#721
Posted 08 July 2018 - 20:36
#722
Posted 08 July 2018 - 20:51
Sent from my Xperia XZ Premium using Tapatalk
#723
Posted 08 July 2018 - 21:47
Otvoren filter i vožnja po kiši ne idu zajedno, teško ćeš ga i blatobranom sačuvati al biće bolje sigurno....
#724
Posted 08 July 2018 - 21:55
Edited by Damjan66, 08 July 2018 - 21:56.
#725
Posted 08 July 2018 - 22:12
#726
Posted 20 July 2018 - 19:16
37409004_1800633926679606_8229384152063934464_n.jpg 162.17K 25 downloads 37574196_1800634003346265_707229466945912832_n.jpg 187.54K 25 downloads 37621902_1800633970012935_793670275097952256_n.jpg 157.52K 24 downloads 37629561_1800681986674800_7026801576995979264_n.jpg 118.66K 24 downloads 37621902_1800633970012935_793670275097952256_n.jpg 157.52K 24 downloads 37590502_1800681976674801_4879389710784397312_n.jpg 172.08K 26 downloads 37594137_1800633910012941_1872321912437211136_n.jpg 139.08K 31 downloads
Ubacio sam mu i 32 pilot iglu sam ostavio ako ima potrebe podesicu i iglu mislim da ce sa 32kom da przi od 0 ako nije prevelika i ona, filter sam ispricao sa sprejom i montirano sve nisam hteo da ga palim za kratku test voznju sutra cu vise da ga vozam i stelam ako je dobro vreme.
37372215_1800682960008036_8963302996758757376_n.jpg 192.24K 40 downloads 37568782_1800683213341344_5237486161026351104_n.jpg 174.88K 45 downloads 37390705_1800682686674730_5329957056017334272_n.jpg 176.68K 41 downloads 37419315_1800682476674751_5282067075450273792_n.jpg 148.7K 37 downloads 37574411_1800667523342913_5430282728933163008_n.jpg 287.46K 35 downloads
Takodje sam se raspitivao za dyno moracu da ga stavim ovi obrtaji me tako zbunjuju, radicu neke testove prvo sto mislim pa videcu.
#727
Posted 24 July 2018 - 06:12
Ako nebude dobra delta onda mislim da probam da kupim malossi crne oprugice za delta clutch sto prodaju dosta su kratki i debeli su 2,2mm i te da probam na moju verovatno ce da hvata na 8 sa njima... kad sam imao 2mm od piaggio s6 opruge na 50ku hvatala je nad 8 ali dobro drugi setup prenos sve. Ako nevalja i sa oprugama onda cu kupiti definitivno doppler sx86. Trenuto sad sa malim gas start pa punu odma odvalim vreme koje vadim je jako dobro i zadovoljan sam ali iskreno mislim da ce biti mnogo jaci na 13 800/900.
#728
Posted 30 July 2018 - 01:08
38003719_1815944048481927_8291417782059270144_n.jpg 266.03K 42 downloads 37844453_1813653615377637_1283437353049784320_n.jpg 109.68K 47 downloads 37966923_1815899978486334_8286598949012242432_n.jpg 91.03K 42 downloads
#729
Posted 30 July 2018 - 23:47
S druge strane skidaj te Stage6 nalepnice jer sa Malossi i Polini nalepnicama dobijaš +1kmh više...
#730
Posted 31 July 2018 - 00:38
#731
Posted 31 July 2018 - 10:21
#732
Posted 31 July 2018 - 12:32
Umesto tog hladnjaka mogao bi da ubacis ventilator od nekog veceg modela skutera,tipa sp 180,vespe gts 300 itd.
Sent from my Smartphone_6.1 using Tapatalk
#733
Posted 31 July 2018 - 16:23
#734
Posted 06 August 2018 - 00:50
38462401_245237422792833_2262003771217281024_n.jpg 807.33K 39 downloads 38647249_638912063168864_1368318353633968128_n.jpg 602.84K 46 downloads 38485085_309918749751914_2753938424674123776_n.jpg 774.62K 41 downloads 38676550_946434155549224_1387677850001211392_n.jpg 857.52K 39 downloads
#735
Posted 06 August 2018 - 10:21
#736
Posted 06 August 2018 - 12:08
Sent from my SM-G950F using Tapatalk
#737
Posted 06 August 2018 - 15:52
Javi rezultate.
Edited by vlayco, 06 August 2018 - 15:53.
#738
Posted 06 August 2018 - 20:02
#739
Posted 09 August 2018 - 19:10
Evo i zasto sam nemao obrtaja u ubrzanje kais ic nece da isteruje neznam sta bi bio problem ako nije remenica drugo neznam ? Kais vozim 775 x 17,4mm 28stepena polini kevlar, merio sam i rastojanje treba 17,5 kais ispada al nema veze i ovaj profi moze da izgura do gore.
38806611_275175856618437_3610922440475017216_n.jpg 220.46K 21 downloads 38818150_256491894963705_9057069820821897216_n.jpg 178.99K 26 downloads 38914335_1022180691291868_3473910913558380544_n.jpg 113.52K 29 downloads
Inace sajmnu je Vlatko postavio izmedju bolcnu i kapacku kais je lezao super za malo da je perfektan.
38812291_247747489195268_2210183994358628352_n.jpg 172.57K 35 downloads 35223545_10214476501244188_8232398673644879872_n.jpg 365.16K 29 downloads
Sutra cu da prodam lamelu pa cu da porucim doppler sx86 videcu sta ce biti neznam sta da radim sa prenosom motor nisam pucao mnogo, vise od 120-125km/h sigurno nije vozen nisam toliko dugo drzao pun gas moralo bi da ga izbaci do gore kad bi moglo al ocigledno nemoze.
#740
Posted 10 August 2018 - 22:57
38806611_275175856618437_3610922440475017216_n.jpg 38818150_256491894963705_9057069820821897216_n.jpg 38914335_1022180691291868_3473910913558380544_n.jpg
38812291_247747489195268_2210183994358628352_n.jpg 35223545_10214476501244188_8232398673644879872_n.jpg
Kakvo produzenje getribe imas pa guras tu brzinu? Fino je to, pogotovo kada ga budes natjerao do kraja da izadje.
