggyso
Posted 16 July 2013 - 04:37
aprilia sr50r factory PureJet 49ccm
0-60kmh = 11s ali start nije sa punim gasom zbog upravljanja jednom rukom.
Seriala, osim auspuha, stavljen sc08, piadjov original kais i plave opruge na kvacilu, a ja oko stotke kg, sa dobrim bocnim vetrom na deonici sa malo uzbrdice, malo ravno. I zadnja guma 140/60/13
Edited by goggyso, 16 March 2015 - 11:48.
#16 cvele
Posted 20 October 2013 - 21:37
Ajd da se i ja upisem ;) Sve iz potpisa,ja 90kg, tem. spoljna oko 22*,tiho bez vetra... Kamenko K. jbt :) Snimak je malo duzi al YT ga nesto tupi na ne mogu da ga "obradim" i skratim...0-60 oko 7sek. do 0-80 oko 10sek...itd...ima malo "prevrtavanja'' pa uskoro sledi snimak sa malo tezim rolnicama...zahladilo pa se centralna dobro drzi ...
#17 NipeNRG
  • 12 posts
Posted 23 October 2013 - 15:54
Piaggio NRG Extreme, totalni stock, samo skinuta blokada sa varijatora.
0 - 60 po satu 13sec
Videcu ovih dana da uradim jos jedan, psoto je pala rezona :)
#18 Grale
  • 1,500 posts
  • MestoKC
  • VozimDitech
Posted 23 October 2013 - 19:20
Aprilia Sr ditech:
Setup:Malossi sport, Malossi ECU, Polini variomat, ZX, Malossi special remen(ja mislim da je onda bio), rolice neznam koje su bile.
Getriba serijska.
Vanjska temperatura oko 30-35, temp. motora oko 65 C.
0-60 cca 7 s(po satu), 0-60 cca 10 s (realnih).
Vozač cca 100 kg čistih mišića :)
Ovako je to izgledalo sa serijalom(Samo zx i Polini variomat):
Kilaža ista(redovno vježbam pa zato :) )
Temp vanjska rekao bih oko 20 C, motora radna(nekih 55 možda).
0-60 cca 12 s (po satu), 0-60 cca 16 s (realnih)
Da napomenem, svi videi su snimani u normalnim uvjetima, znači bez vjetra u leđima, bez naginjanja, glumljenja Rossija i ostale rejserske fore, jer se tako inače ni ne vozim :)
Edited by cvele, 23 October 2013 - 20:15.
#19 Stefan p
  • 1,132 posts
Posted 12 November 2013 - 19:32
  • Skuter:Sprint Exactly
  • Termogrupa:Top perfomance Tropy 70ccm
  • Radilica:fabricka
  • Auspuh:PInasco Power sound
  • Usis:fabricki
  • Karburator:Tekei 16mm
  • Varijator:Malossi multivar
  • Remen:Techno M
  • Kvacilo:Malossi fly
  • Zvono:fabricko
  • Prenos:fabricki
Od 0-60 po satu 8sec, a po gps 9sec.
Vozac: 75kg
#20 Mario
Posted 29 November 2013 - 19:09
Yamaha Aerox
termogrupa stock, variomat, kvačilo, remen stock, kabrurator dellorto 17,5, Airbox, Bullet GP ...
vozač cca 120kg moja malenkost
exclusive test video 0-60 10s (3-13)
