#41
Posted 07 January 2013 - 18:19
Ne treba ti druga radilica za base kit i te obrtaje do 10000. Samo uzmi neki kvalitetniji iglicasti lezaj i mozes to voziti bez problema.
Druga ojacana ili sa punim polutkama radilica bi trebala da ga konstatno kroz ubrzanje vozis preko 10000 obrtaja, ali tu vec spada u visu klasu tuninga tako da ne moras sa tim da se zezas. Uzmi neki base gus kit, auspuh u rangu Zx-a, Treka, Next R-a, karburator 16-19mm na airboxu i sredi prenos i to moze da vozi najmanje 10000 da ni ne pomislis na radilicu.
#42
Posted 07 January 2013 - 20:17
Otprilike ovako bi trebao da izgleda setup :
Cilindar i klip: Malossi sport 70cc
Auspuh: Tecnigas trek
Variator: Malossi Multivar
Kvacilo: Stage6 MK II
Rolnice: Naraku 6.3
Remen: Malossi kevlar
Karburator: Arreche 17,5
Radilica: Fabricka sa novim lagerima i klipnjacom
Ventilator varijatora: RMS
Sundjer: Malossi red sponge
Ako za nesta mislite drugacije napisite, za sada imam samo auspuh, rolnice i remen, dok jos nisam narucio ostalo
Edited by Elyseo, 07 January 2013 - 20:18.
#43
Posted 07 January 2013 - 21:04
#44
Posted 07 January 2013 - 21:11
#45
Posted 07 January 2013 - 21:54
#46
Posted 07 January 2013 - 23:10
#47
Posted 08 January 2013 - 02:01
Koji broj dizne bi trebao da stavim kada stigne cilindar i klip dok ne uznem karb, necu da se vozim cisto da radi u leru, dok ne stignu svi delovi lepo da sklopim, pa da vidim treba li sta da se dosteluje
#48
Posted 08 January 2013 - 02:32
#49
Posted 08 January 2013 - 21:06
Ovaj auspuh sto se vidi na slici prodajem za hijadu dinara, ako neko zeli neka se javi u pm
Edited by Elyseo, 08 January 2013 - 21:10.
#50
Posted 09 January 2013 - 02:01
#51
Posted 09 January 2013 - 02:19
#52
Posted 10 January 2013 - 02:01
Edited by Elyseo, 10 January 2013 - 02:52.
#53
Posted 10 January 2013 - 02:37
#54
Posted 10 January 2013 - 17:00
#55
Posted 24 January 2013 - 01:47
#56
Posted 08 February 2013 - 22:18
http://shop.motobike.../prod_2836.html
http://shop.motobike.../prod_8513.html
Pretpostavljam da je svejedno koja od ove 2, ali bolje da pitam
Na sadasnju bih trebao da menjam lezajeve i klipnjacu, ali to ja necu moci, moracu do majstora da on to namesti, a nisam siguran da ce uspeti da namesti klipnjacu kako treba pa mislim da je mozda bolje da uznem celu...
Edited by Elyseo, 08 February 2013 - 22:21.
#57
Posted 08 February 2013 - 23:19
#58
Posted 09 February 2013 - 00:01
#60
Posted 08 March 2013 - 18:06
