PRC oversize variator,ventilvar...
#61
Posted 16 July 2014 - 22:38
A za onu fiksnu polutku mislim da se moze naci sa FREE postarinom, nemoguce da je skuplja od varijatora..
#62
Posted 16 July 2014 - 22:50
#63
Posted 16 July 2014 - 23:26
#64
Posted 17 July 2014 - 16:59
#65
Posted 10 August 2014 - 12:03
https://www.heavy-tu.../i71/712956.jpg
Markiran , kompletan , nije ni skupo , na ceni od oko 80 evra ( kod njih ) mada su Kinezi znatno jeftiniji ...
To sto daju i oversize kais uz komplet , samo potvrdjuje da smo na dobrom putu kod povecanja i prednje i zadnje remenice , mi cemo to uraditi znatno jeftinije kad sve dovedemo do kraja ...Morini zadnja + oversize kineski vario + oversize kais ...nisu oni pametniji od nas...
Description
The oversize variator Stage6 - the perfect complement for the Stage6 Oversize converter. On race and MidRace engines indispensable: enlarged CVT systems that extend the entire shift range. Stage6 R / T-Vario offers revised and for R / T engines optimized roller raceways for 19x15,5mm weights - as result results in a very homogeneous speed curve, which affects the entire acceleration period. The flank angles are precisely machined on a CNC lathe and then sealed with a ceramic conversion coating to obtain the surface finish and roughness longer. A glass-rays as pure aluminum transducers is not necessary, and only then, if the coating shows clear signs of use. The ramp plate has a reinforced press-on. The sintered liner ensures optimum lubrication properties.Supplied also included is the Lüfterradhälfte including fan and a set of weights and a matching Stage6 R / T back pressure spring. A special, reinforced crown nut allows for easier installation and stable fixation of the Vario.Special assembly tools are also available from Stage6. while the oversize variator can also be operated with standard transducers, the optimal performance you achieved but only in connection with the oversize converter and an extended oversize belt. This is the variant with 13mm Vario stump. 1 set of weights 19x15,5mm à 3.5g
Edited by ALIEN SM, 10 August 2014 - 12:04.
#66
Posted 10 August 2014 - 13:47
ali ovi nasi jaci base setupi bi mogli da koriste i nesto jeftinije a dobro...opet kazem cekamo test PRC 100mm....
#67
Posted 10 August 2014 - 20:56
#68
Posted 22 August 2014 - 23:00
http://www.aliexpres...1435788968.html
http://www.aliexpres...440620019.html?
#69
Posted 22 August 2014 - 23:25
#71
Posted 24 August 2014 - 21:55
#72
Posted 24 August 2014 - 22:48
Prvo da ja ugradim onu tvoju morini 123 polutku i vidim kako ide, ako sve bude ok multivar se moze lako prodati
#73
#74
Posted 27 August 2014 - 22:18
#75
Posted 27 August 2014 - 22:33
985.png 28.57K 5 downloads
Jbg pisi slova bez apostrofa npr. umesto š kucaj s ....
#76
Posted 28 August 2014 - 15:47
#78
Posted 10 September 2014 - 18:46
#79
Posted 11 September 2014 - 18:43
#80
Posted 12 September 2014 - 00:40
