Ulja za 2T motore
38 replies to this topic
Posted 30 September 2011 - 08:37
The Late Great Oil Debate
By Robert Verret
There are very few subjects that stir the emotions of PWC performance enthusiasts more than to ask, what 2 stroke oil do you use and why? This site has dedicated more ‘bandwidth’ to this subject than just about any other topic. Most of the discussions end up in heated debate with no one really changing anyone else’s mind on what oil is the best anyway. We tend to vehemently defend our choice as if our very reputation depended on it. I sometimes think we are more loyal to our favorite brands of oil than to our favorite brand of ski (hopefully Sea-Doo). Well, maybe we’re not quite that loyal to our oils, but close to it. If it’s any consolation, PWC performance enthusiasts are not the only group of “motorheads” that staunchly defends their choice of oil. I belong to several other performance oriented motorsport discussion groups (Ford-Diesel and Racetech-KTM) and they do it also. With all this said, let’s all take a deep breath and put our emotions and biases in a closet somewhere and try to look at this magic miracle ‘brew’ we call 2-stroke engine oil.
What’s in the stuff anyway?
2-stroke engine oils, like most other engine and gear lubricants, are composed of base oil plus an additive package. The additive package can be as simple (only one or two components) or as complex (multiple components), depending on the requirements of the oil.
Base Oil Types
Base oils compose from 50% to 95% of the total weight of the 2-stroke engine oil. They fall into 2 general categories: synthetic and petroleum based. There is a third category, vegetable, I will discuss later. Since synthetic oils are manufactured from petroleum, there has been a lot of litigation flying around about what really constitutes a ‘true synthetic’ oil in the last several years. There is no universally accepted definition for synthetic oil. Each manufacturer is free to label their product ‘synthetic’ by whatever rules the manufacturer chooses. The API (American Petroleum Institute) has defined base oils into 5 different grades or groups rather than use the terms synthetic and conventional (petroleum). The groups are classified by quality of their VI (viscosity index). The VI is a relative measure of the base oil’s ability to not thicken at low temperatures and not thin out at high temperatures. The higher the VI number, the more resistant the oil to changes in viscosity as its temperature changes. Perfect base oil would have no viscosity change at all with temperature change. Some silicone-based oils have extremely high VI, but, unfortunately, they are terrible metal lubricants, so they can’t be considered for engine lubrication. The higher the API group number, the higher the VI number. Most, if not all, high performance 2-stroke oils are manufactured using API group III and IV and occasionally group V base oils. GroupIII (hydrocracked/hydro-treated petroleum oils) are used in non-synthetic and synthetic blends and Group IV (VHVI and PAO synthetic oils) are used in full synthetic and synthetic blends. Group V (Ester synthetic base oils) is rarely used because of their expense and they do not mix easily with gasoline and they are not compatible with some other oils. There are a number of advantages to using synthetic base oil in addition to the better VI. Synthetics have a much higher flash point than petroleum base oils.
Synthetics will not decompose as easily at high engine temperatures as petroleum. The engine stays cleaner because less varnish deposits on the power valves, ring lands and piston crown. They also transfer heat better than petroleum-based oils. In summary, it’s fair to say synthetic based oils (with the correct additive package) will out perform their petroleum-based cousins at extreme loads/temperatures. I mentioned a third category of base oils earlier, vegetable or Castor (not Castrol, that’s a manufacturer) bean oil. This oil is derived from pressing oil out of castor beans and distilling it. ‘Bean Oil’ as it is often referred to, has some very unique characteristics; some very good, others not so good. The good is that it is an excellent lubricant. It seeks out hot spots in the engine and clings to those hot surfaces much better than petroleum type oils. The bad is that it does not mix with gasoline easily and it burns ‘dirty’ (excessive carbon/varnish deposits). In the early 70s, before power valves were used, castor bean oil was very popular in racing 2-strokes. Now that power valves are common and we have improved petroleum and synthetic oils, castor bean oil is seldom used anymore. Several companies still market it in the form of a degummed castor oil for racing applications only. It should be avoided for recreational use unless you enjoy tearing your engine down for a top end cleanup fairly often. Several manufacturers formulate their oil with castor bean oil as an additive (antiwear agent) rather than base oil. They blend it with their petroleum and synthetic base oils. When castor bean oil burns, it has an unmistakable ‘sweet’ smell.
Additives
If science could develop a base oil that would not thermally decompose (burn) until 1600 deg/f and not change in viscosity for –40 to 600 deg/f and not pollute the water or air, we would not need any additives in the base oil. Wouldn’t it be nice if all the oil collected in the expansion chamber body stayed in the same pristine state it went into the engine? We could simply recycle it. Well this isn’t going to happen in our lifetime (sorry, not even you younger guys will ever see this). Lubrication science is just not there yet. Additives are combined with the base oil to fix certain faults with the base oil or stretch the limits of the base oil in some cases. Additives are complex chemicals that account for most of the cost of a bottle of 2-stroke oil. Additives for 2-stroke oils fall into several general categories: Detergent/Dispersants, Antiwear agents, Biodegradability components, and antioxidants. Since the lubricating oil must burn as part of the combustion process in a 2-stroke engine, the residue resulting from this combustion process must be swept away after each firing stroke. If not, the residue (varnish, lacquer and other heavy hydrocarbon compounds) would build up and plug the exhaust port and stick the rings and power valve(s). Detergents/dispersants must be added to the oil to prevent this problem. The two types of detergents/dispersants most commonly used in 2-stoke oil formations are Ashless and Low Ash. Medium Ash and High Ash detergents are not used in 2-stoke oils. Ashless detergents are used in low temperature applications such as TCW3 oils where the ring land temperature is held below 300 deg/f. These detergents work well in engines where an excess of cooling capacity is available and power valves are not used. Ashless detergents are manufactured form organic nitrogen compounds (Hydrazine) instead of heavy metal compounds; therefore, they produce no ash as they are burned away. This is where the name “Ashless” comes from. Oils containing this type detergent have a characteristic Ammonia odor. Ashless detergents were used in the first generation of Bombardier XPS engine oil. The formulation was later changed to a low ash type detergent because of the higher temperatures generated by the 787 engines. Low Ash type detergent/dispersants are used in most API-TC, Jasco FC and ISO GC certified 2-stroke oils. These oils are designed for air-cooled high performance engines that operate under severe load/temperature conditions. Low Ash detergents can keep the deposits to a minimum at ring land temperatures as high as 400 deg/f. These detergents are manufactured from compounds of Calcium and Magnesium (heavy metals). After these compounds (Calcium Phenate or Magnesium Phenate) do their job, they burn away, forming a heavy metal salt (ash) that is swept away during the normal combustion process. Hence, this is where the name Ash-type detergent comes from. Ash type detergents depend on the higher combustion temperatures (787 and 951 engines) to keep the resulting ash swept out. Therefore, the use of these high performance oils in outboard or other mildly tuned 2-stroke engines is not recommended. Some manufacturers are using a combination of detergent types (Ashless and Low Ash) to provide a broader range of uses for their oil. It is important to note that oil designed to meet TCW3 specs. only (Ashless) will not protect an engine requiring API-TC (Low Ash) type oil. The converse is also true. Using a Low Ash oil in an engine designed for an Ashless type oil only could result in fouled plugs and gummy combustion chambers. When 2-stroke oil is kept in its temperature limits, it provides an adequate protective film between all moving parts. When that maximum temperature is exceeded, the oil film breaks down and usually seizure occurs unless another line of defense is added to the oil mixture. These are the Antiwear agents. These Zinc compounds (Zinc Dithiophoshate) flow in with the oil and are never used unless the base oil breaks down. If the base oil breaks down, they form a protective barrier between the moving parts (usually piston skirts and cylinder walls).
Since all 2-stroke engines partially burn and expel their lubricant in the exhaust, the resulting exhaust residue must be rendered harmless to the environment (air, water and land). All 2-stroke oil intended for marine use and many intended for land recreational use contain Biodegrading agents. These complex chemical compounds allow the microbes found in water and in the soil to consume the hazardous chemicals and oil from the exhaust as they fall in the water or on the ground. These Biodegrading agents do nothing for the performance of the oil (sometimes they even hinder it), but they help assure us that 2-stroke engines will be around for a while. As you can see, 2-stroke oils are a mixture of many different complex chemicals with base oil. Each specialty chemical has a job to do. Care must be taken to assure that these different chemicals detergents/dispersants, Antiwear agents, and Biodegrade agents) do not react or interfere with each other or otherwise impair the function of any other additive. Antioxidants are chemicals that reduce the chance of reaction between the various additives in the oil mixture. They effectively extend the ‘shelf life’ of 2-stroke oils.
What does ATP-TC and TCW3 mean?
Specifications for 2-stroke oils are developed from the design of the engine and its intended use (no surprise). Since this type engine has a wide variety of applications its no surprise that the specifications for the oils might vary also. For marine and PWC application there are 2 widely accepted standards for certifying 2-stroke engine oils. These are, by no means, not the only standards for 2-stroke engine oils. The European (ISO) and the Japanese (JASCO) standards have been developed, but these standards are not widely accepted in the country (yet). The standards most used in this country are the National Marine Manufacturers Association (NMMATCW3) standard and the American Petroleum Institute (API API-TC) standard. Both of these standards address the oil ability to prevent wear, keep the engine clean and biodegradability. Since these standards were written for different types of 2-stroke engines it stands to reason these standards would be different. Hence, the oils developed from these standards would also be different. The NMMA TCW3 standard was designed by the various manufacturers of outboard motors (Mercury, OMC, Yamaha etc.). These manufacturers so not utilize power valves, limit their max rpms to about 6800 and have excessive cooking capacity. They also must be able to operate at lower rpms for long periods of time without oil fouling the spark plugs. Although it’s true the performance of this type engine has increased in the last several years, the peak engine temperatures are still relatively low. The use of synthetic base oil in TCW# formulations has extended the useful range of these oils; their detergent system (Ashless) is designed for lower operating conditions. This is one of the reasons Bombardier specifically prohibits the use of these oils in their Rotax engines. The API API-TC standard was developed for Air-cooled, high rpm, high output 2-stroke engines operating under severe load conditions. Although this standard is no longer reviewed and updated since 1993 b the API, it still is in effect today. This standard most accurately addresses the condition Rotax and 2-stroke racing motorcycles and snowmobiles operate under. Almost all these oils are formulated with synthetic or synthetic blend base oils and all use a low ash type detergent. If you walk into a store that handles a variety of 2-stroke oils, it is relatively easy to find TCW3 certified oil. The manufacturer proudly displays that certification on each container. API-TC certified oils, on the other hand, are very difficult to find. There are two main reasons for this. First, many small API-TC oil manufacturers can’t or won’t spend the money (about $75,000) for the testing and certification process. Second, most engines requiring API-TC oils are for racing applications (Motocrossers and Crosscountry motorcycles) and don’t offer warranties with their engines anyway. The owner/operators of these machines know what oils work and don’t work. They do not need the API-TC certification on the bottle to help them decide what oil to use. There are many really good API-TC type oils on the market that have never been certified as such. Bombardier/Rotax is the only manufacturer that API-TC certified oils. The TCW3 market is about 10 times the size of the API-TC market. Outboard motor manufacturers require the use of TCW3 certified oils to maintain their warranty. With this great volume in oil sales at stake, it’s easy to see why TCW3 manufacturers can afford to certify their oils.
Rotax’s Position on What Oil to use
As we all know, Bombardier requires that an API-TC oil be used in their engines. Most other PWC manufacturers allow the use of TCW3 in their engines. So, what’s the difference? A PWC is a PWC, right? No, it’s not! Rotax marine engines evolved from their very successful snowmobile and motorcycle racing designs. These engines produce more power/cc than any other PWC manufacturer’s engine. Rotax designs these engines to work harder and run hotter than other brands. They simply need more protection than TCW3 oils can give. Those that use TCW3 oils are risking high temp. Seizure if the engine cooling system plugs or and internal fuel filter plugs (lean condition). These things may not happen very often, but when they do, it’s better to have a little extra protection that only a TI-TC oil can give.
So, what’s the best oil to use?
I truly believe there are no bad oils anymore (well, maybe a few really cheap ones are not so good). Most problems with oils are the result of misuse. I had a friend once that insisted on mixing STP with his premix. He swore his motor made more bottom end with STP in the fuel. Well, it may have, but he invested considerably more $$ in spark plugs than just about anyone else on the planet. He was also responsible for single handedly stunting the growth of the entire mosquito population in southeast Texas (thank God he quit riding). I hear a lot of complaints about the high cost of some 2-stroke engine oils, mostly Bombardier XPS. Well, I have to agree, it isn’t cheap, but neither are any of the other API-TC oils compared to the TCW3 type oils. Unfortunately it just costs more to manufacture API-TC oils than TCW3 oils. Despite its relatively high cost, I cannot recall any Rotax engine failing because of XPS oil. XPS oil was a joint development of Castrol and Bombardier. Bombardier wanted a ‘universal’ high performance engine oil that they could use in all their recreational products. That meant oil would flow freely at –40 deg/f and still maintain sufficient film strength at 350 deg/f. The first generation of XPS (1995) was formulated using Ashless detergents; this allowed the Rave valves in the then new 787 motor to stick. The formula was later changed (1996) to a low ash detergent that eliminated the rave valve sticking problems. There have been several minor improvements in XPS since 1996. Castrol remains the only manufacturer of XPS. This is a proprietary blend sold only by Bombardier.
There are a number of good API-TC type oils out there if you chose not to use XPS. If the oil you want to use does not have the ATP-TC certification on the container, contact the manufacturer. Most of them will be more than glad to provide you with information on their products.
Decisions, Decisions!
Well, I hope I answered most of your questions concerning 2-stroke engine oils. I’ve tried to keep brand names and my personal biases out of it so far. However, I, like you, have an opinion. My opinion is based on my 30 years experience working with 2-stroke motors and my relationship with some very knowledgeable people involved in lubrication research. I work for the world’s largest manufacturer of oil additives. We make the additives for virtually all the oil retailers.
Now having said that, here are my recommendations. If you have a Sea-Doo PWC that is still in warranty: Stay with XPS or XPS-DI. Sure there are API-TC certified oils that should preserve your warranty, but in an engine failure the dealer could cause you grief getting your PWC warranted. In my opinion, it’s just not worth the hassle to do battle with them. Stay with the XPS at least until the warranty expires. After the warranty expires, select API-TC oil that carries the certification or confirm in writing the oil you want to use is designed for your PWC. Then find someone else that uses the oil you are considering and get his or her opinion. Do not use TCW3 in your SeaDoo PWC. I don’t care if it’s a full synthetic or your brother-in-law uses it; for the reasons stated above, it will not protect your motor when conditions get tough in your motor.
Choose well, Grasshopper, the life of your motor depends on it!
#2 duki996
  • 59 posts
  • MestoNis
  • VozimPEDA Gatto
Posted 12 April 2013 - 18:19
Koje je najbolje ulje za lamele za automatika?
#3 tuningfanatic
Posted 14 April 2013 - 16:45
Ulje za automatske menjace - Modrica Matic ATF Tip A Suffix A ili FAM ATF Tip A suffix A. Fabrika preporucuje i Valvoline TASA Tip A suffix A, ali ga je tesko naci.
Edited by tuningfanatic, 14 April 2013 - 16:48.
#4 ALIEN SM
Posted 25 November 2013 - 12:36
Alien trazi ulje, a kraj sezone...odem po prodavnicama da vidim sta ima, a ima samo preskupi Motul...Posto mi ne pada na pamet da dajem tolike pare za to, ostavio sam to na cekanju...bio sam sasvim zadovoljan dvotaktnim Valvolinom , ili Mobilom , s pocetka sezone to je kostalo oko 580,00 din, a sad je trgovcima ostalo samo ono skupo, iz razumljivih razloga zasto, a kraj sezone pa nece uvoziti...
Sasvim slucajno juce bio na poslovnom putu , pa u Indjiji resim da obidjem neke prodavnice , nikad se ne zna gde sta mozes naci ...i posle nekoliko uzalud obidjenih naidjem u jednoj ono sto treba...francuski TOTAL , nacrtan skuter na njemu , sintetika , zadovoljava JASO FD standard kvaliteta ( za kitovan motor najmanje FC ) , znaci moze i bolje, al ` ne bi trebalo slabije...cena dobra 600,00 din , boja zelena...e, bas sam srecan sto sam ovo nasao , kad sam stigao odmah sipam , stalo 9 dcl, dobra susa je bila u cantri za ulje ...eto, moze se naci i s kraja sezone dobro ulje po nekoj normalnoj ceni ...
#5 Stefan p
  • 1,132 posts
Posted 25 November 2013 - 15:26
Eto ja sam koristio ovo motulovo skupocijeno pa je lijepio ne kazem da je zbog ulja,vec zbog mojih pocetnickih gresaka kod stelovanja karba na pocetku,al sad znam gdje sam grijesio.
#6 cvele
Posted 25 November 2013 - 16:42
View Posttuningfanatic, on 25 November 2013 - 15:21, said:
Gde moze da se pogleda tabela kvaliteta ulja i po kojim parametrima se gleda? Jel ima uticaja gustina ulja na kvalitet podmazivanja?
Ne treba se time mnogo zamarati...kupis,natocis i ne mislis.... :raz_044: ili googlas pa citas,citas...
https://www.google.r...a:sr%3Aofficial
#7 ALIEN SM
Posted 25 November 2013 - 19:24
U principu , nema losih ulja, samo treba uzeti za onu namenu za koju jeste...preskupa ulja treba zaobilaziti , a ja sam sipao sve sto se prodavalo i ni sa jednim nisam imao problema da bi rekao da je zbog ulja...najjeftiniji je bio ESSO , on se vise ne proizvodi , a neka srednja klasa je upravo taj polusinteticki MOBIL I VALVOLIN...
Serijski motor ce biti sasvim zadovoljan sa onim uljem koje nosi oznaku JASO FB, to je japanski , azijski standard kvaliteta i to je uglavnom mineralno ulje , dok ono koje nosi oznaku JASO FC je polusinteticko ( mada sam nailazio i na cisto mineralno sa ovom oznakom ) to je ono koje bi trebalo uzimati i za serijale , a narocito za turpije...dakle , kad se kupuje ulje kupimo ono koje pise najmanje polusintetik u JASO FC standardu kvaliteta , a ako se naleti na sintetiku za slicne pare kao ja, to je u JASO FD standardu, moze se i to uzeti ...moze u boljem standardu , a ne bi trebalo ( bez preke potrebe ) uzimati u losijem standardu...gustina nas se ne tice , valjda oni znaju sta i kako rade , u principu dvotaktna ulja su redja po viskozitetu, u krajnjem slucaju sve to benzin razredjuje...sipas i ne mislis ,,,,
#8 Nesa BG
Posted 27 November 2013 - 13:19
Gustina ulja je bitna ako ga mesa pumpa, kod direktnog sipanja u benzin nema nekog uticaja.
#9 ALIEN SM
Posted 29 January 2014 - 13:19
Prevod o motornim uljima 2-T...
Ajd, probacu da prevedem ovu temu u duhu naseg jezika , posto je Google- ov prevod budalastina ...neke nebitne delove cu mozda izbaciti ...
Kao i kod vecine ulja tako i kod 2-T ulja sastoje se od BAZE ulja i paketa ADITIVA koji mogu biti jednostavni i sastojati od jednog ili dva , ili od vise njih , u zavisnosti od zahteva ulja ...
Bazna ulja se sastoje od 50-95 % od tezine ulja , a postoje dve vrste SINTETICKA i na bazi nafte ( MINERALNA ) Postoje i mesana o kojima ce reci biti kasnije ...buduci da su i sinteticka ulja proizvedena iz nafte, tokom godina bilo je mnogo polemika o tome sta su zapravo prava sinteticka ulja . Ne postoji opsteprihvacena definicija sintetickih ulja , pa svaki proizvodjac moze slobodno da oznaci svoj proizvod kao sinteticka ulja bez obzira na neka pravila ...API ( americki petrolejski institut ) je definisao bazna ulja u 5 razlicitih grupa i one su klasifikovane po VI ( indeksu viskoznosti ) , a on predstavlja sposobnost ulja da se ne zgusnu na niskim temperaturama i ne razrede na visokim ...sto je veci VI ulje je otpornije na promene temperature ...savrseno bazno ulje ne bi menjalo svoj viskozitet na svim temperaturama ...neka silikonska ulja imaju savrsen VI , ali nisu pogodna za podmazivanje motora ...vecina , ako ne i sva ulja za visoke perfomanse 2-T motora , proizvedene su po API klasifikaciji grupe 3 i grupe 4 , a povremeno i grupe 5 baznih ulja ...grupa 3 se koristi u nesintetickim i sintetickim mesavinama , grupa 4 se koristi iskljucivo u sintetickim mesavinama ...grupa 5 se ( to su esterna ulja ) se retko koristi skupa su , ne mesaju se lako sa benzinom , a i nisu kompatibilna sa nekim drugim uljima...postoje neke prednosti koriscenja sintetskih ulja uz bolji VI...sintetska ulja imaju mnogo visu tacku paljenja od naftnih baznih ulja ...
Sintetska ulja se nece tako lako sagoreti na visokim temperaturama kao naftna ...motor ostaje cisci , manje je taloga na klipovima karikama , glavi ,takodje , prenos toplote je bolji nego kod naftnih baznih ulja ...Ukratko , to je prednost sintetskih ulja ( uz tacan paket aditiva ) , nad naftnim baznim uljima ...rad u ekstremnim temperaturama – opterecenjima ...Postoji i treca kategorija ulja proizvedeno iz RICINA uz destilaciju ima neka jako dobra svojstva , ali i neka koja nisu tako dobra ...dobra su sto su jako dobar podmazivac ...ona traze vruce tacke u motoru mnogo bolje nego naftna ulja ...losa strana je da se lose mesaju sa benzinom i ostavljaju puno depozita ( ugljenika ) prilikom sagorevanja ( prljaju motor ) ....ta ulja su u ranim 70 –im godinama bila jako popularna na trkama ...a, sada kad ima savremenijih ulja , vise se ne koriste ...neke firme to jos proizvode , ali to treba izbegavati za svakodnevnu upotrebu , osim ako necete da cesce cistite motor ...neke firme to ulje koriste kao dodatak ,a za njega je karakteristican slatkasti miris ...
ADITIVI
Kad bi nauka razvila bazno ulje koje ne sagoreva na 1600 C i da ne promeni viskozitet od – 40 do 600 stepeni ne bi imali potrebe za aditivima ...bilo bi lepo da ulje ostane u istom stanju u kakvom je otislo u motor , ali to se nece desiti za nasega zivota , ono se mora reciklirati ...aditivi su u funkciji popravke odredjenih karakteristika baznih ulja Aditivi su slozene hamikalije koje poskupljuju cenu ulja , za 2-T spadaju u nekoliko kategorija : deterdzent / rasprsivac , svojstva protiv agenata , biorazgradive komponente i antioksidanti ...Ulje u procesu rada2-T mora sagoreti inace se talozi na izduvnom kanalu u tu svrhu se koriste deterdzenti / disperanti ...i to dve vrste ASHLESS i LOW ASHES ...( dalje se u tekstu objasnjava sta koji aditiv radi u motoru , to ko hoce neka procita izvorni tekst , slozeno je , a nama nije puno bitno ) ...
O standardima za oznacavanje ulja
Specifikacije ulja za 2-T zavise od dizajna motora i njegove namene ...buduci da postoji velika raznolikost ovih motora tako variraju i specifikacije ...Najrasprostranjeniji su ISO ( evropski ) JASO ( japanski – azijski ) , i americki API standardi ...ali ovi standardi nisu identicni i medju njima postoje razlike ...Tako , npr TCW 3 standard je predvidjen za rad motora do 6800 rpm i da sa tim uljem motor radi na niskom broju obrtaja bez zauljenja svecice ...koriscenje sintetskih ulja je prosirilo njihov dijapazon namene API TC standard je razvijen za vazdusno hladjene motore sa visokim brojem obrtaja koji rade u teskim uslovima ...Tu spadaju i ROTAX motori , za trke i motorne sanke , oni rade pod ekstremnim uslovima i uglavnom koriste sintetska i mesana ulja...dalje u textu se govori o tome kako su ta ulja skupa za setifikovanje ...nebitno za nas ...
Koje je ulje najbolje koristiti ?
Vrlo je verovatno da danas nema losih ulja ...
Castrol i i Bombardier ostaju jedini proizvodjaci ulja visokih perfomansi sa niskim sadrzajem pepela i koriscenje istih od -40 do 350 stepeni F dakle univerzalna za sve uslove koriscenja ( osim za trke ) ...Ta ulja nose oznaku XPS , skupa su , a nastala su 1995 godine i sa manjim poboljsanjima se proizvode istovetna do danas...Ako ne koristimo ova ulja , postoji citav noz dobrih ulja za 2-T motore sertifikovana po API TC standardu i asvaki proizvodjac ce rado dati svoje specifikacije za svakog korisnika ...
Dalje , autor texta savetuje koje ulje koristiti ...pa, ako motor zahteva skupa XPS ulja , njih treba koristiti bar dok traje garantni rok motora , a po isteku istoga koristiti jeftinija , settifikovana ulja, API TC od poznatih proizvodjaca ...
Bez obzira na gornji text ja samo dodajem svoje misljenje – za ove nase savremene 2-T motore treba koristiti polusintetsko ulje u JASO FC standardu bilo kog proizvodjaca , dok za motore koji se vrte preko 10 000 rpm sintetsko u JASO FD standardu ...i kraj price o uljima ...to je ono sto svi treba da znamo ...
Ne znam koliko sam uspeo sa prevodom i popravkom teksta , ali mislim da je bolje i razumljivije od Googla...
#10 goggyso
Posted 29 January 2014 - 14:46
Savršeno, svaka čast na trudu.
#11 ALIEN SM
Posted 29 January 2014 - 16:22
Hvala Goggy....sat posla , a trebalo je jos odavno ...prosle godine ...
#12 goggyso
Posted 29 January 2014 - 16:31
Kad god, dobrodošlo, inače je ovo stalna tema, uvek neke rasprave oko toga, sad imaju sažvakano. Hvala i Mariu, da ne zaboravimo, on je započeo.
Edited by Mario, 02 February 2014 - 15:37.
Posted 30 January 2014 - 00:01
MIšo svaka ti čast, zahvalan sam ti na trudu...
#14 Dajteh
Posted 11 September 2014 - 14:57
Ovo ću kasnije pročitati, a kakva je situacija sa rokom valjanosti za 2T ulje?
Vidio sam na boci da piše, rok upotrebe 3 godine od dana proizvodnje, šta aditivi gube svojstva? Eno otvorio sam cilindar nakon 4000km i sve je ko novo, a isteko rok prije jos 2011.
#15 ALIEN SM
Posted 20 April 2016 - 08:58
Evo , malo i da se dotaknemo ulja ponovo ...svi znamo koliko je ulje vazno , a ja sam taj koji je probao sve zivo koliko sta moze da izdrzi ...secate se onog mog ( exprerimentalnog ) matica koji je jeo sve zivo , od preradjenog 4- t , starog kompresorskog i ko zna cega sve ne ...zaribao tek posle mnogo hiljada km i sve to na DS klipu ...
Toga vise sad nema , svi motori su na alu- Airsalima i jedu samo fina ulja ...imam srecu da ovde kod mene imam direknog uvoznika ulja , ne prekupca , pa imam kvalitetno po dobroj ceni ...Ovo sto uzimam vec tri godine je francuski TOTAL, sintetik u plavoj boji , pravim premix sa njim , ofarba benzin u plavo u meri po preporuci proizvodjaca od 3 % ...odlicno maze motor , ne dimi , ne ostavlja skoro nikakve naslage , kad sam pre dva - tri meseca rastavljao Airaslmatica , na klipu i glavi - nista , obrisao samo sa krpom ...sve kao prvog dana kad je smontirano ...jeftiniji je od Motula najmanje za trecinu , a odlicno radi posao ...sve preporuke za njega ...ko moze da ga nabavi , neka ga koristi , ispunjava JASO FD standarde ...
#16 Synn
  • 43 posts
  • VozimAprilia Habana 50
Posted 23 April 2016 - 22:18
Da dodam jos nesto sto sam pisao na drugom forumu.
Danasnja 2T ulja se mogu mesati bez ikakvih problema. Cak vi koji ste malo iskusniji, mozete izmesati ulja tako da dobijete tacno onakvo ulje kakvo vam je potrebno za tvoj stil voznje.
Sva ulja imaju bazno ulje kao osnovu. Bazna ulja mogu biti sinteticka ili mineralna. Ulja se razlikuju samo po odnosu sint. i min. baznog ulja i po aditivima koje imaju u sebi. Ako kupite full sintetiku, koja vam ne odgovara za na primer gradsku voznju jer ima dost alera i spore voznje, slobodno ga mozete pomesati sa nekom polusintetikom, i tako cete dobiti ulje koje sagoreva na nizim temperaturama od prvobitne sintetike. Ako pomesate full sintetiku i mineralno ulje, dobijate polusintetiku. Tu mozete ekperimentisati u odnosima, i doci do najbolje kombinacije za vas nacin voznje. Samo vodite racuna o tecljivosti, jer ako ulje dozira pumpa, onda ulja moraju biti predvidjena za doziranje pumpom.
Danas nista nije tajna. Zna se ko u svetu proizvodi bazna ulja a ko proizvodi aditive i bukvalno svako moze da napravi svoje 2t ulje. Cak i NIS Nisotek scooter 2t ulje ima Piaggio sertifikate. http://www.nisotec.e...-za-male-motore . Neko je pominjao EUROPETROLOVO sinticko ulje, i da nije imao problema. Zasto bi imao kad je proizvodjac BELL, koji ima tehnologe za proizvodnju 2T ulja. Ja ga ne bih koristio jer su napisali da je full sintetika, a takvo ulje ne odgovara mojoj Apriliji Habana Custom, jer ona jadna nema dovoljno obrtaja da bi ga u potpunosti sagorela.
Motorna ulja za 4t benzince i dizele za razliku os 2T su vec nauka jer moraju da izdrze nekoliko godina da pretrce velike kilometraze, da imaju viskoznost i na -30, pa deterdzenti, bla, bla, bla ...
2T ulja odmah sagorevaju i mogu biti prosta i veoma jeftina. Nema potrebe da budu tecna na -30 jer ko vozi scoot na -30... Nema potrebe da imaju konzervanse jer ne stoje godinama u karteru, itd, itd.
Na zalost 2t ulja se proizvode u mnogo manjim kolicinama nego gorepomenuta pa im je cena veca.
Interesantno je da neki posebno strogi standardi za 2T ulja, ne postoje. Poslednji su ustanovljeni jos pre 15 godina. API TB (mineral), API TC (polusintetika) i API TD (sintetika) na primer, gde za sintetiku i polusintetiku uopste nije odredjen procenat odredjenih baznih ulja da bi se tako zvala... Tako da polusintetika moze da ima 80% minerala i 20% sintetike i da se zove "polusintetika" a moze da ima i 20 % minerala i 80% sintetike i da se opet zove "polusintetika", kod nekih proizvodjaca ce da se zove nekim generickim generickim nazivom, tipa "sintezis" ili "na sintetskoj osnovi" a kod nekih proizvodjaca ce se zvati "sintetika"! Tako da je polusintetika i sintetika kod 2T ulja, jako sirok pojam.
Kod 2T su najbitniji aditivi koji ce obezbediti sto potpunije sagorevanje sa sto manje dima, kao i tecljivost zbog skutera sa pumpom za mesanje ulja.
Full sintetika skoro da i ne postoji. Mozda neka specijalna ester ulja, ali ona su nepogodna za svaki dan i koriste se najcesce za visokoturazne 2T masine u motociklima koji idu na trke i tako to...
Postoje i 2T ulja koja su biorazgradiva. Ona se koriste za podmazivanje 2T motora na plovilima da bi se izbeglo zagadjenje vode.
U svakom slucaju, sva ulja se bez bojazni mogu mesati. To obicnim 2T skuterima koji se vrte manje od 10K obrtaja nece smetati.
Inace ja trenutno vozim na mesavinu Kastrola Actevo 2T i MOL Dynamic Sprint 2T u srazmeri pola pola.
Pitate se zasto!
Actevo nije dobro sagorevao jer izgleda ima dosta sintetike u sebi, pa je cadjavio izduv. Ta cadj nije bila masna pa sam iskljucio lose sagorevanje vec neki prah poput grafita kad zarezujes grafitnu olovku. Zakljucak! Jednostavno nije bila dovolno visoka temperatura u cilindru da bi i cadj potpuno sagorela. Kad sam ga za testiranje pomesao sa MOL-om u srazmeri pola-pola, cadjavljene je prestalo i sad je auspuh potpuno cist i posle predjeni 10.000 Km bez ijednog kvara ako ne racunam lulicu i svecice. U skutu mi je ulje jos od prosle godine, a imam jos litar u flasi.
Da kazem i to da i u benzin uvek dodam malo ulja. Oko 0,2 dL na 5 litara pa mi smesa dodje oko 2,5% ulja, pod uslovom da pumpa mesa 2%.
Pre neki dan sam dobio na polkon litar Ipona 2T Scoot Run 2 sa jagodom. To cu da probam kad potrosim ovu moju mesavinu.
Inace svaki skut je drugaciji. Okrecu se na razlicitim obrtajima, karburatori, dizne, uljne pumpe, svecica, hladjenje, nacin voznje, sve je drugacije podeseno i drugacije radi. U sustini, Idealno fabricko ulje za sve skutere ne postoji. Ako si zustar na gasu i imas nabrijanu masinu, treba koristiti sto kvalitetniju sintetiku. Ako si kao ja 99% voznje u gradu. Stani kreni, gas kocnica, Motor ne moze da postigne temperaturu potrebnu da sagori sintetiku, treba sipati polusintetiku. Posto je polusintetika sirok pojam, i kad je kupis, ne znas sta si kupio, a sve zbog zbog nedostaka regulativa za 2 t ulja, onda tu treba malko eksperimentisati.
#17 Desha
  • 17 posts
  • MestoSokobanja
  • VozimPeda GP50
Posted 04 May 2016 - 17:27
sve je ovde lepo objasnjeno,nema sta,svaka cast ali ja i dalje neznam sta bi trebao da sipam u moj skuter a da to bude kako treba,s obzirom da je kinez??sta bi po vama iskusnijim ljudima trebalo da se sipa,u upustvu mi ne pise sta bi trebalo sipati...neznam dali ovde treba da postavim ovakvo pitanje... :(
#18 Razredni
Posted 04 May 2016 - 17:38
Ovakava pitanja mozes da postavis u svojoj temi ili u podrlforumu "kratka pitanja i odgovori"
Prvenstveno, ovako niko ne zna koji je tvoj kinez, 2t ili 4t.. i malo se udaljavamo od teme..
Evo ovako, najprostije moguce:
Za exploataciju 2t motora do 6-7000 obrtaja, podmazivanje ce zadovoljiti bilo koje 2t mineralno ulje, ali nece biti dobro po pitanju tragova cadji i pepela koje ostavlja prilikom sagorevanja. Oznake za mineralna su: api tc, jaso fb
Za skutere, 2t motore sa vazdusnim hladjenjem, motore gde je radni rezim izmedju 6000 i10000 obrtaja, sve kriterijume (podmazivanje, antikorozija, hladni start, sagorevanje) zadovoljavaju polusinteticka ulja. Oznake su: api tc ali JASO FC!
Za motore koji trpe extremna naprezanja, trkacke, kroserice, kartinge, vazdusno i vodeno hladjene sa povisenim stepenom kompresije, alu-nikasil cilindre, radni rezim preko 10000 obrtaja, obavezna je upotreba SINTETICKIH ulja (100% syntetic, ester base, ester formula) cije norme su JASO FD.
Sinteticka ulja delimo po bazi, Synth blend (dozvoljena upotreba u motorima sa mesacem) i ester tehnology (sami pravimo mesavinu).
#19 Desha
  • 17 posts
  • MestoSokobanja
  • VozimPeda GP50
Posted 04 May 2016 - 17:51
ok,izvinjavam se...hvala.. :0takoje:
#20 Synn
  • 43 posts
Posted 10 May 2016 - 18:39
Ako ti je kinez fabricki i ako nisi nista budzio na njemu, neka jeftinija polusintetika ti zavrsava posao.
