#41
Posted 25 August 2016 - 17:25
Na otpadu uzmi od Suzuki Katane ( suzuku-morini agregat) remenice od 123mm koje su linearne, to svi voze na minareli / kina bloku i daje odlicne rezultate, a kosta 20 eura sa sve kvacilom
#42
Posted 25 August 2016 - 20:17
TopRacing sa linearnim kanalima d=34mm.
13493482_1061821223894217_1031677168_o.jpg 146.56K 31 downloads
Edited by Damjan66, 25 August 2016 - 20:23.
#43
Posted 25 August 2016 - 20:20
Sajmna ulazi unutra,sredjena
DSC_0307.JPG 1.49MB 32 downloads DSC_0309.JPG 1.91MB 35 downloads
Pozicija kaisha je dosta bolje od prethodno,al tacno mi hvali jos 0.5mm/0.6mm sajmna da bide perfektno,samo dali cu moci da stavim ono za kurblu to cu probati videcu.
DSC_0311.JPG 1.24MB 42 downloads
I mehanizamm
DSC_0312.JPG 1.19MB 41 downloads
#44
Posted 25 August 2016 - 20:27
#45
Posted 26 August 2016 - 17:47
#46
Posted 26 August 2016 - 19:43
Ako je serijski variomat, nemaju staze za rolnice dovoljnu duzinu pa nece ni jedan remen da izadje do vrha. Resenje malossi multivar.
#47
Posted 26 August 2016 - 20:05
#48
Posted 26 August 2016 - 20:24
Po pravilu, duzi remen daje kraci prenosni odnos, a kraci remen daje duzi prenosni odnos.
Duzi remen stoji vislje u remenicama, ali manje izlazi na variomatu, dok kraci remen stoji na pocetku nize u remenicma, losiji je start, ali izlazi vislje na variomatu i daje vecu krajnju brzinu.
#49
Posted 26 August 2016 - 20:54
#50
Posted 26 August 2016 - 21:25
Inace evo je ,ima lepo na scooter-attack ali nemogu kupiti ,jer nema dostavu do MKD
Capture.JPG 83.05K 41 downloads
Edited by Damjan66, 26 August 2016 - 21:37.
#51
Posted 13 September 2016 - 14:33
#52
Posted 13 September 2016 - 14:43
biće rezultata dobro je ....
#53
Posted 13 September 2016 - 15:46
Edited by Damjan66, 13 September 2016 - 15:47.
#54
Posted 13 September 2016 - 16:17
#55
Posted 13 September 2016 - 16:31
#56
Posted 16 September 2016 - 21:12
Evo sajmna
DSC_0317.JPG 3.88MB 31 downloads DSC_0318.JPG 3.02MB 32 downloads
Ovde poslikao vario
DSC_0316.JPG 3.34MB 35 downloads
Polozba kaisa
14359650_1124694727606866_1974528043_o.jpg 62.38K 35 downloads 14329329_1124695130940159_2074424906_o.jpg 45.52K 34 downloads
Posto mi je auspuh bio izvaden ,a dihtun sam izgbio pa sam napravio novi ,pravim od ovog kingerita jako dobro drzi nema gajle.
DSC_0319.JPG 3.51MB 35 downloads DSC_0320.JPG 1.57MB 30 downloads
Kad sam sve sklopio ,zapalio motor ,okey radi ,posle toga stavio novu svecicu NGK BR8HS i zapalio i motor ugasio,onda probao pod malim gasom kad drzis radi ,a kad dodam punu motor se gusi, uzeo zavrteo straf za smesu dodao benzin probam opet eto okey je ali mi nije nesto naj, posle sam otisao test voznju 5km. E sad imam 2 stvari koji su mi nejasni prvo sa lamelom, imao sam pre ovoga stage6 najmekse opruge na drugu poziciju motor krece na 4500-4600rpm,sad sam stavio sredjne isto na drugu poziciju sad krece na 5000rpm ,to me buni sta tako malo ja sam ocekiva na vise ,znaci sad mi jos preostaje da stavim najtvrdje definitivno jer motor posle povuce malo je 5000rpm ,meni treba bar 5500 nadam se da cu dobiti sa najtvrdjim ako ne onda neznam. Druga stvar koja me buni sa pilotkom 38 nije palio sa krenutim sauhom , e sad kad sam stavio 32 opet ista prica kad krenem sauh motor ugasi ,a sa spusten radi i pali bez problema ,dali sam ja loso namestio sauh ili sta je stvar ne kapiram? I ovo za svecicu sto ne bi odgovarala 8ca hmm, probacu sutra 7cu koju sam imao siguran sam bolje ce da bude ,a i alspuh takodje trebacu da uradim jos jedan dihtun disi dole na granu cuje se ,sutra ide sredijvanje pa videcu, razmisljao sam i o ovom diznom 70 mislim da mi je mala malo videcu sutra boju , negde 76 bi odgovaralo dobro mislim al nema to kod nas nazalost ne nalazim to ja , evo i video palenje i ubrzanje nista posebno kratko.
Edited by Damjan66, 16 September 2016 - 21:25.
#57
Posted 17 September 2016 - 14:41
#58
Posted 17 September 2016 - 20:33
U ovim situscijama se stavlja ili mekša centralna opruga ili teže rolnice, probaj prvo samo oprugu pa posle po potrebi dodaj težinu rolnica
#59
Posted 17 September 2016 - 20:34
#60
Posted 17 September 2016 - 21:04
