#181
Posted 28 August 2013 - 00:44
#182
Posted 28 August 2013 - 09:01
#183
Posted 22 September 2013 - 11:49
Da sam ju isao spajati po nekoj svojoj logici tj. po boji zica vjerojatno bi sve sprzilo, jer boje zica nemaju veze s nikakvom logikom.
#184
Posted 23 September 2013 - 22:14
Smijem biti bezobrazan i traziti link ?
#185
Posted 23 September 2013 - 23:08
P. S. Cim smislim nosac za ovo cudo, spajam ga i javljam rezultate. Ne svidja mi se jedino sto je jako dubok, pa ce strsati kao g...o u puncu
#186
Posted 23 September 2013 - 23:42
Usput ovdje da podjelim stranicu > www.dx.com - znaci kinezi su u pitanju ima nenormalno jeftinih stvari od kopija telefona po $30-50 do pojacala po $15-20 (i ostalih sitnica) .....
ja sebi planiram naruciti 'neon' traku za farove - http://dx.com/p/t10-...r-yellow-146697 (ovaj music senzor izbacit )
mozda i ovaj rpm http://dx.com/p/2-in...ge-black-218225 nije los
koliko sam vidio po forumima ljudi iz HR i BiH su narucivali , stiglo im , valjda nisam toliki pet da od 100 ljudi mene sje.. , samo cekam kakvu karticu da zbavim za placanja
Edited by StariCojek, 23 September 2013 - 23:43.
#187
Posted 24 September 2013 - 14:17
#188
Posted 17 January 2014 - 17:53
#189
Posted 18 January 2014 - 13:29
Fina spravica
#190
Posted 15 March 2014 - 13:01
#191
Posted 18 August 2014 - 16:22
#192
Posted 18 August 2014 - 17:16
http://www.ebay.co.u...%3D271331623767
#193
Posted 18 August 2014 - 18:26
Obrtomjer jos uvijek nisam spojio, jer nemam vremena posto radim nesto na kuci (plocice, laminat itd.) a treba ipak potrositi par sati za izradu nosaca i spajanje obrtomjera.
P. S. Stigla mi je i mini kamera pa mozda opalim jedan video ovih dana .
Edited by mrgood, 18 August 2014 - 18:30.
#194
Posted 18 August 2014 - 19:15
#195
Posted 18 August 2014 - 20:17
Neznam gdje si iskopao podatak oko 18 mm, al mogo si bez problema prosirit rupu na 20, ipak je to plastika.
Sto se el.blokade tice, ona cuvena od slowridera radi za sve pare, pogotovo na pia bloku, dok na minarelliju je malo losija, ali ipak radi poso.
Prijatelju na dr.evo, stage 6 pro, mhr variomat,19 karb itd je radila bez najmanjeg trzaja, i skuter je drzao ravno 50, tako da si negdje ipak fulao s blokadom.
Btw nece nista biti od tog inox prstena kad su i serijske napravljene od zeljeza.
#196
Posted 19 August 2014 - 00:31
#197
Posted 19 August 2014 - 01:43
Edited by mrgood, 19 August 2014 - 01:52.
#198
Posted 19 August 2014 - 01:51
Nisam znao da se ta sema tako zove, onda znam koja je.
Edited by goggyso, 19 August 2014 - 01:51.
#199
Posted 03 September 2014 - 14:51
Idem ja tako na neku vožnju od cca 20tak km, i pri povratku kući na jednoj uzbrdici motor se ugasi. Ja odmah počeo psovat, reko evo ga, zaribao, pa šta mu sad bi itd. Sagnem se dole i vidim ispala lulica. Stavim ju nazad i krenem dalje. Idući dan opet se isto desilo: pala lulica. E sad sam već bio malo lud i odlučim to riješit. Moja lulica je naime napravljena tako da ide na onaj mali navoj na svjećici, znači kapica se mora skinuti sa svjećice i onda se nabije lulica gore. I pošto sam ja prilikom stelanja fergazera puno puta to vadio i stavljao, navoj na svjećici se pojeo i lulica je spadala dole. Stavio sam novu svjećicu (polovnu od škode felicie, znam da treba ić Champion RN2C ili NGK br9es, ali meni su se felicijine pokazale odlične). I kad, vidi vraga, skuter nevjerojatno dobro reagira na gas, a i trokiranje prilikom kretanja je skoro nestalo. Vražji navoj i prokleta lulica
#200
Posted 03 September 2014 - 16:14
