Sprint Eagle - Marko
1599 replies to this topic
#1561 Mario
Posted 22 April 2022 - 06:29
Sve jedno je prozračni su, ja za sam otvorenije prema radilici ako blok nema rupe za podmazivanje
#1562 MaRk0
Posted 23 April 2022 - 00:09
Imam rupice od usisa ka radilici. Montirao sam otvoreni deo ka spolja... Idem standardno metoda ležajevi na radilicu pa sve to zajedno u blokove. Radilica sat vremena u zamrazivaču a ležajevi u ulje na rešo pa grejanje na 90*. Dobar ovaj indukcioni ne laže, na kvarno ga prebacim na 100 jer nema 90 na par sekundi pa vratim... Provera unimerom naravno. Ulazi sve glatko sačekao da se izjednači pa nazad u friz.
Attached File  20220421_182007.jpg   1.38MB   18 downloads Attached File  20220421_182027.jpg   1.13MB   19 downloads Attached File  20220421_182317.jpg   1.29MB   19 downloads
Attached File  20220421_182405.jpg   1.39MB   20 downloads Attached File  20220421_182957.jpg   1.03MB   18 downloads
Ako krenem da žurim neka slobodno dodje neko da me izubija.
Radilica Malossi 5313587 dolazi sa njihovim igličastim 12x17x16mm ali ovog puta nema matica varijatora i magneta.
Ležajevi SKF Italija pakovanje Polini kod 280.0043
Semerinzi Polini 285.0002
Pitanje: Na koliko stežem dva dela blokova?
Edited by MaRk0, 23 April 2022 - 00:21.
#1563 MaRk0
Posted 26 April 2022 - 00:35
Cccc...
Attached File  20220422_163412.jpg   1.13MB   15 downloads Attached File  20220423_012524.jpg   863.87K   16 downloads Attached File  20220423_012433.jpg   584.15K   16 downloads Attached File  20220423_012441.jpg   604.04K   16 downloads
Attached File  20220423_012629.jpg   962.15K   15 downloads Attached File  20220423_012643.jpg   914.99K   14 downloads Attached File  20220423_012730.jpg   1.23MB   17 downloads Attached File  20220423_012748.jpg   968.62K   16 downloads
Attached File  20220423_012511.jpg   710.1K   17 downloads Attached File  20220423_012805.jpg   688.32K   17 downloads Attached File  20220423_012855.jpg   738.2K   17 downloads Attached File  20220423_012816.jpg   786.42K   17 downloads
Pa više sam posla imao da dovedem u red njihovu završnu obradu, nego ceo motor da sklopim.
#1564 MaRk0
Posted 27 April 2022 - 22:02
E ovo je milina za proveru da li vuče falš. :)
Attached File  20220425_182451.jpg   1.21MB   21 downloadsAttached File  20220425_182524.jpg   1.47MB   23 downloads
Attached File  20220425_182622.jpg   900.64K   22 downloadsAttached File  20220425_182635.jpg   713.97K   24 downloads
I naravno već tradicionalno "dihtovanje" auspuha... Ovu flanšnu nikad u životu svom nisam uspeo da zadihtujem.
Blokovi stegnuti na 17Nm. Radilica sa ležajevima upala odlično. Sačekao da se izjednači temperatura pa proverio, karakterističan luft za c4 ležajeve je prisutan, nigde ne zapinje, odlično...
Cilindar zategnut na 12.5Nm. Fabričke podloške pa manje bakarne 1mm debele i tek onda matice. Ispod cilindra 1mm klingerit i 0.2mm aluminijumski dihtung.
Zamenjeni su komplet ležajevi i semerinzi i u prenosu.
Sve je oprano u novoj igrački.
Attached File  20220422_022259.jpg   809.27K   25 downloadsAttached File  20220422_022304.jpg   810.07K   24 downloads
Ultrazvučna kadica je odlična stvar. Pogotovu kad se koristi sa adekvatnim odmašćivačem. Sve sam Živo oprao u njoj. Karburatori mi se sad sijaju kao pasja m...
#1565 Mario
Posted 28 April 2022 - 11:04
Uu jbt pun si nekog tools-a mini kompresor, mini kada, mini 3D štampač
#1566 Lauda
Posted 29 April 2022 - 01:21
Ee to je vec visi nivo radova :)
#1567 Pita
Posted 01 May 2022 - 08:55
Da baš si se opremio sa nesvakidašnjim alatima u hobi radionici...Jl koristiš ti to i u neke komercijalne svrhe ili isključivo za motor ? :)
#1568 MaRk0
Posted 06 May 2022 - 00:31
Vise je kao hobi. Neko trosi na pice, neko na zene, neko na raznorazne gluposti a ja trosim na alatkice. Naravno, padne tu i tamo po neki dinar ali kad sve saberem i oduzmem uvek sam u nekom minusu... ;)
E sad da vidimo sta kazu Italijani iz doba korone... :D Uzeo sam ovo sa 997km na satu. 2021. godiste
Attached File  20220504_112306.jpg   2.09MB   29 downloadsAttached File  20220504_100138.jpg   2MB   28 downloads
#1569 Mario
Posted 06 May 2022 - 08:39
Auu otvori novu temu za ovu lepoticu..
#1570 MaRk0
Posted 10 May 2022 - 13:52
Tačno ću da se šlogiram jedan dan zbog ovakvih prestupa... Za malo da najebe sve u dekli.
Attached File  20220510_142743.jpg   78.75K   36 downloads
Sent from my SM-A528B using Tapatalk
#1571 vlayco
Posted 10 May 2022 - 20:56
Iskreno, ne znam zasto to drzite na visoko tjuniranim agregatima,em je masa zamajca velika, em eto potencijalnog problema kao ovde.
Cupaj to napolje, uradi cauru distancer iza I mirna glava, pali na kurblu kao i svi normalni ljudi 🤣
#1572 Damjan66
Posted 10 May 2022 - 21:20
Lepo kaze vlayco hehehe, takodje ces odbaciti i taj olovo bendeks od radilice manje teret :P
#1573 MaRk0
Posted 10 May 2022 - 21:36
A trebao sam lepak malo da kapnem ili feder podloške... Sreća pa nije ništa drugo stradalo. Poskidaću mu sve to i vratiću inner rotor. Sad makar mogu da biram.
Nema... Sex na sve strane! :1kokice:
Attached File  20220510_142943.jpg   957.49K   31 downloads
Edited by MaRk0, 10 May 2022 - 21:42.
#1574 Pita
Posted 11 May 2022 - 07:29
Hahahah izabrali lep ambijent :)
A što se tiče šrafova i vibracija, tu ni lepak ne pomaže...vibracije su toliko zaebane da odvrću sve živo, seku i režu limove...pucaju nosači auspuha, kao i dekle...ma haos...
#1575 MaRk0
Posted 11 May 2022 - 22:28
Ovo sam ja kriv pošteno. Pokušavao sam da rešim neko zveckanje tog mehanizma pa sam zeznuo stvar... Nema vibracija za sad. Osim onih pozitivnih. :D Kako je dobar osećaj kad povuče kao iz praćke. Ne mogu da skinem kez sa lica! Jednostavno da ne poveruje čovek da je tako nešto moguće. Pa majku mu kako! Jbg potrošnja ide na 4.5l na 82km to izadje nekih 5.5l na 100km ali svaki km vredi :D
#1576 Lauda
Posted 11 May 2022 - 23:44
Heh, ja godinama pokusavam da resim zveckanje tog mehanizma i bez uspeha. Cak sam menjao i veliki iglicasti lezaj, jok.
Sad tek da uzivas u sezoni :)
#1577 MaRk0
Posted 13 May 2022 - 01:13
Problem je izgleda taj što nisu rešili aksijalni zazor izmedju velikog zupčanika i "zamajca" i onog malog prenosnog izmedju anlasera i velikog. Ima kao ona velika podloška ali to i nije neko rešenje. Možda to treba premeriti i odraditi što preciznije sa minimalnim zazorom da ne bi zveckalo. Ali kao što rekoše kolege gore nema svrhe zadržati te delove u ovakvom setup-u. Možda u konfiguracijama koje rade ispod 9k obrtaja u minuti ali ovde realno nema šta da traže. Inače da dodam da je racing mk2 mogao da se odradi za široki spektar obrtaja dok ovde nema ničega ispod 9 hiljada i kususr rpm. Čak i igranjem sa varijabilnim paljenjem po želji ne mogu da dobijem da mirno radi u spektru od npr 5k do 9k obrtaja. Moram da snimim klip kako sad radi i kako se čuje.
Uradio sam konektore za instalaciju i komponente(CDI, Pick-up) tako da budu kompitabilni i da mogu lako da menjam izmedju fabričke postavke, ove moje sa varijabilnim programabilnim CDI-jem i MVT inner rotor paljenjem. Fiksno paljenje nema šta ovde da traži. Sa njim ne mogu ni da nateram motor da udje u rezonancu. Mislim, mogu ali sa prelakim rolnicama. Moje paljenje ubija boga kad uleti u rezonu i puca od snage ali je tu problem što je magnet fabrički i samo molim boga da se ne raspadne. MVT onaj narandžasti DD nekako ne odgovara zbog mape paljenja koja je zadata u CDI-u koji dolazi sa njim ali je svakako bolje od serijskog...
Ne znam kako da objasnim to ali imam osećaj da mogu preko mape paljenja da ispeglam greške u postavci karburatora(do neke mere) ili suprotno da poboljšam efekat rezonance kod ispravno podešenog karba. Samo bukvalno sve zavisi od projekcije cilindra i izduva i koji su ciljani obrtaji. Milion varijabili je u glavi, nekad imam osećaj da sam poludeo. :blink: Ali kako bi mi jedan dyno test valjak rešio sve to je strašno. Moram da dodjem u kontakt sa nekim ko poseduje opremu za testiranje skutera. Samo da bacim poogled makar. Zamislite grafik snage/brzine/momenta/tačke paljenja/obrtaja u jednom... :D
Edited by MaRk0, 17 May 2022 - 22:31.
#1578 Mario
Posted 13 May 2022 - 04:55
Upalio si sad lampice, pa gaziš nemilosrdno..
Da se nadovežem za narandžasti DD, previše prgava mapa, ogroman ugao dole, nema vožnje na srednjim obrtajima..
Tačno je da sa offset-om krive može da se pegla podešenost karburatora, i sasvim je logično, veće predpaljenje traži bogatiju smešu i obrnuto.. ali sve do neke mere da ne izađeš iz optimalnog ugla za ciljane obrtaje..
#1579 MaRk0
Posted 19 June 2022 - 22:57
Stiglo vreme za regu. Vratio sam mehanizam za paljenje na dugme. Prsten za bolcnu varijatora 3d štampam od ABS-a ali moram da nadjem koja debljina mi treba. Za sada sa 8mm prstenom i 5,5gr rolnicama ide malo preko 45km/h. Naravno uštrojim ga onim mojim programabilnim CDI-om da ne baca varnicu preko 8k rpm i 40km/h(Verovatno sat laže nekih 5km/h).
Problem mi ostaje to zveckanje glupog mehanizma el. startera. Ne mogu to da rešim, baš me iritira.
#1580 Laki993
  • 290 posts
Posted 20 June 2022 - 10:32
Zvecka verovatno jer se pojela mala šajbnica pa je dobila lufta. Tako je i meni bilo na kinezu, našao drugu imao sreće da je debljina bila baš koja mi treba stegao sve lepo i nije se čulo ništa više. Imaš 2 šajbnice, jedna deblja i jedna tanja, nadji neke pa se igraj, mora baš na tesno da stoji.
