Obrtaljke made in china...narucujemo xx komada...
193 replies to this topic
#1 cvele
Posted 18 April 2012 - 11:41
Cena -prava sitnica...ajmo u nabavku...
http://www.ebay.com/...19cef2f8f3#shId
http://www.ebay.com/...031213921070801
#2 Pita
Posted 18 April 2012 - 13:05
piše da je dostupno na stanju više od 10 komada...verujem da može na komad...džabaka..
Posted 18 April 2012 - 13:33
ako i treba 10, neće biti problem prodati, samo da vidimo koji je trošak transporta i transkacija
#4 jack023
  • 214 posts
Posted 18 April 2012 - 13:37
Ajde da se svi dogovorimo i napravimo spisak i predamo ga onom tipu što kupuje sa ebay-a pa donosi u Srbiju.
Samo mi nije jasno što piše hours?
#5 Boza
Posted 18 April 2012 - 15:51
View Postcvele, on 18 April 2012 - 11:41, said:
Ова два су иста? Или не?
#6 Pita
Posted 18 April 2012 - 17:08
pitaću lika sa bjb-a za koliko para bi doneo...
#7 jack023
  • 214 posts
Posted 18 April 2012 - 19:22
http://www.facebook....100001242508107 ima i ovaj tip.
#8 cvele
Posted 18 April 2012 - 21:58
Isti su i mere sve po malo al meni su jedino RPM interesantni... :)
Brand New
Brand new, hourmeter / tachometer for your motorcycle is up for auction.
APPLICATIONS: Honda motorcycles, ATVs and dirtbikes, all 4 stroke or 2 stroke gas engines
It will show both engine rpm and hours of operation
It will read up to 99,999 rpm
Instructions included. Very easy to install, just 1 wire;
Wrap it around your spark cable 3-4 times and you are ready to go.
Programmable maintenance interval setting.
No more guessing for the oil change.
It will work on any 4 stroke or 2 stroke gas powered engine.
Replaceable internal battery rated for 35,000 hour of operation
Inace je jedan momak sa MS -a narucio i u upotrebi je na 4t kinezu...vidi se ispod satova dole...
#9 Stipke
  • 8 posts
  • MestoSubotica
  • VozimSprint GR8
Posted 18 April 2012 - 22:43
javite koliko kosta i to, uzeo bih i ja verovatno :)
#10 Pita
Posted 18 April 2012 - 22:47
čekam odgovor od momka koji dovlači stvari sa ebaya pa ću vam prenesem...
#11 Alexandar :D
  • 738 posts
  • MestoPancevo
  • VozimV-Max 1200ccm
Posted 18 April 2012 - 23:00
Da li neko zna koliko su tacna merenja ovog tahometra ? Odnosno da li posle odredjenih obrtaja krece da laze itd.Jer ako krece da laze onda fin shtel upada u vodu...
#12 Pita
Posted 19 April 2012 - 08:34
dobio sam informaciju za ovu obrtaljku:
1 kom - 20eur
10 kom. - 160 eur
To su cene za dostavu u Srbiju
Posted 19 April 2012 - 08:44
hajde pravimo listu.. kome treba, skupimo pare na jedno mesto i to je to..
1.Mario
#14 Pita
Posted 19 April 2012 - 09:59
1.Mario
2.Pita
#15 Beogradski Fantom
  • 1,606 posts
  • MestoBeograd, Kotez
  • VozimMalaguti Madison
Posted 19 April 2012 - 10:59
1.Mario
2.Pita
3.Phantom F12
Posted 19 April 2012 - 11:12
maločas sam pričao sa Aleksandrom, pa da napišem, Pita i ja imamo S6 obrtaljke skupo plaćene, ali upisali smo se da bi imali konfor kada neki motor radimo da ne skidamo sa naših motora, a i da bi brojno stanje 10 bilo brže popunjeno, te da ljudi koji nemaju lakše dobiju odnosno kupe...
po meni je ovo isti kineski modul kao i u koso i s6 obrtaljkama, samo se ne plaća ime i ekstra funkcije tipa merenje temperature+ sonda, osvetljenje...
#17 Stipke
  • 8 posts
  • MestoSubotica
  • VozimSprint GR8
Posted 19 April 2012 - 11:17
ja cu se javiti u toku dana da li cu uzeti :)
#18 Alexandar :D
  • 738 posts
  • MestoPancevo
Posted 19 April 2012 - 14:37
1.Mario
2.Pita
3.Phantom F12
4.Alexandar
Potvrdjujem ovu pricu sa Mariom jer je nekako logicno da placas brend + dodatne funkcije tako da se nekako uklapa u cenu.No mozda je zavrsna izrada ovog uredjaja losija nego stage6 ali ako potraje 2-3 godine,16eur'a za 2-3 godine stelovanja i zezanja je smesna cifra ako se uzme u obzir da ni Stage6 tachometar nije bas izdrzljiv i da imam vise primera da prilikom akanja istog je dolazilo do prekida kontakta unutar zice ili samog uredjaja.Dakle hajd jos 6 ljudi pa da kompletiramo spisak,naravno moze i preko 10 :)
#19 Black Adder
Posted 19 April 2012 - 14:39
1.Mario
2.Pita
3.Phantom F12
4.Alexandar
5.Black Adder
6.Cvele
#20 cvele
Posted 19 April 2012 - 15:39
View PostBlack Adder, on 19 April 2012 - 14:39, said:
1.Mario
2.Pita
3.Phantom F12
4.Alexandar
5.Black Adder
6.Cvele
Ajde tuneri-jedinstvena prilika da se za malo love dodje do vrlo bitne komponente :) http://grafolit.eu/s...tyle_emoticons/default/evilgrin0010.gif
