Peugeot Jet Force
109 replies to this topic
#61 Lenko
  • 783 posts
Posted 22 June 2012 - 02:23
Ako nema ECU u funkciji, đžabe TPS !
Edited by Lenko, 22 June 2012 - 02:23.
#62 Gligorije
  • 166 posts
  • VozimSprint Grizzy
Posted 22 June 2012 - 10:11
kako da proverim ecu ? O_O
#63 Lenko
  • 783 posts
Posted 22 June 2012 - 10:35
Skini ga, pa probaj da upališ.
#64 .::SALLE::.
  • 274 posts
  • MestoKraljevo
  • VozimCBR 600RR
Posted 22 June 2012 - 11:19
ne moze da upali bez ecu-a
#65 Gligorije
  • 166 posts
Posted 25 June 2012 - 18:38
nece pa nece nista haha zlo ! pali na zub radi na leru sve cool das gas brm brm brm sa 2000 na 2500 obrtaja dize spusta i to je to ... koji maler haha izgleda cu morati komplet paljenje menjati i izbaciti kompijuter :
#66 Gligorije
  • 166 posts
Posted 25 June 2012 - 23:47
odradio sam dijagnostiku i ovako zvuci na kraju ove greske sam imao 3 , 4 , 16 , 22
OČITAVANJE GREŠAKA:
3,4,5 Nema veze sa greškama Voda u konektorima
motora Provjerite dali su kablovi oštećeni
16 Greška ECU-a Greška u programiranju
22 ECU power Faulty Wiring or connector Check Wiring & Connectors
Supply Faulty connection to ECU pin 17
Faulty ECU Check ECU (sect. 11) -------------------
e sad sex tek sad neznam sta raditi xD koblove gledam sve tu izgleda normalno jbg
#67 Lenko
  • 783 posts
Posted 26 June 2012 - 00:06
Sad bi trebao povezati na Gameboy-Peugeot Interface i poništiti te greške. A to retko ko ima, da ne kažem - niko. Osim ovlašćenih servisera.
#68 Gligorije
  • 166 posts
Posted 26 June 2012 - 00:15
al sta ce mi pomoci ponistavanje gresaka kad vidis da spominje neke probleme sa kablovima ? O_O
#69 Gligorije
  • 166 posts
Posted 26 June 2012 - 20:34
eo kako radi http://forum.pyrothe...tyle_emoticons/default/sad.png((
Edited by Gligorije, 26 June 2012 - 20:34.
#70 .::SALLE::.
  • 274 posts
  • MestoKraljevo
  • VozimCBR 600RR
Posted 26 June 2012 - 20:39
struja te zeza ocigledno je ... desavalo se na nekim sr-kama ditech sto sam radio , da pocne lepo da radi posle reseta software-a preko gameboy-a .. ali ne bih znao da ti kazem ko ima za peugeot .. jer nije isti software
#71 Gligorije
  • 166 posts
Posted 26 June 2012 - 21:18
nema niko za peugeot raspitao sam se samo u beogradu ima a to mi je nezamislivo daleko i veliki troskovi : maler ! :) kako nema neki hard reset sunce mu rucno ! ;)
#72 Lenko
  • 783 posts
Posted 26 June 2012 - 22:23
Ja sam imao ketriđž za Pežoa, ali ga je tip prepravio na Apriliju. A valjda možeš u Verano da pošalješ samo ECU, na reset. Možda bi mogao i Bugarski da to odradi, on ima neke softverske skalamerije. Mada sam ti rekao da ECU treba da se eliminiše.
Edited by Lenko, 26 June 2012 - 22:25.
#73 Gligorije
  • 166 posts
Posted 26 June 2012 - 23:01
pa kako da mi radi sve na motoru bez ecu ? struja cela ? svetla zmigavci obrtomer itd sve bas sve ? to ide sve preko ecu ... :'
#74 Lenko
  • 783 posts
Posted 26 June 2012 - 23:03
Pa struja treba da se menja ! Ne može i babe i žabe, bato !!!
#75 Gligorije
  • 166 posts
Posted 26 June 2012 - 23:08
ok sutra menjam paljenje onda (: imam neko od italjet formule pa cu probati da napakujem da vidim sta se desava na suvo :) da uklonim komplet ecu
#76 .::SALLE::.
  • 274 posts
  • MestoKraljevo
  • VozimCBR 600RR
Posted 26 June 2012 - 23:36
verovatno bi ti bilo najlakse da se stavi instalacija komplet od jetforce-a karb ali je preskupo , jedino da nabavis drugi ecu od nekog jet force-a injection da probas ali je pitanje da li ce moci sa tvojim kljucem onda .. zajebancija velika kako god okrenes
#77 Mario
Posted 26 June 2012 - 23:50
struja za jetforce, odgovara 1:1 sa ludix-om horizontalnim odnosno kymco-m, u principu prodaje se komplet TNT na motobike za nekih 2500-3000 din bez magneta
#78 .::SALLE::.
  • 274 posts
  • MestoKraljevo
  • VozimCBR 600RR
Posted 26 June 2012 - 23:52
i onda kupiti jos cdi i mozda bobinu , sve to izadje oko 8-9.000 din ..
#79 Lenko
  • 783 posts
Posted 26 June 2012 - 23:55
I kad sve to sabere... A čovek u Bgd prebacuje komplet, ključ u ruke, za 200e !
#80 Gligorije
  • 166 posts
Posted 27 June 2012 - 03:20
super !!! aj pomozi daj link tacno sta da kupim !
to je ok sale samo aj recite mi tacno bas tacno sta sve da kupim ako moze sa motobike sajta link ka artiklima !
aj pomozite sa tim linkovma sta sve da kupim da odma porucim danas to odlepio sam bez motora...
hvala puno unapred !!!!!
