#4681
Posted 21 January 2016 - 22:13
#4682
Posted 21 January 2016 - 22:15
Edited by jovan139, 21 January 2016 - 22:15.
#4683
Posted 21 January 2016 - 22:16
#4684
Posted 21 January 2016 - 22:19
bojan681, on 21 January 2016 - 08:33, said:
#4685
I svi hvale ove kedi vulkanizere iz novog sada ali ja nisam zadovoljan sa njima. Prvi ventil su mi s**bali, krenuo ukrivo da zavrce maticu a tanak alu navoj i osteti se, posle on meni prica fabricka greska a ventili dosli sa vec navrnutom maticom i sve je bilo ok.
Posle mesec dana cekanja da stignu novi ventili dam im da ubace ovaj trenutni cnc, ovaj put im ja stavim maticu i zapocnem zavrtanje i radnik klestima samo stegne maticu umesto da to lepo uradi kljucem i posle 3 dana ispusti guma, pa opet skidaj tocak, pa reklamiraj. Kasnije je drugi majstor lepo stegao ventil gedorom i vise ne pusta..
#4686
Posted 21 January 2016 - 22:24
#4687
Posted 21 January 2016 - 22:28
Da, ova klesta su brembo sa aprilije, ne znam mozda je felna pravljena za aeroxa sa onim grimeca celjustima ili koje sve postoje..
Vise ne zapinje, ali sam morao malo da pobrusim taj sraf na celjustima..
Edited by bojan681, 21 January 2016 - 22:29.
#4688
Posted 21 January 2016 - 22:29
Jel imas bolju sliku sa druge strane?
Edited by jovan139, 21 January 2016 - 22:31.
#4689
Posted 21 January 2016 - 22:31
#4690
Posted 21 January 2016 - 22:39
#4691
Posted 21 January 2016 - 22:59
#4692
Posted 21 January 2016 - 23:07
#4693
Posted 21 January 2016 - 23:20
#4694
Posted 21 January 2016 - 23:30
#4695
Posted 21 January 2016 - 23:32
Jer moguce da je prikljucak nizi na rox opletenom crevu i matica manja-plica ?
#4696
Posted 21 January 2016 - 23:40
#4697
Posted 22 January 2016 - 00:07
Inace oko skutera se vise nece raditi, od kako sam krenuo na fax prioriteti su se promenili, dobio sam cak par dobrih ponuda za motor ali za sada ostaje u mom vlasnistvu do daljnjeg.
Sad samo odrzavam ovo sto sam napravio stim da ce sve biti perfektno ustelovano, vec midrace postaje preglasan tako da ce ovaj motor imati pocasno mesto u garazi i po nekad cu moci da se provozam.
Inace kad dodje toplo vreme imati ovakvu spravicu je super, prolazim pored automobila koji su 100x skuplji od mog motora ali njih niko ne primecuje vec svi gledaju u moj skuter, a i taj kad proradi adrenalin nema cenu..
#4698
Vidis sad vec nije to,to...Po meni je to glupost,voziti motor 1 u mesecu,sad najmanje sluzi onome zbog cega si ga i kupio..naravno svako radi kako on zeli...
Edited by SingeNS, 22 January 2016 - 00:10.
#4699
Posted 22 January 2016 - 01:39
Izvinjavam se što je sve prljavo, nisam imao vremena i živaca da uglancam zadnju felnu i kočionu čeljust pa je tako kako je.. do proleća.
#4700
Posted 22 January 2016 - 11:36
Evo kako stoje kod mene, s tim da oem ventil stoji bitno drugacije!
Mislim da je jedini izbor Grimeca, recimo Malaguti F15 je ima i ona ima ulaz dole, a odzracnik gore.
