#581
Posted 24 November 2015 - 12:31
#583
Posted 24 November 2015 - 13:33
#584
Posted 24 November 2015 - 13:35
#585
Posted 24 November 2015 - 13:41
Metrakit PRO race - 250e
metrakit_pror_2.jpg 148.7K 27 downloads metrakit_pror_3.jpg 228.71K 27 downloads metrakit_pror_4.jpg 173.12K 29 downloads metrakit_pror_5.jpg 277.62K 28 downloads metrakit_pror_6.jpg 243.64K 30 downloads metrakit_pror_1.jpg 305.14K 28 downloads
The company, which is known for the extremely powerful cylinder Pro Race 3 is Metrakit from Spain. With the knowledge gained from many years of racing, aluminum cylinders are manufactured with exceptionally aggressive response and phenomenal power delivery. For beginners in the field of Scootertuning the Metrakit cylinders are certainly not suitable. Connoisseurs of extreme Scootertuning is known as a package with the name Metrakit cylinder Pro Race 3 feels. The performance characteristics of the Metrakit cylinder Pro Race 3 is enormous.
The big brother of Metrakit cylinder SP3 which Metrakit cylinder Pro Race of aluminum, for water-cooled Minarelli engines as Aerox or Nitro, is now available also in the improved 3rd generation. The high-end aluminum cylinder with extremely stringent timing, and a huge 3-split outlet, overflow channels 4, 2 support channels and a compression ratio of 15.5: 1, delivers up to 23 hp at 14000-15000 U / min, depending on the carburetor and Exhaust. The produced in Italy Metrakit Pro Race 3 cylinders have a very good quality and are delivered with a high quality coated Vertex Piston incl. Thin chrome-piston ring. A modular cylinder head with self-centering is also included and provides an excellent heat output and optimal combustion. A stable crankshaft, which has grown both speeds, as well as the torque, must necessarily be used. It is recommended, for example, the crankshaft Metrakit Pro Race 3 MK850A0512 that adequately the performance of Metrakit cylinder was made ??may translate into rotary motion.
The delivery of Metrakit cylinder complete with gold anodized cylinder head cover, hochverdichtender Brennraumkalotte and seal kit incl. Several base gaskets to adjust the squish and a coated pistons with 12mm piston pin.
#586
Posted 24 November 2015 - 13:49
#587
Posted 24 November 2015 - 14:08
#589
Posted 24 November 2015 - 16:02
AcaPostar, on 24 November 2015 - 15:25, said:
Koliko se secam, za te parice ide " ceo kit " - cilindar klip glava i radilica!
http://www.speed-par...narelli-lc.html
ako pogledamo da za pia za te pare ide sa spuhom
http://www.speed-par...it-piaggio.html
odnosno da ide sve sa blokom i paljenjem za 1400
http://www.speed-par...ggio-15323.html
#590
Posted 24 November 2015 - 16:17
Doduse, ovde je u pitanju speedparts, mozda je to samo njihova ponuda.
Nije mi jasno da su favorizovali pia a za minu ispadne dosta skuplje.
Ali ako pogledamo komplet sa blokom, polini prodaje komplet agregat 94cc kao i malossi za 4k eura, sve slozeno i podeseno, kupac samo da ga upali. Ovo je stvarno primamljivo, 98cc za 1400, jedino fali sistem usisa i karb..
#591
Posted 24 November 2015 - 16:22
70ccm
94ccm
#592
Posted 24 November 2015 - 16:46
#593
Posted 24 November 2015 - 16:47
Mislis da su ovi kompleti podeseni u svim segmentima, tipa pogodjen karb i prenos? (Za koju ukupnu tezinu motora i vozaca, za koje vreme tj temperaturu itd itd...)
#594
Posted 24 November 2015 - 17:16
http://www.ebay.de/i...%3D131658331500
#595
Posted 24 November 2015 - 17:58
dajteh, on 24 November 2015 - 16:46, said:
naravno da je dovoljno da bude razlika u spoljnoj temperaturi ili visinska razlika izmedju fabrike u italiji i naprimer novog sada, ili to sto se uzima u jednacinu da je prosecna tezina dzokeja 75kg, pa da se svakako mora sve podesiti..
#596
Posted 24 November 2015 - 21:23
#597
Posted 24 November 2015 - 21:30
Nemoj preterivati
#598
Posted 24 November 2015 - 22:14
#599
Posted 25 November 2015 - 00:45
Bogami lepo prima gas, nije uopšte truba...biće nešto od Du'l'eta!!
#600
Posted 25 November 2015 - 11:23
imam dve opcije po pitanju karburatora ili mikuni 16 ili dell phbg 21, auspuh imam S6 pro samo bi ga trebalo uljuditi, u načelu da se planira neka duža eksploatacija sa ovim setup-om moglo bi se to sve skockati, imam i fabrički volan-paljenje, remenicu-prenos itd... za sada je kao što se i vidi na snimku sve komplet sa HE-a, pa ću vremenom već razmisliti... možda budem složio i druge blokove da ne komplikujem toliko taj prelazak...
@Pita... fino radi Dule,... ide to meni, pogotovo kada sam motivisan i kad postoji neka fina vizija u glavi, ostali deo posla više nije smoran...
što se backup-a tiče, mora da odradi jedno vreme,... ipak je to gus sa polovnim klipom, koliko god da sam ga polirao i honovao, mora da legne... mada kad bolje razmislimo originalni due klip ima jednu ali deblju kariku, dakle sumnjam da će ovde 1mm opstati jer mislim da je velika oscilacija na gusu koji je honovan, ipak nije ideala kao nikasil... dok sa druge strane ovaj baš nije ovalan niti grbav, zaista je malo vožen i odložen..
Što se kvaliteta materijala tiče, nemam nikakvo iskustvo, vreme će pokazati... Za sada planiram SR-ku da odložim na zimovanje i bacam se na Peugeot-a koji me čeka još sredine leta... posle njega dolazi 4T povratak u serijalu, pa deva i farbanje plastika. eto spremio sam za zimnicu da mi ne bude dosadno
28 user(s) are reading this topic
0 members, 28 guests, 0 anonymous users
