Kočione pločice
23 replies to this topic
#1 Cvija
  • 129 posts
Posted 10 March 2011 - 20:04
Veoma bitna stvar.Nekome traju dosta dugo,neko ih opet pojede za 2000-3000 km,sve opet zavisi od stila vožnje.Ono što je važno jeste da imamo 3 tipa pločica 1-Organic (mekane)2-Semi synthetic(srednje tvrdoće)3-Synthetic(tvrde).Ove prve se najbrže troše i najmanje 'jedu' disk,a synth.opet traju ali i troše disk.Ovo bi mogao da bude uvod,neka neko proširi malo....
#2 Rade
  • 454 posts
  • MestoApatin
Posted 10 March 2011 - 22:14
Naravno, zato postoje jeftiniji i skuplji diskovi jer je veoma bitno od kog materijala se prave.
Svakako za sinter plocice treba disk od kvalitetnog nerdjajuceg celika:
http://en.scooter-at...6l%3Dnavigation
Obicni disk:
Vidi se i razlika u ceni..
Po meni je bolje stavljati kocione plocice od mekseg materijala, jer opet bolje sa vremena na vreme i plocice promeniti, nego disk menjati koji je dosta skuplji od plocica.
Posted 26 May 2011 - 09:21
pojašnjenje razlike tipa kočionih pločica, hvala EFZ-u
Organic - are made from organic resins and fibers. They are good for recreational use as its bite is not that strong and they don't like rain or mud. Generate very little heat and that makes them desirable for some systems specially closed system hydros which don't hadle well thermal expansion of the fluid. Its life is rather short.
Semi-Metallic - offer very good braking power, low squeal, medium heat generation and medium lasting. A very good all-around pad. Some would say those are the best. As an example the Hayes pads are venerated as one of the best out there and they are semi-metallic. Made from a resin material with metal (copper, brass) chips inclusions.
Sintered - fully metallic, made out from low melting point metals powder (again, copper and brass alloys) by pressing them at high temperatures. These are the longer lasting, most powerful brake pads... the tradeout is that they squeal rather easily and generate a lot of heat which can be bad for some hydro systems. They cut thru the mud too.... but also some will wear pretty soon under wet (depends on the manufacturer).
#4 cvele
Posted 26 May 2011 - 15:28
Organsko - izrađeni su od organske smole i vlakana. Oni su dobri za rekreativno korištenje kao ugriz nije toliko jaka i ne poput kiše ili blata. Generirati vrlo malo topline, te da ih čini poželjnim za neke sustave posebno zatvoreni sustav hydros koji ne hadle dobro termičke ekspanzije tekućine. Njegov život je vrlo kratak.
Polu-Metalni - nude vrlo dobre sile kočenja, cika nisko, srednje topline i medij trajan. vrlo dobar all-around jastuk. Neki će reći oni su najbolji. Kao primjer Hayes jastučići su štovana kao jedan od najboljih vani i oni su polu-metalik. Izrađen od smole materijala s metalnim (bakar, mjed) čips inkluzije.
Sinterovani - potpuno metalno, izrađena iz niskog tališta metala u prahu (opet, bakar i mjed legure) ih pritiskom na visokim temperaturama. To su dugotrajne, najmoćniji kočnice jastučići ... tradeout je da se cika prilično lako i generirati mnogo topline što može biti loše za neke hidro sustava. Oni rez kroz blato previše .... ali i neke će nositi uskoro u vlažnim (ovisi o proizvođaču).
#5 plameni
  • 1,591 posts
Posted 24 March 2012 - 09:10
Ove plocice pasuju na keeway hurrikan model od 2008 godine i na ostale kiwice koji imaju istu kandzu.Modeli ispod 2008.godine
nose ovakav model plocica
Postavio sam ovo za clanove koji voze keeway skutere pogotovo za modele od 2008.godine jer je jako tesko naci brendirane plocice za tu kandzu koju su kinezi stavili od 2008 godine pa nadalje.
I paknovi od aprilije SR,guliver
Ovi Paknovi pasuju na sve kineze sa kopijom minareli bloka
Edited by Plamenni, 24 March 2012 - 09:11.
#6 cvele
Posted 24 March 2012 - 14:33
Ajd i video oko montaze kad smo vec oko plocica...a i kociona klesta su ko moja...
#7 Mikac93
  • 1,554 posts
Posted 22 January 2013 - 21:13
Ljudi moze li mi neko naci oblik plocica za Piaggio NRG MC2 1997. godiste,kod mene su menjane,ali ja taj oblik ne mogu da nadjem nigde,izgleda da nisu za taj model,evo kakve su sad,googlao sam ali nisam uspeo da nadjem:
Hteo sam da uzmem ove ali nisu iste,pa nzm da li bi mogao da ih stavim:
http://shop.motobike.../prod_2326.html
#8 cvele
Posted 22 January 2013 - 21:24
Mikac premeri dimenzije da znamo sta da trazimo....i slikaj to malo bolje... ;)
edit -probaj da nadjes ovde - http://www.rms.it/pr...hoes-24-c-m.htm
#9 Mikac93
  • 1,554 posts
Posted 22 January 2013 - 21:33
Dimenzije su:
Sta jos treba da slikam,vidi se ovo,malo mutno al jbg...
Cvele ja ne znam da li su ovo pakne za njega,jer na ovom skuteru radjeno sve preko K**ca,da su mogli stavili bi i motor od juga na njega...
Edited by Mikac93, 22 January 2013 - 21:35.
#10 cvele
Posted 22 January 2013 - 21:43
skini ovaj pdf
http://www.rms.it/do...iglie-freno.pdf
....mislim da su prve na listi bas tvoje,zapisi fab. kod pa po njemu trazi...
#11 cvele
Posted 22 January 2013 - 21:50
ove...
#12 cvele
Posted 22 January 2013 - 21:51
http://shop.motobike...prod_13136.html
#13 Mikac93
  • 1,554 posts
Posted 22 January 2013 - 21:57
Ove prve jesu iste,i dimenzije su iste,e sad jos samo da nadjem malossi za njega i na konju sam... Hvala ;)
#14 cvele
Posted 22 January 2013 - 21:58
View PostMikac93, on 22 January 2013 - 21:57, said:
Ove prve jesu iste,i dimenzije su iste,e sad jos samo da nadjem malossi za njega i na konju sam... Hvala :D
http://shop.motobike.../prod_2316.html
;) imas i skuplje iz MHR serije...
http://shop.rollerla...ossi-Sport-9097
#15 Mikac93
  • 1,554 posts
Posted 22 January 2013 - 22:09
E Cvele svaka ti cast,hvala,imas pivo ;)
#16 cvele
Posted 22 January 2013 - 22:20
;) evo radim na njemu :D
#17 steva85
  • 198 posts
  • Mestozemun
  • Vozimkymco super 9
Posted 27 January 2017 - 18:31
da se ozivi tema
kupio sam za prednji tocak paknu od ..rms... firme :) ajde neka iskustva,negde sam procito da su krs a neko ih hvali....i odma dilema u glavi
procito sam da moze pakna da pukne i da se polomis sa skutera :rolleyes:
da li su ..rms pakne krs :1kokice:
#18 Lauda
Posted 27 January 2017 - 18:42
Obicne kineske pakne. Dosta vise habaju disk zbog smese.
#19 Depe
  • 1,239 posts
  • MestoNew York
  • VozimAprilia sr 50 2006.
Posted 27 January 2017 - 18:47
Nisu vrhunski kvalitet ali nisu bas toliko lose da su ne bezbedne. Tacno je da disk brze trose. Ako ti je skuter serijski i ne postizes vece brzine bice ti sasvim dobre i zavrsavace posao.
Послато са SM-J500F уз помоћ Тапатока
#20 steva85
  • 198 posts
  • Mestozemun
Posted 27 January 2017 - 18:49
ok rms menjam u radnji uz doplatu za ulje,necu da zeznem disk
gledam na racing.pl ima samo polini pakne jel one valjaju..da ih porucim ..
aj neko iskustvo dal polini da kupim ili neke druge ;)
