Tomos BT 50
177 replies to this topic
#121 jack023
  • 214 posts
Posted 12 May 2013 - 13:18
Može, javi mi na face ako šta bude :D
A antifon sam morao da stavim koliko reže...očekujem u sredu/čevrtak poziv za sud-zbog buke :D
Nego, gde mogu da kupim dihtunge za ovaj moj motofirce kit? Da li su isti kao i za standard mina horizontal? I šta mislite o Stage 6 racing cilindru? Kakav je?
Edited by jack023, 12 May 2013 - 13:19.
#122 jack023
  • 214 posts
Posted 13 May 2013 - 21:46
Neko? Hoću da poručim par delova iz Moto Bike-a pa mi je zato malo hitnije.
#123 cvele
Posted 13 May 2013 - 21:50
Sve je isto ko na ostalim mina cilindrima...ako se bas nesto malo i ne poklapa-tu je skalper :4u2ap3b:
Finally the review
Posted ImageStage6 Racing 70cc LC
190€ / 15,1 hp / 13.569 rpm
The Stage6 Racing was tearing up the scene when it first got released (btw there is a version 2 about to arrive :). At its low price and great feature set it made the established manufacturers (especially Polini and Malossi) look very old and outdated. But not only the price but also the performance exceeded the expectations of most. In combination with the Stage6 R1200 exhaust it creates a Stage6 typical (see the Sport cylinder test) very wide revenue band. Definitely a killer combo that is easy to adjust and with 10 nm torque also good for the one or other hot lap on the circuit. The T shaped exhaust port allows for improvements and there are some high end portings out there that reach the 20 horse power mark.
Stage6 Racing 70cc 15,1hp at 13.569rpm
#124 jack023
  • 214 posts
Posted 13 May 2013 - 22:34
Oho :) Sviđa mi se ovo što si postavio!
Mislim da sam dobro prošao sa 4000 što sam platio cilindar sa glavom.(mada nikasil je očajan pa ću morati da nosim da se stavi nov sloj)
#125 bojan681
Posted 22 June 2013 - 13:31
a kolko kosta stavljanje nikasila i gde se to radi?
#126 tuningfanatic
Posted 22 June 2013 - 13:50
Zaboravite na obnovu nikasila, preskupo je to, vise se isplati novi cilindar kupiti.
#127 cvele
Posted 22 June 2013 - 14:13
Zavisi od cene novog cilindra ...a i u kojoj drzavi zivis :respect:
http://www.airsal.co...eparaciones.htm
http://www.airsal.co.../reparacion.pdf
#128 bojan681
Posted 22 June 2013 - 14:26
pa onda se jack023 ni ne isplati kupovati taj cilindar, za njega 111e kosta stavljanje nikasila, za te pare mozes nov uzeti.
#129 jack023
  • 214 posts
Posted 22 June 2013 - 15:08
Džabe kad sam ja kupio :( Tj. cena je bila ok, samo kad mi je stigao cilindar imao sam šta da vidim.
#130 bojan681
Posted 22 June 2013 - 15:17
a ja sam cuo da se moze stavljati i metalna hilzna il kako se zove, bez obzira sto je alu cilindar, mozda bi to bilo isplativije?
Edited by bojan681, 22 June 2013 - 15:17.
#131 tuningfanatic
Posted 22 June 2013 - 16:23
Jeftinije, ali losije resenje. Gusana hilzna se ne siri kao aluminijum pa dodje isto kao da je ceo cilindar gus. Ako se ne odrade dobro kanali, snaga moze biti znacajno manja nego pre hilznovanja.
#132 jack023
  • 214 posts
Posted 29 September 2013 - 11:03
Pozdrav!
Evo mene opet posle malo duže puze vraćam se projektima :D
Za vreme letnjeg raspusta sam radio, ali sad kako vidim uradio sam sve osim onog što sam hteo. No nema veze. Evo par sličica :D
Prvo sam započeo sa sređivanjem cilindra od moje Honde NS.
PRE:
POSLE:
Ostale kanale, pa i ostatak obrade nisam uspeo da slikam jer mi se mobilni oprostio od života...
Nastavljamo...
Malo sam opremio i sredio radionicu...
Čak sam uspeo da nabavim kalup za izradu trkačkih oklopa :D
Nastavio sa Tomosima...
#133 Mario
Posted 29 September 2013 - 11:14
aux portovi na apn-cu, sad već preteruješ...:D
#134 jack023
  • 214 posts
Posted 29 September 2013 - 11:16
Imam jedno glupo pitanje :D Kako se postavljaju ovi ležajevi, pošto nisam nikad imao prilika da radim sa njima?
Znam, krajnje nepotrebno, ali kako su BT/T15/Junior cilindri skupi, a od apn-a imam "na merenje", koristim ih za vežbu :D
Edited by jack023, 29 September 2013 - 11:17.
#135 Mario
Posted 29 September 2013 - 11:19
znam jasno je, na apn cilindru se vežbaš, provalili smo te u nekim ranijim postovima, i sasvim je opravdano...
za ležajeve sa poliamidnim imaš metode kod mene i kod cvele-ta u temi
#136 Mario
Posted 29 September 2013 - 11:26
http://forum.pyrothe...ndpost__p__2337
#137 jack023
  • 214 posts
Posted 29 September 2013 - 11:35
Fala :D Našao sam šte me je zanimalo. Znači montiraju se zatvorena strana prema semeringu (ako dobro vidim)
http://www.pyrotherm...007_aprilia.jpg
#138 Pita
Posted 29 September 2013 - 13:05
kolika je širina izduvnog kanala na hondinom cilindru? Vidim da si uklonio pregradu ali nadam se da širina izduvnog nije preko 70% prečnika cilindra...
#139 Mario
Posted 29 September 2013 - 13:33
ležajevi su prozračni, u principu sve jedno je kako ih okreneš, postoje razne teorije kako, mada niko ne može da se zakune sa koje strane dobije viša podmazivanja, da li sa rupice iza ležaja ili kod proreza celim obimom do polutke radilice...
tako da stavljaš kako misliš da je najbolje
#140 jack023
  • 214 posts
Posted 29 September 2013 - 19:39
@ Pita Merio sam prvo, i ne prelazi 70% :D Problem je što je hilzna jako loše urađena. Kanali su pomaknuti po 3 mm, čak ima i pregrada na mestima gde ne bi trebala biti.
@ Mario Hvala :D
