Baotian Falcon 50R
937 replies to this topic
#541 VlatX
Posted 09 December 2017 - 13:31
flak je 3mm i imace jos pojacanje,mozda ga i skratim malo ali kad dovrsim grlo,grlo je digacko samo radi ugla inace bice jedno 5cm krace kad se zavrsi
#542 Damjan66
Posted 11 December 2017 - 16:41
Svaka cast Vlatku , uvek odradi kako sto treba profi. Ispada 45 stepena zakrivljen ovako karb, ovo grlo cu koristiti za sad za ovaj karb kad uzmem 28cu onda cu kupiti kisler ili hebo grlo.
Attached File  25271221_10213018768561782_1354686848_o.jpg   210.55K   56 downloads Attached File  25286973_10213018827043244_977257051_n.jpg   38.77K   68 downloads Attached File  25285821_10213018817763012_549403224_o.jpg   122.93K   70 downloads
Attached File  25344384_10213018829923316_233509672_o.jpg   196.15K   63 downloads Attached File  25286169_10213018788042269_268435615_o.jpg   102.96K   57 downloads Attached File  25316987_10213018817723011_2040611548_o.jpg   149.11K   58 downloads Attached File  25319545_10213018772681885_1834066360_o.jpg   53.08K   55 downloads
#543 Damjan66
Posted 14 December 2017 - 19:38
Evo na kraju kako je ispalo
Attached File  25400937_10213043166571717_793846208_o.jpg   77.67K   56 downloads Attached File  25397658_10213043165371687_362546505_o.jpg   76.41K   67 downloads Attached File  25400860_10213043124650669_2011721851_o.jpg   155.5K   65 downloads
#544 Damjan66
Posted 23 December 2017 - 08:57
Evo namontirano sve kako ispalo , narucio sam i jos neke sitnice koje stizu uskoro.
Attached File  25577094_10213088032813345_461164787_o.jpg   1007.69K   60 downloads Attached File  25577451_10213087787927223_2044507526_o.jpg   721.63K   70 downloads Attached File  25579242_10213087788807245_58063274_o.jpg   826.83K   64 downloads
Edited by Damjan66, 23 December 2017 - 08:57.
#545 Damjan66
Posted 14 January 2018 - 22:34
Sta kazete o kupovini athena racing-u novi dosta jeftino 150eura , najbolja mi varijanta nekako 10ka bolc da uzmem novi da ga izvozim i malo podici izduv samo minimalno, jel ce imati vece razlika od sporta ili da cekam slednu sezonu nesto mnogo jace sa drugom radilicu ?
#546 Mario
Posted 14 January 2018 - 22:46
Athena racing je bila kao stage 6 racing MK1
A jes potpisao vlatx blok na vidnom mestu bokte, marketing ko kuća
#547 Damjan66
Posted 14 January 2018 - 23:47
Da ja sam mu rekao tamo hehe :rofl_jaki:
#548 Pita
Posted 15 January 2018 - 22:00
Naravno da je Racing jači od Sporta...i nemoj dizati izduv ni malo jer je i u stock postavci razrok do bola...
radilica bi trebalo da isprati tog Racinga ako ćeš menjati...
#549 Damjan66
Posted 16 January 2018 - 00:23
Jeste jak al cisto jos malo neki konj da se dobije nece biti lose , moze ovaj spuh da izgura naravno bice sa 28pwk karbom.
#550 Damjan66
Posted 19 January 2018 - 20:52
Jos jedno pitanje dali bih mogao cak i 30mm karb da uzmem za ovaj kit trenutno? Dali bi bilo problem oko stelanje il ice moci da se ustela ili je ipak previse golem?
#551 Mario
Posted 19 January 2018 - 21:46
Nije, ja imam 30
Pita i Boki imaju isto 30
#552 Yooalexandar
  • 1,393 posts
  • MestoZemun
  • VozimVespa Et4
Posted 19 January 2018 - 23:00
View PostMario, on 19 January 2018 - 21:46, said:
Nije, ja imam 30
Blago Vama, meni je 19
#553 Damjan66
Posted 19 January 2018 - 23:29
O sport pro-u pricam , da ne bude zabune znam za athena racing nema problema.
#554 Mario
Posted 20 January 2018 - 06:59
Jer tomos imao 40 na onim takmičarskim motorima od 50 ccm ?
Salim se naravno, promer difuzora karburatora se bira prema nameni agregata, nije uvek pravilo da ce veca kolicina smese doneti i vise snage... Taj tvoj sport pro je Vlatx nakopao, pa u zavisnosti od površina transfera, lamelica, primarne kompresije i BD-a možeš ići na veći difuzor..
#555 Mario
Posted 20 January 2018 - 09:34
tebi i taj "ispada po putu" :)
#556 Damjan66
Posted 20 January 2018 - 22:20
Da vas pitam dali odgovara sekundar od kineza na ovih minarelli blokove , ima da se kupi 13-31 koji mi daju produzenje od 22% sto mislim da je dovoljno.
Attached File  26942942_10213349162261418_1515839812_n.png   23.73K   29 downloads
#557 Mario
Posted 20 January 2018 - 22:25
Ne odgovara
#558 Yooalexandar
  • 1,393 posts
  • MestoZemun
  • VozimVespa Et4
Posted 21 January 2018 - 10:48
Eto jednom padne I posle ne moze ni Dunav da te opere :D
#559 Damjan66
Posted 31 January 2018 - 22:48
Masina je kod mene , cekam jos traka za auspuha da stigne , da kupim zupcanik za kurblu i da produzim sajlu jer ova sa novom trkackom ruckom je 1m a treba mi 1,5m, pa onda montiram masinu.
Takodje promenjena je igla od W7 na W16 i pilotka od 50 na 40.
Attached File  27605192_1601739423235725_1834762735_o.jpg   273.05K   42 downloads
#560 Pita
Posted 03 February 2018 - 15:39
Mašina je više raskačena nego spojena na ram skutera...tako to ide...
Matorci bi sad pitali, šta sad opet ne valja?? :)
Zimski radovi pripremanja mašine su najbolji, jer ima se vremena na pretek i treba sve uraditi polako i tačno..
