Tomos ATX tunning
16 replies to this topic
#1 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 03 March 2016 - 22:06
Evo i moje price sa atx-om, kupio sam ga za male pare i nisam imao pojma u kakvom je stanju ustvari. Prethodni vlasnik je bio kvarisa pa je lose prosirio kanale na cilindru, lose sklopio kvacilo... Uzeo stvari u svoje ruke i sredio sve. I uradio generalnu.
Evo i nekoliko slika kad sam ga kupio i sredio te stvari:
Attached File  11756622_396575327208921_1484409172_n.jpg   138.93K   12 downloads Attached File  11749243_396575300542257_1742838427_n.jpg   179.02K   14 downloads
Zatim sam malo sredio spoljasnji izgled:
Attached File  11759574_396574623875658_1262488228_n.jpg   79.66K   18 downloadsAttached File  DSC_0009.JPG   99.3K   17 downloads Attached File  DSC_0010.JPG   102.18K   14 downloads Attached File  DSC_0013.JPG   108.35K   13 downloads Attached File  DSC_0012.JPG   105.31K   12 downloads
#2 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 03 March 2016 - 22:23
Posle sam kupio lancanike promenio prenos sa 12:32 na 10:34, karburator bing 20mm (od freze imt 506), kupio sam masku i far od yamahe dt i novi prednje blatobran :
Attached File  DSC_0047.JPG   102.23K   8 downloadsAttached File  Capture.JPG   67.2K   8 downloads Attached File  maska.JPG   67.8K   12 downloads Attached File  12087333_420952931437827_1132696889_n.jpg   53.35K   12 downloadsAttached File  12087586_420952838104503_2061173767_n.jpg   54.02K   14 downloads
E onda sam odlucio da ga farbam, pa je doslo rasklapanje kompletnog motora:
Attached File  12166760_422379737961813_422087586_n.jpg   43.05K   8 downloadsAttached File  12166947_422379704628483_579456480_n.jpg   46.93K   9 downloadsAttached File  12167982_422379714628482_825206200_n.jpg   46.17K   9 downloadsAttached File  12179736_423986324467821_1063724430_n.jpg   53.77K   10 downloadsAttached File  12185727_423986291134491_196155889_o.jpg   154.63K   7 downloadsAttached File  10567963_422380044628449_2093179304_n.jpg   39.98K   8 downloads
Slike farbanja necu kaciti odneo sam kod farbara da odradi kako valja, al evo posle farbanja (ipak sam resio staviti njegovu masku) :
Attached File  12202488_568258263321816_1512622232_n.jpg   95.28K   9 downloadsAttached File  12204673_568258129988496_897334601_n.jpg   88.18K   9 downloadsAttached File  12188521_568258273321815_1843024148_n.jpg   83.05K   10 downloadsAttached File  804495_568258266655149_419095207_n.jpg   75.2K   9 downloads
#3 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 03 March 2016 - 22:33
Posle sam kupio i jos neke stvarcice druge (gasne amortizere, nove gume za nogare, kurblu, rucke, ulizak gasa.. lezajeve zadnjeg tocka, odneo cilindar na honovanje kupio klip nov (obican) nove dihtunge i platine):
Attached File  12182299_423986311134489_1983965601_n.jpg   48.95K   15 downloadsAttached File  12782130_461382810728172_1883681875_n.jpg   85.81K   18 downloads Attached File  12822606_461382897394830_1006178253_o.jpg   159.87K   16 downloads Attached File  12825349_461382907394829_1922602911_n.jpg   82.96K   15 downloads
Posto su ovi amortizeri veci bilo je nekoliko prepravki oko rama i zadnje viljuske, i kad sam sve sredio i stavio amortizere pojavio se problem oko lanca cesao je o viljusku zatim sam i to sredio (ne bas najbolje):
Attached File  12804544_461382854061501_1994255329_n.jpg   116.42K   11 downloadsAttached File  12825626_461382860728167_2004684213_n.jpg   152.42K   11 downloadsAttached File  12498653_461382920728161_1889576492_n.jpg   60.4K   13 downloadsAttached File  12784216_461382927394827_2084017514_n.jpg   94.53K   15 downloadsAttached File  12736216_461382870728166_560091012_n.jpg   83.7K   21 downloads
Evo par slika kad sam sklopio, ostalo je jos par sitnica do kraja i gotovo:
Attached File  12735960_457285857804534_1265660597_n.jpg   71.25K   22 downloadsAttached File  12784619_461382950728158_1026739762_n.jpg   81.24K   16 downloads
Nadam se da ce vam se svideti moja prica, nije nesto preterano al eto mnogo truda i prepreka je bilo, ostalo je jos nastelati paljenje kupiti drugi cilindar (ovaj je sa iznjakanim kanalima), i sajlu gasa i puza nabaviti.
Voleo bih da mi date neke savete oko cilindra koji staviti kako ga doraditi da bude bolji uz taj karburator, dal ima jos neke stvari koje uraditi da ide brze ili oko estetike, i kako bi drugacije mogao uraditi ovo za lanac.
#4 Nesa BG
Posted 03 March 2016 - 22:45
Fino si ga sredio. Sto se lanca tice mozda si trebao samo staviti neku tvrdju plastiku na mesto gde cese lanac (recimo komad spanera lanca sa automobila) i bilo bi dovoljno. Po mom misljenju za ATX bi najbolji cilindar bio onaj sa 14ice u kombinaciji sa nekim 16mm karburatorom. Bolje hladjenje i dosta snage i elasticnosti. Jedino je problem pronaci originalni cilindar i glavu od 14ice, vecina je sahranjena pa zamenjena sa apn-ovim kompletom a to ipak nije ni blizu. Kada bi mogao da nadjes dobar cilindar i glavu od 14ice to bi bio pun pogodak.
#5 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 03 March 2016 - 23:36
Ja sam razmisljao o bt ili t15 kompletom na ovaj karburator, al 14ice se nisam setio imacu to na umu hvala vam
#6 goggyso
Posted 03 March 2016 - 23:58
Taj lanac je predugačak, treba ga skratiti na optimalnu dužinu.
#7 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 04 March 2016 - 00:12
Ako skratim lanac nece stati pod onaj zubcanik ako tamo nestane cesace vile a spaner od kola se ne smesti tamo probao sam
#8 Nesa BG
Posted 04 March 2016 - 06:49
Nisam mislio ceo spaner nego samo komad fiksiran na deo vile po kojoj cese lanac. Samo toliko da ne struze po metalu. Po ugledu na neke ozbiljne kross motore.
#9 goggyso
Posted 04 March 2016 - 09:48
Mogao bi i španer sa zupčanikom ali sa oprugom koja će konstantno natezati lanac bez obzira na položaj točka.
Posted 04 March 2016 - 10:19
evo pročitao sam još jednom.. i moram da te pitam,
zar je potrebno toliko novih problema rešavati samo zato što piše "cross" na amortizerima za tamo neki model kroserice ?
#11 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 04 March 2016 - 11:40
Jel postoji neki nacin da se stavi drugi veci lancanik pozadi. Moji stari amortozeri se ono istrosili bili za promenu, a na ove sam slucajno naisao na najlonu i to za veoma male pare pa sam ih uzeo mislivsi da nece biti puno problema
Posted 04 March 2016 - 13:34
postoji ali će se onda menjati i prenosni odnos... možda odgovara neki lančanik sa 50 zuba od nekog drugog motora, i onda dobiješ veći prečnik, ali onda da bi popravio prenosni odnos moraš i napred postaviti veći, pa sad koji bude uopšte stao... mislim da je 15 najveći napred...
možda ćeš doći do zaključka da bi trebalo ove amortizere zameniti da bi rešio brdo drugih problema, ali eto može i težim putevima
#13 Nesa BG
Posted 04 March 2016 - 13:42
Mozda je lakse pomeriti usice na viljusci gde se nose amortizeri i vratiti ugao viljuske u priblizno fabricki.
#14 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 04 March 2016 - 14:21
Sredicu nekako to hvala vam. Sta mogu uraditi da na friziram masinu koji karb i cilindar staviti jel ima nes jos uraditi sa rezonom
#15 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 16 March 2016 - 13:49
Zavrsio sam motor kompletno. Stavio sam novi bt cilindar, glavu od bt-a drugu i dellorto karburator. I polepio nalepnice.
Attached File  12366713_464662640400189_1291772716_n.jpg   92.67K   27 downloadsAttached File  12064323_464662530400200_1956634936_n.jpg   107.5K   30 downloadsAttached File  12077441_464662440400209_33383025_n.jpg   55.15K   19 downloadsAttached File  12092322_464662270400226_764028495_n.jpg   78.52K   18 downloadsAttached File  12463530_464662037066916_1157452262_n.jpg   47.41K   17 downloadsAttached File  12804576_464662107066909_750272808_n.jpg   40.72K   13 downloads
#16 Dajteh
Posted 16 March 2016 - 16:36
Super su mi amortizerčeti
#17 SmileSmisule
  • 21 posts
  • VozimTomos Atx
Posted 19 March 2016 - 12:48
odlicni su
