gilera runner 125sp
72 replies to this topic
#61 mako
  • 44 posts
  • MestoKriževci (Cro)
  • Vozimrunner sp180
Posted 29 September 2017 - 12:38
Hvala ekipi na pomoci, i naravno Mario! Pa da ubacim i slike od radova:
#62 francuz69
  • 443 posts
  • VozimKymco Downtown 300
Posted 29 September 2017 - 13:30
Udri Mako! Samo jako!
#63 Mario
Posted 29 September 2017 - 13:38
Sa čime to greješ blokove sa MAP gasom ?
#64 mako
  • 44 posts
  • Vozimrunner sp180
Posted 29 September 2017 - 15:54
Sa malim brenerom ( Let lampom)
#65 mako
  • 44 posts
  • Vozimrunner sp180
Posted 29 September 2017 - 16:20
I danas se radilo, pa tako stavljen novi iglicasti na radilicu, novi klip,brtve,izmjerena kubikaza glave i skvis, te sastavljen cilindar..
cilindar je piksiran na blok, ubacene dvije piksice izmedu cilindra i bloka, isto je u originalu napravljeno izmedu cilindra i glave, tako da je sve u centru....Attached File  image-0-02-04-e95a9bb2eeeee4e3f1bdfc342b6025d75047390c98fb494df53abe2dc019679e-V.jpg   244.61K   16 downloadsAttached File  image-0-02-05-418f9df4231b9842927d537efb4bea6fcc77e7928c000a36e3759e8aa58c83be-V.jpg   225.03K   18 downloadsAttached File  image-0-02-05-c31acc9d0a7096005afff332fae8ac9d80b2adc93e1ed4e72f12ae37937379bb-V.jpg   209.55K   21 downloadsAttached File  image-0-02-05-abba9ab91076e5292eed68d72e26584a2f1b8c2f9e2725882ca976ba65359888-V.jpg   239.85K   20 downloadsAttached File  image-0-02-05-875714e1934a0d95d0f912db231d65a90298dd9e7bea0abecbfa973c7e10d4ac-V.jpg   186.35K   20 downloadsAttached File  image-0-02-05-ff0bd8d1aabb6d7a85cff3ac64f0147c70beca6584038d1f604d04088aafd54a-V.jpg   228.61K   24 downloads
svi podaci zabiljezeni u dnevnik, da nebi isparili iz glave s vremenom :)
Attached File  image-0-02-05-d6173d1a3ba7f080bdabc25cf1ddbc8db2cca785c18351efae27f8590879c646-V.jpg   188.8K   23 downloads
#66 Razredni
Posted 29 September 2017 - 18:55
Svaka čast, majstorski radovi, pratim sa zadovoljstvom. Kakvi su planovi po pitanju karburatora, paljenja i auspuha?
#67 mako
  • 44 posts
  • Vozimrunner sp180
Posted 29 September 2017 - 23:13
Hvala! Karb jos nisam odlucio, ali u opciji su 28 ili 30 pwk, paljenje ce biti serijsko, posto ce motor biti za svakodnevnu upotrebu i registraciju pa je ta opcija da mogu imat svijetla i sve potrebno, jedino ce bit jos mhr digitronic cdi,a auspuh ide malossi :)
#68 Mario
Posted 30 September 2017 - 06:58
Računao si stepen kompresije metodom ulivanja ulja ?
Praksa je pokazala, a i na takmičenjima tako proverava komisija, sto ulivaju do druge-trece loze navoja sa strane kompresionog prostora. Tako je najpribližnija simulacija zapremini uvrnute svećice..
#69 Mario
Posted 30 September 2017 - 07:04
Imamo danas vec preciznije metode, koje prate kasnije izmenu zaptivača i promenu ns sqush-u, tako da možeš i planirati kompresioni odnos onapred, pogledaj temu i download-uj sebi kalkulator..
https://svet-skutera...kompresije-V2.0
#70 mako
  • 44 posts
  • Vozimrunner sp180
Posted 30 September 2017 - 11:55
Tako je, omjer sam mjerio ulivanjem nafte..ustvari provjeravao sam ga samo iz sigurnosnih razloga, da nebi bio preveliki omjer, jer nisam htio bas ici u krajnost sa tim, posto bude za svakodnevnu voznju, tako da mi mala odstupanja nisu bila bitna.. hvala na informacijama vezano uz ovo do kud je najbolje ulivati, nisam to znao, isto tako hvala na kalkulatoru, morat cu ga malo prouciti, posto nisam bas koristio takve stvari, sve sam uglavnom racunao rucno do sad.. :)
#71 mako
  • 44 posts
  • Vozimrunner sp180
Posted 04 October 2017 - 21:14
Posto mi fale neke sitnice za zavrsit masinu, danas se radilo malo po rami, bit ce promjenjena plastika oko vilica, skinut je volan jer ce i on ic novi, isto tako je maknuta postojeca instalacija jer ce ici originalna..nema nekih posebnih slika, dok ne pocnem sa detaljnijim radovima...
#72 steeef
    2t bb & 4t i.e.
  • 2,198 posts
  • Mestokc
Posted 04 October 2017 - 22:44
ajd napokon da si se i ti pokrenul..vidim da te rakija zaljecila :D
vilica je brutalna,uzivo jos bolje izgleda,masivno i pravo sportski
nema boljega nego rada s novim dijelovima,najveci gust
#73 mako
  • 44 posts
  • Vozimrunner sp180
Posted 10 October 2017 - 21:40
opet je bilo malo vremena, pa se radilo na nekim sitnicama...promjenjena plastika oko kilera i dodatno probusena da je bolji protok zraka,posto je gore kiler od nexusa..stara plastika je bila u komi, ispucana i falili su komadi..Attached File  image-0-02-05-03ba7af6c01445748762cf7dca83425c3ccb5629f3b19cf48fed456449a1aa3b-V.jpg   187.86K   22 downloadsAttached File  image-0-02-05-03ba7af6c01445748762cf7dca83425c3ccb5629f3b19cf48fed456449a1aa3b-V.jpg   187.86K   22 downloads
lezajevi vilica podmazani samo, posto su vilice bile dolje zbog stavljanja plastike...
na motoru je grimeca 4-klipna celjust, od stajanja je malo pocela stekat, i aluminij je poceo oksidirat, pa je rastavljena, ociscena, klipici podmazani, i ponovo sastavljena..
Attached File  image-0-02-05-9eac78f2aa4f3fef8900174a8211d4455860dc5081c4e11c130c9da7fbb6234c-V.jpg   243.16K   14 downloadsAttached File  image-0-02-05-71ada0d7dd0e29583fea1298bf9572ccfc8a7763e4ecdcf119301ec1bbfb722d-V.jpg   208.06K   14 downloadsAttached File  image-0-02-05-4f217338627d6fa97c5cacfbb9e38c28069df0f56edc80dfedaa4c4597bd367d-V.jpg   228.95K   15 downloads
plocice su jos dobre, pa su samo malo ociscene i vracene nazad..
Attached File  image-0-02-05-6a18775b875db9b7ea01f9fc584c77b04bd6a2300beb4e800d26d523c0f6bdc7-V.jpg   230.19K   14 downloadsAttached File  image-0-02-05-6dd4eae5bcc5b3a88838f5de1ac1945b60e5a9a3df7068801bbb90fa55f00d11-V.jpg   233.45K   14 downloads
to je zasad to, cekamo novo slobodno vrijeme za nastavak radova :D
