#61
Posted 13 May 2013 - 23:15
#62
Posted 13 May 2013 - 23:28
http://www.scooter-c...MBRANPLAETTCHEN
Ili kompletan usis...
http://www.scooter-c...ERGASER_MEMBRAN
#63
Posted 13 May 2013 - 23:33
#64
Posted 13 May 2013 - 23:37
#65
Posted 13 May 2013 - 23:51
zoran_28, on 13 May 2013 - 23:37, said:
http://www.scooter-c...ASER_LUFTFILTER
A svecice...jbg tu je izbor veliki al cu ja opet moju preporuku...
http://www.scooter-c...DUNG_ZUENDKERZE
#66
Posted 14 May 2013 - 00:03
Pozdrav ljudi,treba mi netko koje da usisne lamele koje su dobre??ima stage6 ima malossi par varijanti,i molim vas pomoc oio kuglica za variomat ima razlicitih dimenzija ne znam koje meni idu,znam da moram uzet od 6grama i 9 grama samo koje dimenzije?hvala unaprijed
#67
Posted 14 May 2013 - 17:19
#68
Posted 14 May 2013 - 17:56
#70
Posted 14 May 2013 - 21:22
Pita bio si u pravu ovo je igra bez granica,ali rijesit cemo mi to uskoro sada narucujem sto mi je preostalo jos i gotov sam s ovim dosta je bilo trosenja haha
#71
Posted 15 May 2013 - 11:17
#72
Posted 15 May 2013 - 11:24
Ekipa da vas pitam koji mi treba filter sportski uzimam malossi e13 sada mislim ravni uzeti ili s kolinom???imam dellirto 21 karb,i molim malo pomoc oko rolnica tezina to me muci...kosta 10 eu set jedan a meni ce trebat 5-6 setova,i uzimam opruge racing malossi uzeo sam bio obicne sportske,a tribam ove zbog starta i obrtaja,da stavim plave,sale600 pise da su crveni slabi a crni prejeki da je on stavio plave....a centralna oruga od variomata je bijela,da uzmem ljubicastu ili ostaviti ovu?treba mi dobar savjet i sutra moram to sve narucit hvala puno zoki
#73
Posted 16 May 2013 - 15:13
#74
Posted 16 May 2013 - 15:32
#75
Posted 16 May 2013 - 17:35
#76
Posted 16 May 2013 - 18:14
#77
Posted 16 May 2013 - 18:23
#78
Posted 16 May 2013 - 18:27
#79
Posted 16 May 2013 - 19:41
Stage6 Racing 70cc LC
190€ / 15,1 hp / 13.569 rpm
The Stage6 Racing was tearing up the scene when it first got released (btw there is a version 2 about to arrive . At its low price and great feature set it made the established manufacturers (especially Polini and Malossi) look very old and outdated. But not only the price but also the performance exceeded the expectations of most. In combination with the Stage6 R1200 exhaust it creates a Stage6 typical (see the Sport cylinder test) very wide revenue band. Definitely a killer combo that is easy to adjust and with 10 nm torque also good for the one or other hot lap on the circuit. The T shaped exhaust port allows for improvements and there are some high end portings out there that reach the 20 horse power mark.
Stage6 Racing 70cc 15,1hp at 13.569rpm
#80
Posted 16 May 2013 - 20:17
Stage6 dizne:88-110 i dellorto 112-120
Sportski filter E13 32-38 mm ravni Malossi
Svjecica ngk br8eg
Variomatske rolnice: 4,0,4,3,5,0,5,5,6,1,7,2 ja mislim da je dosta tu za poigrat se s tezinama
Kvacilo opruge mhr: najvjerovatnije cu staviti plave
Centralna opruga : Ljubicasta
Malosi prijenos: 14/39 primar
Malosi zvono
eto ga to je to,za moj setup dovoljno sto vi mislite?ovo sutra narucujem i saljem za dva tjedna za split da se sve montira
40 user(s) are reading this topic
0 members, 40 guests, 0 anonymous users
