Baotian Falcon 50R
937 replies to this topic
#461 Damjan66
Posted 28 August 2017 - 19:31
Evo malo photo session danas , a medjuvremenu riknula mi pumpa izgleda, uopste se necuje kad dam kontakt probao i drugi akumulator iako moj je bio pun ma jok nece da cuje uzecu ovih dana novu :D
Attached File  image-0-02-05-7dca205b9259a0a4682f63c2de08f7dab2c08389fa38736fb7e0688cd54830e5-V.jpg   185.37K   46 downloads Attached File  image-0-02-04-9a8796283d2a0ddcb4b92820b52682d7a0f6beca4b3dda78b55e62ea7cabdb5d-V.jpg   146.51K   50 downloads Attached File  image-0-02-04-ac05fc1fd36e8723d61bb19e09be3a04261906f00446867115ef8190c9456bc7-V.jpg   127.61K   50 downloads Attached File  image-0-02-04-c7ffebdfd5672b00350346c2ccf37758194432160b479e871825ec3505a9434c-V.jpg   133.09K   42 downloads
Edited by Damjan66, 28 August 2017 - 19:32.
#462 Damjan66
Posted 28 August 2017 - 19:51
Inace ko god da sedne da vozim dvojica kad dam pun gas odma se dize tocak i to dosta visoko, al kad sam sam nece da podigne haha :ninjar:
#463 Mario
Posted 28 August 2017 - 19:58
Ja nezz kako ovi stunteri sa 50-kama dižu na zadnji kako hoće.. Nešto tu nije dobro
#464 Damjan66
Posted 28 August 2017 - 20:36
Haha sve je tehnika i znanje :)
#465 SpenserMKD
  • 267 posts
  • VozimAprilia sr50
Posted 28 August 2017 - 20:40
 Damjan66, on 28 August 2017 - 19:31, said:
Od benziske do benzeske, pa aj foto sesija. :D :D :D
#466 Damjan66
Posted 29 August 2017 - 17:27
Definitivno ova bosch pumpa je riknula, sutra cu da uzmem 2-3 nove pa da vidim koja ce biti najbolja malo cu da testiram mozda i malo vratim ugao palenja hocu temperaturu da dovedem do 65 max.
Edited by Damjan66, 29 August 2017 - 17:27.
#467 Mario
Posted 29 August 2017 - 17:30
Da da.. nova je 100e
#468 Damjan66
Posted 29 August 2017 - 17:52
Jeste znam , ali imam druga koji ima 2 sprata mercedes delova sve i svasta polovnih i novih tako da nista neplacam :)
#469 Damjan66
Posted 03 September 2017 - 17:06
Stiglo novo zvono :)
#470 Damjan66
Posted 05 September 2017 - 17:12
Bio sam kod druga jucer pretrazili skoro sve delove ma dzaba od motora do vrata sta ne sve bukvalno samo nema pumpe nemam srecu, nasli smo samo 2-3 i to su aluminske neke starije pumpe uzeo sam ih za probu da vidim ali mi se ne svidjaju, danas sam resio da rasklopim ovu bosch pred da kupujem novu, otvorio sam je proverio sam cetkice i skroz su potrosene , ovih dana cu uzeti nove cetkice i smeniti.
Edited by Damjan66, 05 September 2017 - 17:13.
#471 Damjan66
Posted 06 September 2017 - 16:56
Danas sam skidao auspuh, izmedju dihtun i flanshu sve je suvo nigde nije curilo, znaci auspuh pusta kod konusa mislim da je zbog ovoga jer je ukriveno malo na unutra , probacu da ga iscukam da ispravim i hocu staviti i silikonsku o-ring gumicu samo da nadjem gde da kupim.
Attached File  21441429_1466482206761448_1964599982_o.jpg   94.96K   35 downloads
Evo i klip nakon 100km :)
Attached File  21392531_1466485670094435_1351659516_o.jpg   246.17K   35 downloads Attached File  21441609_1466484300094572_2103567965_o.jpg   140.9K   34 downloads
#472 Damjan66
Posted 06 September 2017 - 18:46
Stavio sam teflon traku i jedva sam ubacio auspuh jer sam uvitkao previse , uplaio sam ga nekih 1min u leru do 60 stepeni i ugasio sam ga , gledao sam nema nigde da curi cisto je sad nego malo mi cudno nesto sa auspuhom kad dam gas reze sve lepo i kad pustim odma izduvuje i kao da ispucuje takav zvuk daje dubok.
#473 Damjan66
Posted 07 September 2017 - 12:16
Sklopio sam nazad pumpu sa nove cetkice radi odlicno ,takodje sam primetio kad stisnem kocnicu onda pumpa se namali posle cu da istekam dzek za stop da nemam sve cu da iskljucim, takodje planiram da uzmem antifriz da vidim kako ce se dviziti temperatura sa njim ovako je samo cista voda, izbusicu i plastike a ubuduce definitivno cu uzeti onu bosch pumpu sa protok od 17,5L/min.
Za sad obavezno moram uzeti obrtometar ,OR remenicu i kais i da proveri boju mada previse ima ulje u rezervara na ler curi kad je i zagrejan cak, takodje i dva nova akumulatora upisao sam se na faks sada pa nemacu i mnogo vremena da ga vozim.
Evo kako se drzi teflon traka za sada videcu kad ga vozim vise sad kratka voznjica 10min i 15min u mestu je radio. Jako malo ima ulje ne vidi se lepo na slici ,valdja ce ovo da legne lepo i nece vise curiti.
Attached File  DSC_0425.JPG   1.24MB   34 downloads Attached File  DSC_0426.JPG   1.22MB   33 downloads
Edited by Damjan66, 07 September 2017 - 12:22.
#474 Damjan66
Posted 08 September 2017 - 17:21
Prosle nekoliko kapke na selettru i u prenosu :P , evo i koliko se penje kais fali negde oko 2mm, ovih dana cu da idam kod Vlatko da probamo 18mm kais i da montiram MHR zvono.
Attached File  DSC_0423.JPG   1.35MB   47 downloads
Attached File  DSC_0424.JPG   1.83MB   47 downloads Attached File  DSC_0425.JPG   1.72MB   40 downloads Attached File  DSC_0426.JPG   1.78MB   41 downloads
#475 Damjan66
Posted 09 September 2017 - 01:53
Veceras sam vozio skuter temperatura super dvizila se oko 60 63max ali sam stao nesto i vidim u ler podize dodje nekih 69 i odma ugasim dajem kontakt vidim neradi pumpa, aj rekoh mozda nema kontakt mrdao zice ma nisto i odjednom proradila i otisao sam kod druga taman kod njega opet otkazala pumpa.
Napunio sam akumulator prikljucim dam kontakt svrti pumpa i opet prestane , proverio sam svaki kontakt probao i direkt prespoijo i od drugi akumulator pa jok nece da cuje , i onda mi tekne uzmem udarim je i eto je proradi, elektricar mi nije lepo stavio cetkice sutra cu dda je otvorim lepo da stavim.
Edited by Damjan66, 09 September 2017 - 01:54.
#476 Damjan66
Posted 09 September 2017 - 16:50
"Nove original" cetkice stavio ma ...
#477 Damjan66
Posted 09 September 2017 - 23:34
Tek sad sam video koliko kosta ova pumpa nova 240$ a ja sam je sjebo hm..... one sive sto sam uzeo nisu ni bile pumpe tako da sad trazim opet polovnu da kupim.
#478 Mario
Posted 10 September 2017 - 05:33
Da ti nisam rekao :)... ja sam novu kupio za 100e
#479 alentje
  • 572 posts
Posted 12 September 2017 - 08:21
A peglanja oko te pumpe. Jeli nije mala ta temperatura? Meni je normalna bila oko 75 80. Uz brdo mi je jednom digao preko 90, mada sam kasnije ustanovio da zaptivac glave nije valjao.
Verstuurd vanaf mijn SM-G935F met Tapatalk
#480 Damjan66
Posted 12 September 2017 - 14:01
Ne temperatura je bila dobra sada nije stigla ni do 65, ranije je isla vise jer pumpa nije radila kao sto treba, sa novim cetkicama je super samo eto nevalja pumpa odma ih potrosila sad trazim polovnu drugu da kupim.
41 user(s) are reading this topic
0 members, 41 guests, 0 anonymous users
