#261
Posted 27 January 2012 - 17:31
#262
Posted 28 January 2012 - 00:36
sve pohvale dobro je ispalo, fino prima gas
#263
Posted 28 January 2012 - 01:43
isli bi malo gore,kad bi se stavio neki jolly moto .. koji za apriliju i cagivu kosta i do 500e a mozda i vise
#264
Posted 28 January 2012 - 11:14
P.S. sale dobar ti je potpis
#265
Posted 28 January 2012 - 12:45
tako nesto,ili za nsr 250..neverovatno je kako je taj motor brz
a ko ima cagivu mito,i moze da nabavi masinu od rd 350 vrlo lako to moze da ukombinuje..
p.s Hvala
#266
Posted 28 January 2012 - 13:30
#267
Posted 28 January 2012 - 14:18
#268
Posted 28 January 2012 - 14:46
#269
Posted 28 January 2012 - 16:03
Milos'96, on 28 January 2012 - 14:46, said:
#270
Posted 28 January 2012 - 16:52
Milose ako mislis da ti fali snage, sedi na motor i dodji na adu huju. Kad spustis vreme ispod 42 sekunde vreme je za veci.
#271
Posted 29 January 2012 - 15:45
#272
Posted 29 January 2012 - 17:09
Steta sto je na snimku bez originalnih oklopa, treba ga videti uzivo, zraci.
On, gamma i nsr500 - zive legende http://forum.pyrothe...tyle_emoticons/default/smile.png
#273
Posted 29 January 2012 - 23:29
#274
Posted 30 January 2012 - 01:35
cvele, on 29 January 2012 - 23:29, said:
ovaj gore mislim da ima 750ccm ,proleteo pored ovog pri izlasku na stazu ko da je skuter xD http://forum.pyrothe...tyle_emoticons/default/sign0188.gif
#275
Posted 30 January 2012 - 11:04
#276
Posted 30 January 2012 - 18:03
#277
Posted 30 January 2012 - 22:48
#278
Posted 30 April 2012 - 17:34
Nego akumulator mi pri kraju,otiso bas za motorijadu,pa sam nekoliko put morao na guranje da ga palim,pa sad gledam akumulatore,vidim da za njega ide 12V 5Ah dimenzije 120X130X60,ali vidim yuasa ima 3 vrste,razlika u ceni ogromna,a karakterisitke iste,pa me interesuje u cemu je uopste razlika:
http://batterycentar...-5Ah/pid/783337
http://batterycentar...-5Ah/pid/783338
http://batterycentar...-5Ah/pid/783342
#279
Posted 20 May 2012 - 22:45
Ja nemam iskustva u tome,nikad nisam napravio nista elektronsko,nisam nikad cak ni promenio neki element na elektornici(jeste da idem na elektortehnicki smer,ali sam tek 1. godina,a tamo ucim uglanvom teoriju,formule i tako te gluposti),a hteo bih da napravim jednu elektroniku cisto da je imam za rezervu,e sad nasao sam jedan sajt,moze da se poruci preko interneta(posto u Smederevu nema ni jedne prodavnice tih elektronskih komponenata).
Ovo je sema elektronike(znaci samo do bobine,bobina mi ne treba,ovo je sema za onu sa bobinom u sebi,ali ja hocu samo elektorniku),i sastavio sam otprilike spisak,ali je sema nekako neprecizna,ne znam od koliko W otpornici,pa 2 diode ne mogu da nadjem,a ne znam dal moze neka druga sa ovog sajta itd...
Uglavnom,kod otpornika sam gledao da otpor bude isti,a W sam uglanvom stavljao najjace(to valjda ne smeta,to je samo valjda koliko mogu da izdrze),i evo su linkovi do svake komponente sa seme(osim diode MIKRON SK1/16 D2 i diode IR2006 D1),ali proverite dal sam uzeo dobar tiristor(posto ni njega nema,pa sam uzeo na svoju ruku neki za koji mislim da je najslicniji,malo sam istrazivao po netu itd).
Ovo je sema po kojoj hocu da pravim:
A evo ga spisak koji sam ja sastavio na svoju ruku,pa ne znam dal je sve dovoljne snage,znaci da to bude trajna elektrnika,a da ne crkne posle prve voznje:
Otpornik R1 - 10R
Otpornik R2 - 470R
Otpornik R3 - 10K
Otpornik R4 - 33K
Otpornik R5 - 56K
Kondezator C1 - 2mikrofarada , 400V(e ovde ne znam sta znaci onaj simbol,dal je to obican kondezator,ili mozda elektrolitski(mada bi on morao da ima obelezeno + i - ,ja sam stavio onaj koji sam nasao,a neki kazu da je bolje da se tu stavi 1 mikrofarad,valjda zbog brzeg praznjenja,pa el to tacno,ili da stavim kako pise u semi?):
Kondezator C2 - 10nF (e sad ovde ne znam koji da stavim,dal od 100V ili od 500V,i za to mi treba pomoc):
Kondezator C3 - 4.7mikrofarada , 35V(ovde sam stavio elektrolitski 4.7mikrofarada,samo 50V,to valjda ne smeta):
Dioda D1 - IR2006 :E to ne znam koju da stavim,stavicu posle link do ovog sajta,pa ako neko moze da mi nadje neku koja ima iste karakteristike kao ova sa seme.
Dioda D2 - MIKRON SK1 / 16 :isto kao i za D1
Dioda D3 - 1n4007
Tiristor TH1 - Motorola T12182 (ovaj ne mogu da nadjem,ali mi se cini da je ovaj slican,ali proverite vi,posto ja ipak neznam nista oko elektronike):
Sajt sa koga bi porucio,pa bi bilo dobro kad bi bilo svih elemenata tu:
http://www.retam.co.rs/
To je to,sad ako neko ima volje da mi malo pojasni oko elektronike...istu tu elektroniku mi koristi i piaggio,i znam da sa njega odgovara na yamahu,a bez ove 2 diode za 10e mogu da napravim 3 takve elektronike,sa sve probnim plocicama(uzeo bi ove plocice,posto ne znam ja da crtam seme,ispiram kiselinom i kako to vec ide):
A i ja bi voleo da je napravim sam,to bi mi bila prva elektronika,pa jos kad bi proradila... :scooter
PS morate da kliknete na sliku elemenata da bi se videla cela.
#280
Posted 10 August 2012 - 15:04
Malo pre sam izasao na otvoren put,put koji vodi iz Smedereva prema Kovinu,znaci ravnica,nema uzbrdica,nizbrdica,ni nicega,i navuko sam ga do ravno 150kmh ja sam prezadovoljan,za mojih 90kg nije lose
Evo ga jedan snimak do nekih 145kmh,tek se pri kraju vidi km sat,kroz ubrzanje se uglavnom vidi obrtaljka,ali se vidi da je otisao preko 140kmh.
Edited by Milos'96, 10 August 2012 - 15:06.
