#4601
Posted 14 December 2015 - 23:11
#4602
Posted 15 December 2015 - 10:20
#4604
Posted 16 December 2015 - 11:44
Sa druge strane, za te pare bi mogao uzeti neki ozbiljan kit alunikasil.
#4605
Posted 16 December 2015 - 12:02
Imam ti ja sve mape.
Pretpostavljam o kojem se gameboyu radi, kod nas se prodavao za nekih 120€
#4606
Posted 16 December 2015 - 12:06
#4607
Posted 16 December 2015 - 12:20
#4608
Posted 16 December 2015 - 12:35
Okacit cu vam link
Edited by dajteh, 16 December 2015 - 12:36.
#4609
Posted 16 December 2015 - 13:01
http://www.apriliafo...i-Tech-ECU-Maps
Lauda, ja verujem da se može ući nekim alatom na PCu u mapu pa čačkati po njoj. Imam negde sliku otvorene mape, ako se dobro sećam u hex-u je pisan al nisam siguran.
Da mi je bar da pogasim sve blokade, skinuta mi je ona što mi limitira obrtaje na 11500 al nije ona što kontroliše odnos položaja TPa i postignutih obrtaja, neznam kako su to uradili ali definitivno ako mašina skoči na 5k uz milimetar otvorenog gasa, ECU prekida ubrizgavanje i varnicu. To je extra idiotski, osim za teletabis vozače, jer opasno smeta kod iole ozbiljnijeg tuninga.
#4611
Posted 16 December 2015 - 13:20
http://tuneecu.com/T...U_En/links.html
Možda bi se moglo iskoristiti da se sa PCjem komunicira sa ECU.
#4612
Posted 16 December 2015 - 13:31
I found my paper notes. When I worked on this I had a working system that used a color gameboy with a custom cartridge to flash the ECU. It came with interface cables already made so unfortunately I did not record the pin numbers. The physical interface is a simple ECU power (+12, Gnd) and a K-Line (0-12V logic) Initial baud rate is 9600.
If your not familiar with K-Line it is a single wire interface where the two devices take turns transmitting. On device uses a pull up resistor and signal idles logic hi and the device sending a packet pulls the line to near ground when it needs to send 0's You can tell the difference between the two when looking at the data on a scope as one device usually pulls the data lower than the other.
Here is a download to the ECU I captured. gb=gameboy (host),
55 aa 55 aa 55 aa 55 aa 55 aa 55 aa 55 aa 55 aa 55 aa 55 aa 55 aa
55 aa 55 aa
;the above looks like idle keep alive polling. gb sends 55, ecu replies AA.
;next is the start of session
c3 15 ;gb sends
65 04 e0 be ;ecu replies
c0 11 ;gb sends
04 ;ecu replies
c0 12
02
c0 00
2c
c0 00
2c
fa 03 01
81 b0 81 b9
f9 51 39 17 b1
03 01
06 00 0c 00 00
0c 00 00
03 01
4d 31 45 41
03 01
50 44 57 41
02 01
30 30 31
06 00 0d 00 00
0d 00 00
03 01
53 52 35 30
03 01
30 30 00 03
55 55 aa
c3 15
65 04 e0 be
c0 00
2c
fa 03 02
37 c7 37 d0
f9 2b 8c
2d af
03 02
No clue what the above conversation is about or if the baud rate was changed.
Next comes the data syntax looks like
Length, AddrHi, AddrMed, AddrLo, data0, data1, data2....data15, checksum
checksum is the total of all bytes length to data15 (inclusive) minus 1
Since the first line has no 00 I am assuming the 00 is an acknowledge (ecu saying it got the previous packet ok)
10 01 50 00 de fc d2 f9 11 44 cb 01 be f6 2a 42 ce f2 ae 62 16
00 10 01 60 00 86 01 55 66 11 44 cb 03 be 69 6c f1 8f 3a 47 60 c9
00 10 01 70 00 1c bc 1f ff 5b c6 c4 27 00 de 07 e6 69 16 ed 31 ea
00 10 01 80 00 bc f6 d7 d0 6a e0 6e 69 3e c7 89 1c e1 13 1f 9d 64
00 10 01 90 00 92 99 88 b6 6a e4 7c 37 fa 29 ab 38 c4 ab 0f 26 b4
00 10 01 a0 00 c5 f7 b5 c9 66 e9 f7 dc 86 86 8a c1 91 44 1e 9b f1
00 10 01 b0 00 e4 49 2a f2 2a c8 56 aa b9 24 4f 1f e3 f8 3e 39 98
00 10 01 c0 00 33 d7 f7 42 14 e0 fa bc 57 fa a1 4f cc d8 bb d0 2d
00 10 01 d0 00 a4 32 64 34 fa 8f 5d 89 f3 70 7e bb ac 0a ed 26 22
00 10 01 e0 00 e5 70 ae 89 7a ef 3c 76 c0 f6 81 48 8f 03 3e d5 bb
00 10 01 f0 00 35 03 64 89 7a ca b0 77 99 f4 6c 10 8b 0a 39 29 90
00 10 02 00 00 7a 49 8a c1 15 f1 99 05 f2 7c ae 59 05 4b 71 28 21
00 10 02 10 00 d3 a2 22 0b 1e 68 f9 24 52 c7 e6 50 a6 bf 08 f6 18
00 10 02 20 00 53 40 5d 41 6c 6f b5 37 8f fd c1 84 7a 42 6f 9f c4
00 10 02 30 00 d9 cb 5d c8 63 fe 99 af 05 c7 8c 4e c5 7a f7 3d cc
00 10 02 40 00 13 60 64 c1 15 f1 4b 10 b6 ef c5 ef 4c 4b 71 14 bf
00 10 02 50 00 8d 15 e3 f4 4d 52 ae 49 90 70 12 2e 72 42 03 f6 5d
00 10 02 60 00 94 b8 5b 16 4b c9 5b 89 a0 d3 a7 cb c6 c2 7d 32 42
00 10 02 70 00 06 c8 5d 42 6c f9 4b 38 94 54 8b e5 69 f9 1e bf 6d
00 10 02 80 00 33 f6 ad b2 dd 16 f4 25 3b dc 46 ce c6 e3 14 29 36
00 10 02 90 00 d2 49 22 c1 15 f1 99 05 f2 7c 41 59 07 4b 71 28 36
00 10 02 a0 00 d1 a2 20 4b 61 70 4a a9 30 87 99 5f 48 2a b8 55 81
00 10 02 b0 00 46 35 4d 7f e9 8d c7 38 89 c0 96 8c e1 16 06 5a 3f
00 10 02 c0 00 4b 7b 04 24 6b f4 1d d2 88 cd 91 2b 6f 7d 3f d0 19
00 10 02 d0 00 ba 08 75 f8 6b f7 44 3e f8 8e d8 58 a3 b6 bd 52 12
00 10 02 e0 00 1f 1c c2 7d 11 42 e0 dc ff 44 e5 6f 03 02 47 21 7e
00 10 02 f0 00 d7 af 6e 98 86 f8 40 6f 64 c6 9b 58 00 56 38 28 8d
00 10 03 00 00 ab b8 4b 81 6b f8 4d 4a 81 b3 98 27 7a 9f 75 92 4e
00 10 03 10 00 75 40 5c c8 15 f8 46 b6 80 4e 95 ce d9 4b df d4 0c
00 10 03 20 00 17 5a fc 5e df 82 f8 26 89 12 9c 50 73 43 9c 9d f2
00 10 03 30 00 2f 4a 54 1d 67 f0 4c 36 03 c3 91 5c 75 99 9d 42 a5
00 10 03 40 00 92 c8 51 2b 61 7a 3d 3f 80 da ed 59 72 b2 11 9f f3
00 10 03 50 00 a4 42 44 8f 89 f4 0c dc 88 87 91 8d 43 a8 0d 69 0e
00 10 03 60 00 bc f6 d7 cb 89 89 0c 26 3e 44 e1 68 8e db 55 39 cc
00 10 03 70 00 ea a2 59 89 7a 6f 7c 2f 6e 3a d9 68 8e db 4f 39 5e
00 10 03 80 00 e2 00 44 fb 97 b1 5d 7c c8 d7 ef a5 3a 5b 70 d4 e0
00 10 03 90 00 ed 51 16 89 7a ca b0 77 f2 7d 9a 48 34 a8 03 68 82
00 10 03 a0 00 d4 08 1d 42 6f 44 56 8f 89 c2 86 8a e1 68 39 ca 2c
00 10 03 b0 00 ae c2 24 c8 63 e4 31 3e 89 3e 8e ee 73 48 1e 9e 8e
00 10 03 c0 00 46 4c 15 2b 6b b9 ae 4f c8 d7 30 a5 3a 5b b1 ca 49
00 10 03 d0 00 a8 00 44 7d 97 b1 4d ea b8 24 92 18 6b fc 8d 2a 6e
00 10 03 e0 00 46 31 15 d1 dd 7a 3d 2f 03 3a d9 68 8e db 51 39 83
00 10 03 f0 00 1b a2 59 89 7a 44 b0 77 70 24 9c 19 62 f9 f3 61 7e
00 03 04 00 00 df fb 5f 3f
00 10 0a 00 00 88 51 f3 b9 22 46 3c 76 c0 34 27 bc e4 fe c7 30 68
00 10 0a 10 00 12 92 e2 b4 fa b7 be 8d 6f e5 eb e4 d9 e5 f3 29 5c
00 10 0a 20 00 58 53 1a c9 97 0a f9 67 0a 3f 3c a5 43 b2 0f 8c 82
00 10 0a 30 00 b5 c7 55 67 7a 2b 4c 9a 99 7d 90 fa 42 c2 15 a0 65
00 10 0a 40 00 bf 31 1f 80 6b 10 3d 74 c0 c6 79 58 9b 5c be bb db
00 10 0a 50 00 16 99 e3 19 fc 42 5b 8d b8 3e 85 ee 53 7b ef d9 39
00 10 0a 60 00 5f 40 85 3b 22 52 ce df 89 16 6c f4 aa f5 dc f1 64
00 10 0a 70 00 1b 94 8c 3e be 0a 05 82 0a 2b 62 10 d5 c8 e4 da 53
00 10 0a 80 00 ed ee d7 26 fc 67 95 8b 5b 1f 67 8d aa 7d da da 3d
00 10 0a 90 00 ec 7f d7 24 99 b1 f3 bc 63 34 d8 93 f1 a5 1e 1e dc
00 10 0a a0 00 d4 09 f8 b9 23 35 5d 91 f8 8f 3c 29 3b 86 ed c9 f0
00 10 0a b0 00 6c a2 ba 01 e3 8d c4 4a 51 b1 4d a0 a3 96 f6 c0 ee
00 10 0a c0 00 7f b9 bc 13 b2 4b 50 cc 39 e1 12 86 09 f6 7d 83 aa
00 10 0a d0 00 bf 3a e9 2a 11 44 3e 80 93 6a 49 11 ae 93 47 f4 db
00 10 0a e0 00 7d f5 49 3b d8 bd ce e1 22 dd ea e5 01 e1 14 86 7d
00 10 0a f0 00 bf e1 4e 5e c4 48 57 9c 00 1b 18 85 aa ff 13 da a2
00 10 0b 00 00 ac 09 d7 16 c1 e3 36 82 fa 6d 8b f9 68 f2 15 5e d0
00 10 0b 10 00 a5 5b 47 5e fb 5a e4 24 71 24 4d a0 90 96 d6 9d 47
00 10 0b 20 00 b8 b2 e4 58 e9 27 e6 25 f2 7a e2 29 3b 02 98 64 ab
00 10 0b 30 00 7d 93 b0 44 8e 44 ed 98 89 67 82 e0 e3 ff a4 32 af
00 10 0b 40 00 a5 ef 59 d4 6b e5 4d 91 be bc 26 87 f9 af 9e 7c 32
00 10 0b 50 00 0f 5a ad ff 5b 70 56 4e c0 8e 18 44 69 2f 0f 34 73
00 10 0b 60 00 a5 5a 47 3e fa a0 4d 22 9e 30 02 ea d8 50 32 1e 39
00 10 0b 70 00 de f6 b2 c9 b5 f0 93 24 88 3a 25 f0 69 c2 eb bf e1
00 10 0b 80 00 1d 5a 4f c0 8f c3 1c e3 32 dc 25 64 45 c1 eb 29 22
00 10 0b 90 00 40 46 49 5d 30 f1 50 05 d9 1b 90 bd 87 68 4f 29 f4
00 10 0b a0 00 b9 47 b1 85 fb 47 c6 23 18 68 3b 43 e4 e8 0e 34 27
00 10 0b b0 00 94 51 88 21 5b c6 3d 74 c3 bf da 13 43 77 75 92 5a
00 10 0b c0 00 5a 50 e3 f4 5d 42 56 9a 89 69 81 7e 6a fc 75 9e 54
00 10 0b d0 00 67 fd f4 8a c3 e2 5d 09 f3 7d 9d e1 69 f6 b7 33 0e
00 10 0b e0 00 10 3a e0 92 7a 0f 37 85 85 3f 4f 88 8a 38 7c f1 c5
00 10 0b f0 00 12 32 54 18 7d 45 df c0 9e 79 02 e9 aa ff dd a0 43
00 10 0c 00 00 d6 d7 98 df da 6a e4 e7 3c 14 72 86 a1 fb 98 b9 83
00 10 0c 10 00 7f fd 4e 17 92 3f ae c7 4e 25 49 11 b4 93 47 ee 9b
00 10 0c 20 00 09 5b fa d2 fc 18 ae e1 5a 75 77 cb c0 5b b9 bf b2
00 10 0c 30 00 59 92 e2 67 fa 4b 5d 8f 1f 30 49 ea a1 c2 7d bf d1
00 10 0c 40 00 2f 56 ec 5b e8 ee 7b ac 13 24 4f 8b 3a ed 9f 9a 95
00 10 0c 50 00 76 09 fe 58 db 21 f9 ec 00 b4 07 cf a1 02 c8 b8 ce
00 10 0c 60 00 19 92 1c 66 fb 4a 9e 76 43 57 23 48 c7 dd b4 a0 fe
00 10 0c 70 00 76 c8 27 5e d4 e9 fa a9 3d d7 22 59 a1 4b dd 3e 44
00 10 0c 80 00 11 d3 e1 b2 dd b0 f4 25 38 bc 25 02 db 51 0e fa 07
00 10 0c 90 00 b2 f3 c6 7d 10 4e 6a 28 39 57 39 a1 09 fc e1 c0 93
00 10 0c a0 00 b5 e3 2f 7f a8 c8 b4 3e 2c c7 4d 4a f3 4a a1 39 04
00 10 0c b0 00 77 40 f1 d8 d0 f8 ef 0f be 3e eb ef 9d 7a ed 22 0d
00 10 0c c0 00 26 31 f9 d3 e3 fb db 92 89 ce 9c 5a 48 6a 6e 9f 55
00 10 0c d0 00 d9 62 15 2b 1a b9 65 68 3e 56 25 f4 69 52 b9 aa d1
00 10 0c e0 00 d5 cb 56 c8 68 fe 98 ac e0 fb a6 48 36 a8 03 68 75
00 10 0c f0 00 46 40 14 2b 61 b8 5d 73 6a ca d0 48 88 53 bc 52 ee
00 10 0d 00 00 12 83 44 8c 89 f4 0c 2f 8d 3a d9 48 76 b6 46 39 cc
00 10 0d 10 00 a1 bc 1c d8 2c b8 5d 0c 74 8f a6 48 c6 a8 03 68 94
00 10 0d 20 00 46 40 14 2b 61 b8 5d 9e 74 8f 81 e4 91 46 4f 39 dc
00 10 0d 30 00 33 70 44 2f 97 b1 7d c3 19 86 81 e6 33 5b b3 d4 05
00 10 0d 40 00 ed 51 e2 89 7a 54 b0 77 be ef c1 ed 43 63 5e 9d f6
00 10 0d 50 00 8d 10 e6 e0 3a 4a 65 6e 3d ef c1 ed 5a 1a bd 01 32
00 10 0d 60 00 fc f4 6a f8 57 ce 72 0e 89 b8 65 59 0d 76 30 19 3e
00 10 0d 70 00 94 b5 59 b7 6b 86 7d 01 7d f6 b8 55 0d 4a 71 19 b5
00 10 0d 80 00 92 5a e4 f5 5a f8 32 16 be f6 ac 70 a9 fc 9e 84 92
00 10 0d 90 00 99 44 2b 5d d0 f9 32 0e b5 f7 75 d1 0d 76 30 13 d2
00 10 0d a0 00 92 41 2b f2 8e f8 32 0f 6d 51 d5 67 6a f5 f7 16 d9
00 10 0d b0 00 94 62 8a 7a e5 86 b2 7e de 72 02 f8 e2 f4 0e 56 e5
00 10 0d c0 00 f3 f5 c6 79 2a 6f f0 3f f6 91 25 59 0d 0b 5a 9c de
00 0f 0d d0 00 7f f3 89 7f 01 b8 71 2e 3c cf ee 68 fb 34 39 86
00 00 ff ff 01 01 00 00 00 00 00 00 00 00 00 00 00
00 10 0c 00 00 5e c6 a7 3d 89 10 a4 d6 72 40 62 aa 93 f5 ad c0 e9
00 10 0c 10 00 4c a8 bd 21 83 10 a4 89 3f 78 42 e0 c4 f3 a9 90 86
00 10 0c 20 00 21 ff cb 6c b2 5f a8 80 79 63 53 fc 5c f4 f6 97 d3
00 10 0c 30 00 3e e7 79 6e ab 47 94 99 80 61 c4 e6 ba f5 90 97 d7
00 10 0c 40 00 04 ff 08 76 33 46 fd 9b d0 65 06 e6 8c f5 e9 97 0f
00 10 0c 50 00 97 ff 69 76 40 5e fc 98 16 79 66 fc 78 f5 08 97 0f
00 10 0c 60 00 b9 e6 af 6f c4 47 5d 81 9d 79 8f e6 03 f5 62 97 9d
00 10 0c 70 00 d2 ff 2b 76 0e 5c fb 9d 7a 79 d1 e6 3b f5 e0 97 50
00 10 0c 80 00 7a ff ad 77 ca 46 e0 80 1a 78 08 e7 84 e8 af 8b cf
00 10 0c 90 00 e0 e2 d9 6a b5 5a ba 9d f0 64 60 e7 90 fd b8 9f 95
00 10 0c a0 00 13 f7 f3 7f fd 4e da 89 3b 71 21 ee e0 fd b0 9f cc
00 10 0c b0 00 37 f7 c6 7e da 4f ef 89 1b 71 03 ee cb fd 9c 9f 5e
00 10 0c c0 00 37 f7 e4 7e dd 4f ea 89 3a 71 20 ee d4 fd a9 9f dc
00 10 0c d0 00 37 f7 e5 7e db 4f fc 89 2e 71 21 ee d5 fd 9c 9f e6
00 10 0c e0 00 14 f7 d1 7e cd 4f fd 88 1e 71 36 ee c6 fd bc 9f c7
00 10 0c f0 00 11 f7 e0 7e cc 4f fd 89 36 71 2f ef e5 fd 9c 9f f4
00 10 0d 00 00 1a f7 e5 7e cd 4f fd 89 3d 71 22 ee ce fd b2 9f 0c
00 10 0d 10 00 02 f7 e4 7e f8 4f df 89 39 71 41 ee c2 fd 9c 9f 09
00 03 0d 20 00 15 f7 f2 2d
00 02 08 15 00 a1 f9 b8
00 10 08 17 00 13 f7 e2 7e dc 4f fb 89 3f 71 27 ee c4 fd b8 9f 24
00 10 08 27 00 13 08 91 47 86 7d 77 37 05 4b 2d 1e c7 e3 6a 30 c1
00 10 08 37 00 16 fd ca 71 3a 3c fe 83 6f 8e e7 ae 84 fd b8 af 0d
00 10 08 47 00 13 18 2e 81 23 32 fb 9d 3a bc 2d 08 82 f7 b7 fb 7b
00 10 08 57 00 2f ef c6 4e e0 04 a1 ed 51 09 a5 62 52 5d 1d 35 74
00 10 08 67 00 bc 4e fa 4e 8c 37 5b 5b 1c 07 51 98 9e d0 8a 3f 8c
00 10 08 77 00 85 93 e5 79 9a 1f 9f 88 36 68 39 c6 f6 71 dc 9a 5e
00 10 08 87 00 11 f6 e3 7b df 47 f1 87 2b 6a 02 db 82 a2 0d 54 98
00 10 08 97 00 cc 1c 10 89 24 45 ef 97 0d 37 7d c0 94 cb fe 9a 96
00 10 08 a7 00 c6 f4 ca 7a d4 5f e3 a9 17 75 21 e9 cd f7 b4 91 1a
00 10 08 b7 00 1c e6 f0 6a ca 57 e7 a9 1b 59 34 fc d5 ed b6 93 8a
00 10 08 c7 00 15 f7 d2 56 f8 5b eb 9d 37 43 37 fe d0 f1 b2 cf de
00 10 08 d7 00 49 b1 ca 6a dd 4f fb 8f c0 15 15 f0 c1 f8 8a b7 a6
00 10 08 e7 00 30 3f ed be d6 56 6d d9 39 73 2b eb d0 99 e8 8e 2b
00 10 08 f7 00 11 df fb 7b c4 2b b0 26 3b 97 fb 26 16 ad e8 95 6c
00 10 09 07 00 1c 61 a9 1a d9 4a fa ed 3a 70 26 ee c5 ff bb ad 53
00 10 09 17 00 b0 e6 f2 81 d4 49 4c 62 d9 73 09 dc d0 cf b5 ad 35
00 10 09 27 00 19 f2 60 72 d8 2b c9 80 3f 61 07 de 84 ad d8 ef e5
00 10 09 37 00 93 67 42 ce 1c 9f 1b 79 c0 71 14 88 5d 31 47 25 6f
00 10 09 47 00 06 a9 2a 4c d9 56 fb 05 a9 d1 93 54 0c ae ea aa 62
00 0d 09 57 00 23 c7 d2 7e df 4f fb 89 3f 71 27 ee c4 e1
00 05 09 64 00 13 5d 48 2b 89 dd
00 10 0e 00 00 5c b5 d5 50 fa 6f e7 9e 2b 61 2a e5 cc fb bc 9d fc
00 10 0e 10 00 13 e3 f6 6a c8 58 ec 9e 28 66 3d d4 fe c7 82 a5 b8
00 10 0e 20 00 29 cd f6 6a c8 5b ec 9e 28 66 30 f4 fe c7 82 a5 de
00 10 0e 30 00 29 cd d8 6a c8 5b ef 9e 28 66 30 f9 de c7 82 a5 b8
00 10 0e 40 00 29 cd d8 44 fd 6e d9 ad 19 59 0d c2 f4 c9 80 a7 85
00 10 0e 50 00 29 cd d8 44 e6 59 e3 a9 1e 53 03 c6 e8 d3 88 ad 74
00 10 0e 60 00 27 c1 d8 44 e6 75 ef 91 1f 50 05 c8 ec d7 94 b1 a0
00 10 0e 70 00 23 c5 d0 48 e6 75 c1 9d 27 51 06 cd e1 db 90 b6 93
00 10 0e 80 00 39 db cc 4e e8 75 c1 b3 2b 69 07 cf e0 d8 9e b8 14
00 10 0e 90 00 3a dd ce 50 f2 7f c3 b3 05 65 3f ce e5 d9 9f b7 54
00 10 0e a0 00 3a dd c8 54 f6 63 d7 bd 05 4b 33 f6 da dd 9a b9 60
00 10 0e b0 00 3b dd c8 54 f6 65 d7 a5 11 47 1d fa d2 eb ae 89 3b
00 10 0e c0 00 0d d3 ca 52 f1 62 d5 a7 0f 41 15 dc d0 eb ae 89 db
00 10 0e d0 00 05 ef f8 60 fa 65 d6 a7 11 41 17 dc f6 e9 ae 89 70
00 10 0e e0 00 05 e1 fa 64 c2 6b dd ae 17 58 0d c5 ef d6 ac 89 34
00 10 0e f0 00 05 e1 f4 66 c6 51 df ac 19 56 0f c6 ec d5 90 8b 0f
00 10 0f 00 00 05 e1 f4 68 c4 55 e5 ab 1d 52 02 cb e1 db 9e b9 58
00 10 0f 10 00 07 e1 f4 68 ca 57 e1 97 1f 50 05 cc e6 df 9a bd 67
00 10 0f 20 00 31 e3 f4 68 ca 59 e3 93 21 50 06 cc e6 df 9a bd a6
00 10 0f 30 00 31 d5 a5 39 9b 07 b2 c5 6f 27 5d 6c 40 7b 30 15 aa
00 10 0f 40 00 9f 7b 6e 39 9b 08 b3 c0 72 25 7d 98 46 79 3e 17 f5
00 10 0f 50 00 99 7d 6e f2 9b 07 b1 c5 70 22 71 b2 b6 83 3a 1b 3f
00 10 0f 60 00 95 71 64 f8 5a 08 b3 c3 72 20 71 b4 98 8d c6 09 63
00 10 0f 70 00 8b 6d 78 e4 46 d5 b3 c0 75 3f 76 b8 9c a1 cc 1d 78
00 10 0f 80 00 97 73 66 fa 58 cb 7f c1 76 3a 68 bc 90 ab d8 1f 71
00 10 0f 90 00 95 7f 68 f2 50 c3 77 05 76 3b 6b a1 97 ab e2 fb 87
00 10 0f a0 00 95 7d 6e f0 52 c1 75 07 b1 3b 6d a2 94 ae ed c7 ae
00 10 0f b0 00 7d 71 68 f0 48 d5 65 29 9f d1 6d a4 88 ad ea ca 29
00 10 0f c0 00 4a 9e 94 04 a2 cd 7d 03 b3 fd ab a4 8f b0 e8 cd 40
00 10 0f d0 00 45 ae 86 14 ac 3b 83 09 b1 e7 b1 78 8f b6 f5 d0 b9
00 10 0f e0 00 43 a4 ba 24 81 2f 9f e5 bf e1 b9 70 5a b6 f3 d2 95
00 10 0f f0 00 5c a7 b0 2a 8a 15 9b ed 53 f1 a9 7f 55 6c f3 d2 04
00 10 10 00 00 5d b8 b2 28 84 15 a5 ed 55 0b a3 60 4a 73 36 d4 63
00 10 10 10 00 58 b9 ad 2e 8a 17 a7 ed 4b f3 ad 62 48 71 34 13 9d
00 10 10 20 00 58 bb b2 28 86 2f 93 f9 45 f7 ab 62 48 71 34 13 b6
00 10 10 30 00 9f bc ae 2e 8a 15 9b e1 4f f1 a1 62 48 71 34 13 e4
00 10 10 40 00 9f 7b a9 2e 88 19 a1 e9 57 01 a7 68 48 71 34 13 e2
00 10 10 50 00 9f 7b 6e f3 51 cf 7b 09 bf fa ac 6e 44 7d 38 16 70
00 10 10 60 00 9a 77 62 fe 5c cb 7f 09 bf f1 a7 6e 44 7d 38 1f 7c
00 10 10 70 00 93 77 62 fe 5c cf 7b 1d ad e1 a9 6c 46 69 2a 0f 47
00 10 10 80 00 9d 75 9c ee 52 c3 71 0f bd f3 a7 90 b8 91 ee e1 cf
00 10 10 90 00 6f 8d 9a 26 94 35 83 ff 4b 35 18 c0 e8 d7 90 bc 19
00 10 10 a0 00 30 d5 c2 61 c2 53 e7 a9 21 6c 3c f6 dc e1 a2 86 30
00 10 10 b0 00 0b e1 f4 66 cb 59 ee 9d 2b 65 33 fd d7 ef aa c5 b9
00 10 10 c0 00 45 bf cc 5e c0 7d cb a1 21 68 3f f3 d8 e5 af 8b 68
00 10 10 d0 00 00 ee fa 6a cf 5e f4 9c 2b 60 2a e5 ce ee aa 90 8e
00 10 10 e0 00 18 fd eb 4a e8 7b ce bc 0a 46 1f d6 f8 c1 84 a1 59
00 10 10 f0 00 2c b7 a6 3b 9a 09 bc c1 74 3d 6b be 95 af ed c9 c7
00 10 11 00 00 45 a2 b5 26 86 15 a1 5b 96 d3 b3 69 b8 8d dc c5 e4
00 10 11 10 00 5d d9 c6 67 cc 46 fa 89 71 31 12 c2 e1 e2 a2 89 8c
00 10 11 20 00 00 e7 ef 75 d5 48 fe 8d 3d d4 82 4b 61 58 1d 3a 21
00 10 11 30 00 b6 52 47 db 79 ef 5e 23 95 db 8d 44 6e 57 17 30 b0
00 10 11 40 00 bc 58 4d d1 73 e0 54 26 90 de 88 41 6b d5 8a d9 39
00 10 11 50 00 41 af be 1e be 29 93 e3 53 1d 49 80 aa 93 98 b3 5a
00 10 11 60 00 2f bf b0 28 82 2d 9d e1 55 1d 49 80 aa 93 d6 89 4a
00 10 11 70 00 31 c1 a6 30 88 11 9f e1 53 1f 57 9e b4 8d c8 ef d0
00 10 11 80 00 1f e1 d2 3c 92 1b a5 e7 4f 03 53 98 be 81 c6 1f 48
00 10 11 90 00 91 f1 ec 5c 9c 03 af d7 51 03 51 92 46 75 36 0d d4
00 10 11 a0 00 87 61 e4 72 c6 75 b1 eb 53 03 5d 6e 42 77 36 0d f2
00 10 11 b0 00 85 6f 78 7a d0 55 cf c1 5d 1d 53 94 44 7b 34 0f ce
00 10 11 c0 00 87 61 7a e4 d8 43 e1 bd 77 13 4b 96 ba 79 32 11 c0
00 10 11 d0 00 81 63 74 e6 46 4b f7 93 09 21 45 82 be 7d 3e 13 c6
00 10 11 e0 00 81 61 78 e2 42 ef ff 85 23 4d 71 8c b6 83 30 0d d4
00 10 11 f0 00 8f 53 4a d2 6c fd 4f 8d 33 6d 1b b8 a6 89 3c 0d 3e
00 10 12 00 00 89 57 46 d6 70 ff 4f 31 3b 7d 3d d8 96 a3 d4 e3 c9
00 10 12 10 00 99 63 7c da 76 e1 49 3f 85 75 2b f6 ec c5 fa d5 fd
00 10 12 20 00 41 a9 8e 04 5a df 61 2d 97 db 25 e6 ca e9 98 b3 ff
00 10 12 30 00 2b b7 aa 30 8a 11 9d e5 4d 07 5f ec cc f3 ac 87 bb
00 10 12 40 00 0f d7 c0 5a fa 67 d1 a5 0f 47 1b d0 c6 fb b4 8d 7b
00 10 12 50 00 07 e1 fa 64 c0 51 db ab 1b 57 0f c2 ea ff bc 99 cf
00 10 12 60 00 1b fd e8 74 d6 45 f1 83 35 7b 2d e4 ce f7 e7 f6 e7
00 10 12 70 00 7d 80 62 fe 5c cf 7b 09 bf f1 a7 6e 44 7d 38 1f 7a
00 10 12 80 00 93 77 62 fe 5c cf 7b 09 bf f1 a7 6e 44 7d 38 1f 97
00 10 12 90 00 93 77 62 fe 5c cf 7b 09 bf f1 a7 6e 44 7d 38 1f a7
00 10 12 a0 00 93 77 62 fe 5c cf 7b 09 bf f1 a7 6e 44 7d 38 1f b7
00 10 12 b0 00 93 77 62 fe 5c cf 7b 09 bf f1 a7 6e 66 5e 1b 3d cb
00 10 12 c0 00 b2 57 7c e2 44 db 6b 05 b7 f7 a3 6c 44 59 1d 3a 88
00 10 12 d0 00 b7 54 40 de 42 d5 6d 1b b1 fb a1 6a 46 7d 1e 38 89
00 10 12 e0 00 b4 51 47 da 7f ed 5b 15 a7 e3 ab 68 40 7f 38 79 10
00 10 12 f0 00 c1 5c 69 08 bb 14 a8 c2 7a 31 1c d9 f0 cc 96 b3 7d
00 10 13 00 00 32 d6 c3 60 c0 53 ed 9b 2e 61 28 e0 c8 f7 be 99 95
00 10 13 10 00 15 d3 c6 5c fd 6f e6 9e 2c 63 37 fe d4 f3 b4 97 02
00 10 13 20 00 1b ff ca 56 fa 6c d9 97 27 67 32 fa d7 ef a9 8f 0a
00 10 13 30 00 1d fb e8 52 f7 65 d3 af 1f 6a 3f f9 d2 e8 ac 8e 37
00 10 13 40 00 03 f9 ec 70 f0 64 d1 af 1b 51 3b f7 d3 eb ad 8b 22
00 10 13 50 00 02 e7 ec 70 d2 63 d0 a3 19 53 07 f3 df e4 af 89 c0
00 10 13 60 00 07 e6 f2 70 d2 41 d7 a2 15 57 05 ce da e1 a2 86 7f
00 10 13 70 00 0b e2 f0 6f d3 40 f4 a4 12 5a 00 ca e6 dd a6 85 ad
00 10 13 80 00 04 e1 f1 6f cd 5f eb 99 11 5f 0b c9 e7 dc a7 83 c8
00 10 13 90 00 0a e1 f7 6d cd 5e ea 99 2f 5c 0a c5 e2 de 99 80 e2
00 10 13 a0 00 0f ee f4 6a cf 5d ea 98 2f 61 0b c2 ed db 9c be 4a
00 10 13 b0 00 0c eb fb 69 c9 5b e8 9b 2e 61 37 c4 ee d5 9e ba 79
00 10 13 c0 00 31 e9 f9 67 cb 5a e8 9b 2e 60 37 fe ec d5 9e b9 df
00 10 13 d0 00 37 d6 ff 65 c5 57 ee 9a 2e 7e 29 e0 ca db 9e b9 b8
00 10 13 e0 00 37 d3 c2 62 c5 57 ec 9c 2c 60 28 e0 ca f3 9e b9 7c
00 10 13 f0 00 35 d3 c6 5c c2 55 e3 9e 2a 63 37 e0 ca f3 b6 b9 a4
00 10 14 00 00 35 d1 c6 5a fe 51 e1 91 28 65 36 e0 ca f3 b6 91 b1
00 10 14 10 00 35 d1 c4 5a f8 6d e5 93 27 67 34 fe ca f3 b6 91 f8
00 10 14 20 00 1d 08 1d 81 23 b0 04 76 c0 8e d8 10 3b 37 0e 3d 46
00 10 14 30 00 87 67 6c c6 7a db 6b 07 b1 d5 b3 62 44 81 c2 0f 6b
00 10 14 40 00 9b 73 62 02 a6 32 86 ed 5b 43 15 93 b9 99 dc ad 41
00 10 14 50 00 21 93 86 1a b8 7d c9 bb 0d 43 15 dc f6 e4 a1 86 c2
00 10 14 60 00 21 c5 d0 67 c5 56 e5 bb 0d f3 a3 68 4c 77 34 11 6e
00 10 14 70 00 83 67 70 ec 4e dd 6f 1d ab e7 a5 6a 42 75 32 13 2d
00 10 14 80 00 9d 67 72 ec 4e dd 69 1d ab e5 b1 6c 46 79 3e 17 77
00 10 14 90 00 99 7b 6c f0 52 df 69 1d ab e5 b3 78 46 7f 3c 1b b1
00 10 14 a0 00 95 71 6a f4 56 c5 77 05 b3 fd a9 60 54 7f 3a 1b 9f
00 10 14 b0 00 97 73 64 f6 56 c5 71 05 b3 fd ab 62 48 71 3a 1d 95
00 10 14 c0 00 91 75 60 fc 5e cd 79 0b bd f3 a5 6c 46 7f 3a 1d d1
00 10 14 d0 00 92 77 9c 00 a2 cd 7a 09 41 0f 59 6a 40 7b 3e 19 af
00 10 14 e0 00 9b 72 64 f8 5a c9 73 0d b9 f7 a1 68 42 7f 3a 1d e0
00 10 14 f0 00 91 75 60 f8 5a c9 7d 0f b9 f7 a1 6b 41 78 3d 1f f1
00 10 15 00 00 6f 9b 88 16 b4 cf 87 e5 55 19 4f 6e b8 8d d2 f5 f2
00 10 15 10 00 79 77 9e 08 ac 23 97 09 bf f1 a7 6e 44 7d 38 1f 16
00 10 15 20 00 93 77 62 fe 5c cf 7b 09 bf f1 a7 6e 44 7d 38 1f 3a
00 10 15 30 00 93 77 62 fe 5c cf 7b 09 bf f1 a7 be 8c bd 8e b7 10
00 0d 15 40 00 19 df ca 5a fc 5b fb c9 7f 31 67 ae 84 e1
00 00 ff ff 01 01 40
Obviously this is too small to be a complete binary of software and maps so it must be User settings kind of like a KIT racing ecu would download. Just eyeballing it I don't see any 3d maps in that data.
I also have copies of the custom cartridge firmware. They used to do a lot of gameboy development and hacking. Maybe you could dig up some familiar with the platform to disassemble the cartridge software?
#4613
Posted 16 December 2015 - 14:24
#4614
Posted 16 December 2015 - 15:26
AcaPostar, on 16 December 2015 - 14:24, said:
Mislim da je to ipak preterana cena za ono što se može uraditi sa njim, jer je to jednokratna pomoć u tuniranju PJta. Ne kažem da bi ga jednom skopčao na SRku već kad bih isprobao sve raspoložive mape pa ostavio najbolju, tada bi GameBoy i kertridž postali mrtav kapital. Malo je ditecha-PJetova na našim putevima da bi mogao unovčiti uslugu bar da se koliko toliko otplati. Možda se ipak nađe način pristupa ECU-u uz pomoć PC-a. Polažem nade u tu soluciju.
#4615
Posted 16 December 2015 - 15:41
Realno, nema od toga nikakvog pomaka nabolje. Moze se sve napraviti kako treba i bez te dijagnostike.
S druge strane, za purejet agregat, pristup bi trebao biti omogucen u svakom servisu, o cemu je vec bilo rijeci. Tamo sam i mijenjao 2 dostupne i raspolozive mape, i mogao sam pratiti parametre dok radi motor, provjeriti radne sate, resetirati greske.
Nakon sto sam shvatio da imam samo 2 mape na raspolaganju, i znam ih prepoznati u 5sec rada motora, potreba sa softverom ne postoji.
Jedino sto nisam siguran vise jel gameboy kompatibilan sa piaggio agregatom..
Ako netko ima volje i misli da moze nesto odraditi, moze racunati na moju podrsku.
Edited by dajteh, 16 December 2015 - 15:43.
#4616
Posted 16 December 2015 - 17:36
Postavis 2 dizne umesto 1 ko sto sad imas, samim tim smanjis pritisak i produziz vek trajanja ac pumpe.
Tako bi dobio dobru stranu karba i dobru stranu pjet tehnologije.
Konacno bi ti proradila ta rezona i verujem da je vise nebi skidao, a ulaganja su sigurno mnogo manja neg za taj gameboy..
#4617
Posted 16 December 2015 - 18:11
Boki, vec bi ja poradio na indirektnom ubrizgavanju al nemam adekvatne dizne ni mesto na usisu gde bi ih namontirao. Treba tu puno toga osmisliti i napraviti sa neizvesnoscu dali ce to uopste proraditi, kao i koliko goriva i kada ubrizgati.
#4618
Posted 16 December 2015 - 18:25
I meni se indirektno ubrizgavavanje cini kao jedino razumno rijesenje, ali onaj ko to misli odradit taj mora biti malo ludji.
Trenutni koncept je podredjen najmanjoj mogucoj potrosnji, dugom vijeku trajanja, i vrlo dobrim performansama.
Meni osobno pun pogodak, za sve ostalo su druga provjerena rijesenja.
Edited by dajteh, 16 December 2015 - 18:28.
#4619
Posted 16 December 2015 - 18:34
#4620
Posted 16 December 2015 - 21:07
