Sprint Exactly - by Stefan p
556 replies to this topic
#21 Stefan p
  • 1,132 posts
Posted 09 October 2012 - 18:52
View Postcvele, on 09 October 2012 - 14:08, said:
Exactly ima pumpu koja izgleda "baca" ulje lopatom u karb :D Nisam ni jednog vido a da nije zamazan ...resenje -probati stelovanje pumpe ili najbolje-pumpa iskljucena i pravi se mesavina rucno...
Bio je bacao ulje na auspuh dok nisam iskljucio pumpu i promjenio saug,sada sam pravim mesavinu na 5l sipam 1d ulja.
#22 Stefan p
  • 1,132 posts
Posted 09 October 2012 - 18:57
View PostSlacko95, on 09 October 2012 - 15:34, said:
a stefane jel si ti uzeo ovaj sauh od 980 din?
Da taj u motobik-u,zasad radi odlicno.A imas jos neki od 3240din. :D
Edited by Stefan p, 09 October 2012 - 18:58.
#23 Slacko95
  • 282 posts
  • MestoDespotovac
Posted 09 October 2012 - 20:52
nedaje mi se bas 3200 din za sauh :D
#24 cvele
Posted 09 October 2012 - 21:05
Ma idi-begaj...dodas jos malo i kupis 17.5 u kompletu sa rucnim saugom...
#25 Stefan p
  • 1,132 posts
Posted 09 October 2012 - 21:32
Uzmi onda ovaj kao sto sam ja uzeo od 980din.
#26 Slacko95
  • 282 posts
  • MestoDespotovac
Posted 09 October 2012 - 23:54
po meni rucni sauh je majka a ne ko ovaj automatski da neznam na cemu sam...
#27 Mikac93
  • 1,554 posts
Posted 09 October 2012 - 23:57
Dobar je i automatski na svoj nacin,ali rucni je bolji,crkao je i meni sauh,pa sam kupio taj za 900 dinara i sasvim lepo radi...
#28 Slacko95
  • 282 posts
  • MestoDespotovac
Posted 10 October 2012 - 00:25
izgleda da je na exactly-u boljka sauh
#29 Mikac93
  • 1,554 posts
Posted 10 October 2012 - 00:29
Sauh,i levom faru sijalica,i tako sitnica koliko hoces...
#30 Slacko95
  • 282 posts
  • MestoDespotovac
Posted 10 October 2012 - 00:33
bolje sitnice nego veci problemi :D
#31 Mikac93
  • 1,554 posts
Posted 10 October 2012 - 00:38
Tako je! :D
#32 Milos'96
  • 1,281 posts
Posted 10 October 2012 - 08:43
Ma manualni zakon,kad god sam montirao automatski skinio sam ga posle 2 dana...ovaj i u sred zime povucem,upalim motor,spustim ga posle 10sec i odma vozim najnormalnije,znam da je sigurno iskljucen i ne razmisljam o tome.
#33 Mario
Posted 10 October 2012 - 10:18
kod automatskog se uglavnom samo prekinu žice, nema tu mnogo filozofije, bimetal ne može da se pokvari, to je mehaničko širenja dva različita metala, koji se lagano greju usled proticanja struje kroz njih...
i meni se to desilo, pa sam izmenjao žice...
http://forum.pyrothe...dpost__p__25462
#34 Stefan p
  • 1,132 posts
Posted 10 October 2012 - 11:49
Kad mi je saug bio pokvaren skuter se gasio stalno na leru, a sada radi normalno...
#35 Pita
Posted 10 October 2012 - 19:50
ručni je zakon, kad ga uključiš znaš da si ga uključio...mada kod automatskog ne razmišljaš, samo ručkicu kočnice i BAM po dugmetu i teraj!!! :blink:
#36 Mikac93
  • 1,554 posts
Posted 10 October 2012 - 20:15
Tako je Pita,svaki ima svoje prednosti i mane...
#37 Stefan p
  • 1,132 posts
Posted 29 November 2012 - 12:51
Da li moze da se stavi karb 19mm na serijsku prirubnicu?
#38 Mikac93
  • 1,554 posts
Posted 29 November 2012 - 13:04
Moze,ali to nije to onda,kod Bojmeta je stavljen PWK 24mm na serijski usis...
#39 Stefan p
  • 1,132 posts
Posted 29 November 2012 - 13:15
Aha,jel treba preradjivati prirubnicu ?
#40 cvele
Posted 29 November 2012 - 13:23
Moze...ide u nju svaki dell, od 12- 21...
